1201 GENERAL GUIDELINES FOR STELLITE® HARDFACING ONTO STEEL SUBSTRATES
1202 Scrap Specifications Circular
1203 Vision for Welding Industry
1204 The effect of microstructure on abrasive wear of hardfacing alloys
1205 Assessment of Aframax Tanker Hull-Girder Fatigue Strength According to New Common Structural Rules
1206 Nickel-Based Superalloy Welding Practices for Industrial Gas Turbine Applications
1207 P23 and P24 for power generation and hydropgen service – are they fit for these applications?
1208 Alloy design for similar and dissimilar welding and their behaviours
1209 SELF-WELDING EVALUATION OF STELLITE 6 AND STELLITE 156 IN FlOWING SODIUM
1210 Steels: Mettaalurgy and applications – 3rd edition
1211 Glossary of NDT Terms
1212 MICRO-SCALE SLIDING WEAR BEHAVIOR OF HVOF SPRAYED WC-Co(Cr)
1213 Applications of advanced low-alloy steels for new high-temperature components
1214 MICROSTRUCTURAL INVESTIGATION OF A COMPLEX COBALT BASED THERMAL BARRIER COATING TESTED BY QUICK THERMAL SHOCK
1215 Microstructured cermet powders for HVOF spraying
1216 Improvement of Stress-rupture Life for Modified-HR6W Austenitic Stainless Steel
1217 Liquid Penetrant Testing
1218 Procedure Manual Visible Dye Penetrant Inspection Process Spray Can Method
1219 Recent progress in high strength low carbon steels
1220 Examination Guide for Initial Certification Liquid Penetrant
1221 Comparision of the properties of stellite 6 alloy when supplied in different product forms
1222 Rare earth elements
1223 Life Management and Maintenance for Power Plants Vol. 1
1224 Life Management and Maintenance for Power Plants Vol. 2
1225 Liquid Penetrant and Magnetic Particle Testing at Level 2
1226 COMPRESSION PRE-STRESS OF TUBULAR TORSION SPRINGS
1227 Hydrogen and Temper Embrittlement of Medium Strength Steel
1228 Welding procedure and welder approval
1229 AWS: Safety and health fact sheets
1230 Arc Stud Welding Fundamentals
1231 FABRICATION OF HASTELLOY® CORROSION-RESISTANT ALLOYS
1232 GAS METAL ARC WELDING
1233 FABRICATION OF HAYNES® AND HASTELLOY® SOLID-SOLUTION-STRENGTHENED HIGH-TEMPERATURE ALLOYS
1234 Pipe welding handbook
1235 EPRI: Engineering training module
1236 Welding Robots
1237 Susceptibility of service exposed creep resistant materials to reheat *****ing during repair welding
1238 MECHANISM OF PHOSPHORUS SEGREGATION IN HAY OF Cr/Mo STEEL AND ITS EFFECT ON REHEAT *****ING
1239 Materials and Hydrogen
1240 Recent Advances in Creep Resistant Steels for Power Plant Applications
1241 IMPACT TOUGHNESS OF STEAMLINE MATERIAL 14MoV6-3 AFTER LONG-TERM EXPLOITATION
1242 In-service Condition Monitoring of Piping Systems in Power Plants Requirements and
Advanced Techniques
1243 Assessing Innovation Infrastructure in Fossil Power Generation Plants
1244 Two Shifting of Power Plant: Damage to Power Plant Due to Cycling - A brief overview
1245 Potential Issues in the Cycling of Advanced Power Plants
1246 RISK-BASED COMPONENT LIFE MANAGEMENT IN FOSSIL POWER PLANTS
1247 EPRI AND SOUTHERN COMPANY BUILD A HIGH ACCOUNTABILITY MAINTENANCE ORGANIZATION WITH PLANNING & SCHEDULING
1248 Creep Monitoring of Repair Welds in High Temperature Components
1249 Root Causes of Transient Tube Temperature Anomalies Measured in Horizontal Gas Path
HRSGs
1250 Effect of Full Annealing PWHT on a Long -term Creep Strength of 2.25Cr-1Mo Steel Welded Joint
