151 Metalurgija 49:2
152 Metalurgija 49:3
153 Metalurgija 49:4
154 Metalurgija 50:1
155 Metalurgija 50:2
156 Metalurgija 50:3
157 Metalurgija 50:4
158 Metalurgija 51:1
159 Metalurgija 51:2
160 Metalurgija 51:3
161 Metalurgija 51:4
162 Metalurgija 52:1
163 Metalurgija 52:2
164 Metalurgija 52:3
165 Metrode Welding Consumables Newsletter Summer 2010
166 Lincoln: STT
167 Lincoln: STT
168 Creep characterization of Boron added P91 steel in the temperature range 600-6500C
169 RECENT DEVELOPMENTS IN WELDING CONSUMABLES FOR P(T)-91 CREEP RESISTING STEELS
170 EsbjergUnit 3-Investigation of AdvancedMaterialsat Steam Temperaturesup to 720 °C
171 Invertec® STT® II
172 Update on Fireside Corrosion Resistance of Advanced Materials for Ultra-Supercritical Coal-Fired Power Plants
173 Australiran Welding Institute: STT
174 Materials for Ultra Supercritical Fossil Power Plants
175 LOAD & RESISTANCE FACTOR DESIGN Volume I Structural Members* Specification
176 AWS: Toxicity of welding fume in rats
177 Handbook of Corrosion Engineering *Pierre R. Roberge
178 New Generation Strategy Ultra-Supercritical Technology
179 THE MECHANICAL PROPERTIES AND MICROSTRUCTURES OF 9% CHROMIUM STEEL P92 WELDMENTS
180 CREEP RESISTANCE OF WELD JOINT OF TUBE MADE OF P92 STEEL
181 Modified 9% Cr steels for advanced power generation: microstructure and properties
182 Creep Strength of Ferritic/Martensitic Steel P92 in Oxygen-Containing Lead at 650°C
183 EPRI: Repair Methods for Dissimilar Metal Welds— Development* Weldability* and Properties of EPRI P87 Solid Wire Filler Metal
184 PHASE TRANSFORMATIONS IN CREEP STRENGTH ENHANCED FERRITIC STEEL WELDS
185 LONG-TERM AGING EFFECT ON THE CREEP STRENGTH OF THE T92 STEEL
186 Application of High Steam Temperature Countermeasures in High Sulfur Coal- Fired Boilers
187 Advanced Material Castings for High Temperature Coal Fired Steam Turbine Applications
188 PROPERTIES OF T/P92 STEELWELD METALS FOR ULTRA SUPER CRTITICAL (USC) POWER PLANT
189 P92 WELDING CONSUMABLES FOR THE POWER GENERATION INDUSTRY
190 ADVANCED PRESSURE BOUNDARY MATERIALS
191 Experiences with Zeron 100 superduplex stainless steel in the process industries
192 REGULATORY GUIDE OFFICE OF NUCLEAR REGULATORY RESEARCH REGULATORY GUIDE 1.71 (Draft was issued as DG-1167* dated October 2006) WELDER QUALIFICATION FOR AREAS OF LIMITED ACCESSIBILITY A. INTRODUCTION
193 Welding Metallurgy 2 - ppt
194 Weldability and defects in weldments
195 Weld imperfections and preventive measures
196 How to weld duplex stainless steels
197 BPV #4 – Temper Bead Qualification Hardness Acceptance Criteria
198 Microstructural parameter controlling weld metal cold *****ing
199 Stress corrosion *****ing of different duplex stainless steel grades in pulping liquor
200 stainless steels and their properties
link:
