301 EPRI: Temperbead welding repair of low alloy pressure vessel steels: Guidelines
302 EPRI: Review of steam generator girth weld *****ing
303 EPRI: State-of-the-art weld repair technology for high temperature and pressure parts Volume 2: Repair guideline
304 EPRI: State-of-the-art weld repair technology for high temperature and pressure parts Volume 5: Weld repair of 1-1/4 Cr-1/2 Mo piping girth welds
305 EPRI: State-of-the-art weld repair technology for high temperature and pressure parts Volume 7: Weld repair of aged piping-A literature review
306 EPRI: Steam Generator Reference Book
307 EPRI: Valve Application* Maintenance and Repair Guide (In Situ State-of-the-Art Valve Welding Repair)
308 EPRI: State-of-the-Art Weld Repair Technology for Rotating Components Volume 1: Weld Repair of Steam Turbine Discs and Rotors
309 EPRI: Proceedings: Welding and repair technology for power plants – Second international conference
310 EPRI: On-Line Welding Repair for Leaking Pipe Components
311 EPRI: Guideline for underwater welding to achieve acceptable ferrite bumber (FN) for stainless steel
312 EPRI: Machine Welding Equipment for In Situ Piping Installation and Repairs
313 EPRI: Influence of Irradiation and Stress/Strain on the In-Reactor Behavior of High Purity Stainless Steels & Ni-Based Alloys
314 Turbine Steam Path Damage: Theory and Practice Volume 1: Turbine Fundamentals
315 EPRI: Weld overlay of waterwall tubing* alternative materials and distortion
316 EPRI: 1998 Repair & Replacement Applications Center – Product Report
317 EPRI: Non-Destructive Evaluation of the Oyster Creek Top Guide Samples
318 EPRI: Vibration fatigue testing of socket welds
319 EPRI: Welding and repair technology for power plants
320 Appendix C: Field testing of pipelines
321 Improving the Inspectability of Stainless Steel and Dissimilar Metal Welded Joints Using Inverse Phase-Matching of Phased Array Time-Domain Signals
322 NEW TIE-IN TECHNOLOGY FOR PIPELINE CONSTRUCTION
323 CE470 Lecture 15:Welds
324 CHAPTER 6. WELDED CONNECTIONS
325 CONDITIONS LEADING TO QUENCH *****ING OTHER THAN SEVERITY OF QUENCH
326 Example Of Cost Calculation In Welding
327 ESAB: Welding Filler Metal Data Book February 2012
328 Experiment: Heat Treatment - Quenching & Tempering
329 Principles and practices of stud welding
330 Fillet Weld Legs Determine Size and Throat of Fillet Welds
331 Steel tube and pipe manufacturing processes
332 A Guide to Estimating the Consumption of Welding Consumables
333 ESAB: STORAGE AND HANDLING RECOMMENDATIONS FOR THE STORAGE* REDRYING AND HANDLING OF ESAB COVERED ELECTRODES.
334 GUIDELINES FOR THE EVALUATION OF UNDERGROUND STORAGE TANK CATHODIC PROTECTION SYSTEMS
335 Fatigue design of welded joints and components
336 Fatigue design procedure for welded hollow section joints
337 The science and practice of welding Volume 1 Welding science and technology
338 The science and practice of welding Volume 2 The practice of welding
339 IIW recommandations on methods for improving the fatigue strenght of welded joints
340 Design of welded structures
341 22 possible causes of weld metal porosity
342 Lloyd's register welding procedure & welder qualification review
343 Welding and weld inspection
344 Increasing P91 Welding Productivity with FCAW
345 Review of Current Practice for Welding of Grade 92
346 Oerlikon compentence # 4
347 EWF Guideline Dedicated Knowledge for Personnel with the Responsibility for Welding Coordination to comply with EN 1090-2
348 Dratec catalogue
349 Kjellberg finsterwalde: Schweisselektroden
350 Tess: Flux cored wire high alloyed
