continuing....
51 Study of the microstructure of the Grade 91 steel after more than 100*000h of creep exposure at 600°C*
52 Dissimilar Metal Welds by Karl E. Dawson
53 OPERATIONAL GUIDELINES AND CODE OF PRACTICE FOR STAINLESS STEEL PRODUCTS IN DRINKING WATER SUPPLY
54 Plasma Arc Welding of Modified 12%Cr Stainless Steel
55 Austenitic Stainless Steels and Alloys With Improved High-Temperature Performance for Advanced Microturbine Recuperators
56 Guidelines for welding dissimilar welds
57 Kobelco welding handbook 2009
58 Properties of matching filler metals for T91/P91
59 The Low Temperature Fracture Behaviour of the Super Duplex Stainless Steel Zeron 100
60 DISSIMILAR METAL WELDS AND WELD JOINT DESIGN FOR DUPLEX STAINLESS STEELS
61 Advanced Austenitic Heat-Resistant Steels for Ultra-Super-Critical (USC) Fossil Power Plants
62 Evaluation of the Shielding Gas Influence on the Weldability of Ferritic Stainless Steel
63 Heat-Resistant Steels* Microstructure Evolution and Life Assessment in Power Plants
64 Welding and Joining of Magnesium Alloys
65 Kobelco welding today Vol. 12 No. 1 2009
66 Hyundai Welding Consumables: MIG/TIG ARC WELDING FOR STAINLESS STEELS & CARBON STEELS
67 Development of 590N/mm2 Steel with Good Weldability for Building Structures
68 Weld Metals for P91 – Tough Enough?
69 Recent advances in creep-resistant steels for power plant applications
70 A small survey of exposure to stainless steel welding fume
71 ECCC RECOMMENDATIONS - VOLUME 6 [Issue 1] Residual Life Assessment and Microstructure
72 HIGH TEMPERATURE BEHAVIOUR OF SIMILAR AND DISSIMILAR WELDED COMPONENTS OF STEEL GRADE P22 AND P91
73 Effect of Composition Profiles on Metallurgy and Corrosion Behavior of Duplex Stainless Steel Weld Metals - Diluting the nitrogen content of the austenite with increased nickel appears to degrade the weld pitting corrosion property
74 Controlling Heat Treatment of Welded P91
75 Evaluation of Dissimilar Welds between Ferritic Stainless Steel Modified 12% Cr and Carbon Steel S355
76 Howard B.Cary – Arc Welding Automation
77 A challenging weld repair of Grade 91 tubing by avoiding PWHT
78 Creep Damage and Expected Creep Life for Welded 9-11%Cr Steels
79 EPRI: Effect of Normalization and Temper Heat Treatment on P91 Weldment Properties
80 EPRI: Guideline for Welding Creep Strength-Enhanced Ferritic Alloys
81 EPRI: Optimal Hardness of P91 Weldments
82 EPRI: Evaluation of Filler Materials for Transition Weld Joints Between Grade 91 to Grade 22 Components
83 Guideline for Welding P(T) 91
84 HIGH TEMPERATURE BEHAVIOUR OF SIMILAR AND DISSIMILAR WELDED COMPONENTS OF STEEL GRADE P22 AND P91
85 Hitachi power welding guidelines
86 P91 and Beyond
87 Growing experience with P91/T91 forcing essential code changes
88 Performance of P91 Weldments Under Steady And Cyclic Load Conditions And Directions For Future Research
89 Welding “Grade 91” Alloy Steel
90 Welding and Postweld Heat Treatment of P91 Steels
91 A simulation of fatigue ***** propagation in a welded T-joint using 3D boundary element method
92 The embrittlement of a duplex stainless steel by hydrogen in a variety of environments
93 The science and practice of welding Volume 1 Welding science and technology
94 Pipefitter's & Welder's Pocket Manual – All new 2nd edition
95 Intelligentized methodology for arc welding dynamical process
96 EPRI: Boiler Condition Assessment Guideline
97 Hybrid laser–arc welding
98 Corrosion of austenitic stainless steels: Mechanism* mitigation and monitoring
99 Materials and processes for NDT technology
100 THE DISTRIBUTION OF STRESSES IN WELDED AND RIVETED CONNECTIONS
link:
