Thread: 50 X 50 Welding Literature ... # 50
    2451 Weld overlay coatings for erosion control
    2452 A REVIEW OF CAVITATION-EROSION RESISTANT WELD SURFACING ALLOYS FOR HYDROTURBINES
    2453 Ultrasonic Measurement of Weld Root Erosion
    2454 Corrosion
    2455 High-velocity slurry erosion of welded cobaltbased alloys
    2456 Welding on Rotors for Power Plant Turbo Sets State of the Art
    2457 THERMOGRAPHY ANALYSIS ON WELDING DEFECTS AND INTERNAL EROSION OF CARBON STEEL PIPELINE
    2458 The Electrochemical Investigation of the Corrosion Rates of Welded Pipe ASTM A106 Grade B
    2459 Erosion and Abrasion Resistance of Boride and Carbide-Based Weld Overlays
    2460 Influence of welded layers thickness on the cavitation erosion resistance
    2461 Erosion in elbows in hydrocarbon production systems: Review document
    2462 Unifuse overlay cladding for surface protection against corrosion and erosion/corrosion in power boilers and waste heat recovery systems
    2463 Comparison of erosion-corrosion behaviour of hot isostatically pressed and welded stellite coatings
    2464 Role of Weld root Geometry – Backing rings in Flow Accelerated Corrosion (FAC): Radiography testing is an alternate NDT method for detection – An experience at Tarapur Atomic Power Station-1&2; Nuclear Power Corporation of India Limited* India
    2465 Solid particle erosion resistance of ductile wrought superalloys and their weld overlay coatings
    2466 Erosion Wear Behavior of Inconel625 Plasma Transferred Arc Weld (PTAW) Deposits using Air
    Jet Erosion Tester
    2467 Case Study: Failure Analysis of a Weld Neck Flange in a Refinery
    2468 PROBLEMS IN LASER REPAIR WELDING OF POLISHED SURFACES
    2469 Hardfacing
    2470 Lifetime extension with hardfacing
    2471 Poster – ESAB: ISO and ASME welding positions
    2472 ASME Welding Positions Comparison with ISO & EN
    2473 Arc welding technical posters
    2474 STT Pipe Root Pass Weld Process Guide
    2475 Lincoln: WELDING PRESSURE PIPELINES & PIPING SYSTEMS
    2476 STT Pipe Root Pass Synergic Weld Process
    2477 Welding terms
    2478 Advantages of MAG-STT Welding Process for Root Pass Welding in the Oil and Gas Industry
    2479 Welding with a digital root welding penetration technology
    2480 IIW guideline for the assessment of weld root fatigue
    2481 Modified Short Arc GMAW Techniques for Welding a Root Pass
    2482 Gas purging optimizes root welds
    2483 Weld imperfections and preventive measures
    2484 Influence of root gap and tack weld on transverse shrinkage during welding
    2485 WiseRoot+ HIGHLY EFFICIENT ROOT PASS WELDING
    2486 Gas Tungsten Arc Welding − GTAW − (40 Hours Course)
    2487 Tool design for joining processes
    2488 DESIGN AND FABRICATION OF MIG WELDING JIGS
    2489 Mechanisation and Welding Fixture
    2490 JIGS AND FIXTURES
    2491 Welding tables
    2492 Welding Jigs & Cutting Metal
    2493 Introduction to JIGS AND FIXTURES
    2494 3-D Welding Table Systems Jigs & Fixtures Automation
    2495 The Frame Jig
    2496 Interpretation and Implementation of Some Aspects of Welding Process and Fixture for Increasing SPR in Manufacturing Industry A Case Study
    2497 Distortion Control in Thin Low Carbon Steel Plates Using Sequential Welding and Restraints
    2498 JIGS AND FIXTURES
    2499 An Effective Jig for Friction Stir Welding of Pipe Butt Joint
    2500 Assembly Techniques – Category II Welding* Adhesive Bonding
  3. Re: 50 X 50 Welding Literature ... # 50
    Massive effort* well done BornToSin. Many thanks.
    probably soon will come part 50 x 50 # 2
  1. 50 X 50 Welding Literature ... # 25
    Last Post: 01-17-2017, 06:51 AM
  2. 50 X 50 Welding Literature ... # 24
    Last Post: 01-17-2017, 05:53 AM
  3. 50 X 50 Welding Literature ... # 23
    Last Post: 01-17-2017, 04:29 AM
  4. 50 X 50 Welding Literature ... # 05
    Last Post: 01-10-2017, 04:56 AM
  5. 50 X 50 Welding Literature ... # 03
    Last Post: 01-09-2017, 05:41 AM
