251 EPRI: Fan Repair Guideline
252 EPRI: Welding Best Practices Manual for High-Risk/High-Value Repairs
253 EPRI: PWHT Exemptions for Low Hardenability Materials
254 EPRI: Ultrasonic Testing (UT) of Dissimilar Metal Welds (DSM) Training
255 EPRI: GTAW Flux-Cored Wires for Open Root SS Welding
256 EPRI: Reinstatement of Post-Weld Heat Treatment (PWHT) Exemptions for P Nos. 4 and 5A Socket Welds
257 EPRI: Temperbead Repair Welding of Grade 91 Material
258 EPRI: Evaluation of Filler Materials for Transition Weld Joints Between Grade 91 to Grade 22 Components
259 EPRI: Effect of Cold Work and Heat Treatment on the Elevated-Temperature Rupture
Properties of Grade 91 Material
260 EPRI: Investigation of Thickness Limits for Post Weld Heat Treatment (PWHT) Exemption
261 EPRI: NDE Training Activities
262 EPRI: Materials Handbook for Nuclear Repair Applications
263 EPRI: Status Review of Initiation of Environmentally Assisted *****ing and Short ***** Growth
264 EPRI: Materials Reliability Program: Selection of Materials and Fabrication of Weldments
for Investigation of PWSCC Susceptibility in the Alloy 600 and 690 Weld Heat Affected Zones (MRP-161)
265 EPRI: Flue Gas Desulfurization Systems Component Material Performance and Welding
266 EPRI: Investigation of Thickness Limits for Post Weld Heat Treatment (PWHT) Exemption
267 EPRI: Dissimilar Metal Weld Configuration Management Database
268 EPRI: Materials Reliability Program: Technical Basis for Preemptive Weld Overlays for
Alloy 82/182 Butt Welds in PWRs (MRP-169)
269 EPRI: Topical Report Supporting an Expedited NRC Review of the Content of the Code Case needed for Dissimilar Metal Weld Overlay Repairs
270 EPRI: Stress Corrosion *****ing of Grade 91 Materials
271 EPRI: Repair and Replacement Applications Center: Investigation of Thickness Limits for Post Weld Heat Treatment (PWHT) Exemption
272 EPRI: Repair and Replacement Applications Center: Stress Corrosion *****ing in Closed Cooling Water Systems
273 EPRI: Repair and Replacement Applications Center: Topical Report Supporting Expedited NRC Review of Code Cases for Dissimilar Metal Weld Overlay Repairs
274 EPRI: Nondestructive Evaluation: Dissimilar Metal Weld (DMW) Configuration Database
275 EPRI: Materials Reliability Program: Advanced FEA Evaluation of Growth of Postulated
Circumferential PWSCC Flaws in Pressurizer Nozzle Dissimilar Metal Welds (MRP-216)
276 EPRI: Materials Reliability Program: Advanced FEA Evaluation of Growth of Postulated Circumferential PWSCC Flaws in Pressurizer Nozzle Dissimilar Metal Welds (MRP-216* Rev. 1)
277 EPRI: Materials Reliability Program: Inspection and Evaluation Guidelines for Reactor Vessel Bottom-Mounted Nozzles in U.S. PWR Plants (MRP-206)
278 EPRI: Hexavalent Chromium Air Sampling Data from Welding and Steel Cutting
279 EPRI: Nondestructive Evaluation: Guideline for Conducting Ultrasonic Examinations of Dissimilar Metal Welds
280 EPRI: Development of a New Nickel Filler for Dissimilar Metal Welds and Repair
281 EPRI: Welding and Repair Technology Center: Evaluation of Post Weld Heat Treatment (PWHT)
Exemption Thickness Limitations
282 EPRI: Repair Methods for Dissimilar Metal Welds— Development* Weldability* and Properties of EPRI P87 Solid Wire Filler Metal
283 EPRI: Materials Reliability Program: Technical Basis for Preemptive Weld Overlay for Alloy 82/182 Butt Welds in Pressurized Water Reactors (PWRs) (MRP-169) Revision 1-A
284 EPRI: Materials Reliability Program: Welding Residual Stress Dissimilar Metal Butt-Weld
Finite Element Modeling Handbook (MRP-317)
285 EPRI: Guidelines and Specifications for High-Reliability Fossil Power Plants Best Practice Guideline for Manufacturing and Construction of Grade 91 Steel Components
286 EPRI: Relationship Between Alloy Chemistry* Hardenability* and Creep Behavior of Code Case 2199 (T23)
287 EPRI: Materials Reliability Program: PWR Reactor Coolant System Cold-Loop Dissimilar Metal Butt Weld Reexamination Interval Extension (MRP-349)
288 A challenging weld repair of Grade 91 tubing by avoiding PWHT
289 EPRI: Dissimilar-weld failure analysis and development program Volume 8: Design and procedure guide for improved welds
290 EPRI: Ambient temperature preheat for machine GTAW temperbead applications
291 EPRI: Proceedings: 1983 workshop on secondary-side stress corrosion *****ing and intergranular corrosion of PWR steam generator tubing
292 EPRI: Proceedings: 1986 workshop on advanced high-strenght materials
293 EPRI: NOREM Wear-resistant* iron-baced hard-facing alloys
294 EPRI: Cobalt reduction guidelines
295 EPRI: Inconel weld-overlay repair for low-alloy steel nozzle to safe-end joint
296 EPRI: Underwater Maintenance Guide: Revision 2
297 EPRI: Welding best practices survey
298 EPRI: SMAW temperbead weld repair without grinding
299 EPRI: New materials for advanced steam turbines Volume 5: Survey of superalloy bolt failures in high-temperature services
300 EPRI: Supplemental Guidance for the Application of EPRI Report NP-5652 on the Utilization of
Commercial Grade Items
