1101 Influence of Post Weld Heat Treatment on Secondary Hardening of CrMoV Welded Joints
1102 TWI: Elevated temperatures of weldments
1103 Plant Life Management - How and What ?
1104 Quality management at RWE using T24 boiler material as an example
1105 PRINCIPLES FOR EXAMINATION OF WELDERS
1106 Performance of P91 Weldments Under Steady And Cyclic Load Conditions And Directions For Future Research
1107 SCHAEFFLER DIAGRAM CALCULATION OF STRUCTURE FOR STAINLESS STEELS
1108 Boiler Grade DMV 304 HCu
1109 Boiler Grade DMV 310 N
1110 Boiler Grade DMV 347 HFG
1111 Bohler: WELDING CONSUMABLES FOR STEEL CONSTRUCTION
1112 SVETSAREN: The ESAB welding and cutting journal vol. 60 No.2: 2005
1113 Thermal fatigue in carbon fibre polymer-matrix composites* monitored in real time by electrical resistance measurements
1114 Tooling solutions for advanced high strength steels
1115 FIRESIDE CORROSION RESISTANCE OF PROPOSED USC SUPERHEATER AND REHEATER MATERIALS: LABORATORY AND FIELD TEST RESULTS
1116 Effects of fuel composition and temperature on fireside corrosion resistance of materials for advanced ultrasupercritical coal fired power plants
1117 REPARATION OF THE DAMAGED FORGING HAMMER MALLET BY HARD FACING AND WELD CLADDING
1118 ESTIMATE OF A POWER DISTRIBUTOR LIFE SPAN BASED ON THE FRACTURE MECHANICS CRITERIA
1119 ULTRASONIC TESTING OF STEEL CASTINGS
1120 HIGH STRENGTH SHEET AND PLATE STEELS FOR OPTIMUM STRUCTURAL PERFORMANCE
1121 CREEP RESISTANCE OF MICROSTRUCTURE OF WELDS OF CREEP RESISTANT STEELS
1122 Weldability of Stainless Steel
1123 Weldox: Static strength in joints of Weldox grades
1124 Predictive and Measurement Methods for Delta Ferrite Determination in Stainless Steels
1125 The weldability of steel
1126 ESAB: Submerged Arc Welding handbook
1127 Effects of contents of Nb and C on hot deformation behaviors of high Nb X80 pipeline steels
1128 EFFECT OF NIOBIUM AND VANADIUM AS AN ALLOYINGELEMENT IN TOOL STEELSWITH HIGH CHROMIUM CONTENT
1129 FATIGUE PROPERTIES OF GALVANIZED HIGHER-STRENGTH STEEL SHEETS
1130 THE EFFECT OF SMALL ADDITIONS OF NIOBIUM OH THE WELDING BEHAVIOR OF AN AUSTENITIC STAINLESS STEEL
1131 Joints In Steel Construction: Moment connections
1132 Steel buildings
1133 Why do we Need to Measure Trace Elements in Steel?
1134 Welder level B: Program outline
1135 Welder level C: Program outline
1136 Guide on the CE Marking of Structural Steelwork
1137 INFLUENCE OF RESIDUAL ELEMENTS ON STEEL PROCESSING AND MECHANICAL PROPERTIES
1138 BCSA code of practice for metal decking and stud welding
1139 *****s in steel structures
1140 Niobium in Microalloyed Structural & Engineering Steel
1141 Continuous Cooling Transformation Temperatures and Microstructures of Niobium Bearing Microalloyed Steels
1142 Joints in steel construction: Simple connections
1143 THE EFFECT OF NIOBIUM ADDITIONS ON FERRITE FORMATION IN CASTRIP® STEEL
1144 Guide to site welding
1145 THE ROLE OF NIOBIUM IN MULTI-PHASE STEEL
1146 Typical welding procedure specifications for structural steelwork
1147 WELDING OPTIONS IN STEEL CONSTRUCTION
1148 High temperature stainless steels
1149 DNV: Non-destructive Testing
1150 Martensitic-phase steel MS-W
link:
