Thread: 50 X 50 Welding Literature ... # 01
    just digging through my old documents* for the beginning* so I will share here books* artciles etc. about welding
    1 Welding Robots Technology* SystemIssues and Applications
    2 Welding of aluminium and it's alloys
    3 DIN/DVS Handbook 8
    4 DIN/DVS Handbook 191
    5 Welding inspector CSWIP 3.1
    6 DOCUMENT NO. CSWIP-DIV-8-96 Requirements for the Certification of Personnel engaged in the ACFM Inspection of Welds – Levels 1* 2 and 3
    7 TWI-Welding inspection:Steels
    8 TWI-Welding inspection:Steels – Notes & Questions
    9 TWI – Welding Inspection duties & responsibilies
    10 TWI WIS 5 Course WELDING INSPECTION of STEELS
    11 Welding journal February 2010
    12 WRC 329
    13 Workshop processes* practices & materials
    14 Manuals de systemas y materiales de soldadura
    15 Handbook of Welded Carbon Steel Mechanical Tubing
    16 The New Standards on Digital Industrial Radiology ISO 16371 to replace EN 14784 *ISO 17636 to replace EN 1435
    17 The Welding Handbook for maritime welders
    18 WELDING METALLURGY SECOND EDITION Sindo Kou
    19 CWB: Welding Procedure Guide
    20 INFLUENCE OF WELDING PHYSICAL CONDITIONS ON WATERPROOFING MEMBRANE
    WELD QUALITY
    21 TECHNICAL MANUAL WELDING DESIGN* PROCEDURES AND INSPECTION
    22 Welding pipeline handbook
    23 Welding metallurgy & weldability of stainless steel
    24 NAVAL SHIPS’ TECHNICAL MANUAL CHAPTER 074 - VOLUME 1 WELDING AND ALLIED PROCESSES
    25 Spirally welded steel pipes
    26 INTERNATIONAL INDEX OF WELDING FILLER METAL CLASSIFICATIONS
    27 Welding practice for the Sandvik duplex stainless steels SAF 2304* SAF 2205 and SAF 2507
    28 Fundamentals of evaluation and diagnostics of welded structures
    29 Welding for design engineers
    30 Practical guidelines for the fabrication of duplex stainless steels
    31 Sumberged Arc Welding Of Thick Ferritic martensitic 12Cr stainless steel with a variety of comsumables
    32 WELDING OF FERRITIC AND MARTENSITIC 11-14%Cr STEELS
    33 EFFECT OF WELDING ON THE FRACTURE BEHAVIOUR OF THE FERRITIC CORROSIONRESISTANT
    STEEL
    34 Increasing P91 Welding Productivity with FCAW
    35 SIMILAR AND DISSIMILAR WELD JOINTS OF CREEP-RESISTING STEELS
    36 Gas metal arc welding of modified X2CrNi12 ferritic stainless steel
    37 Effect of Postweld Heat Treatment on Microstructures and Hardness of TIG Weldment between P22 and P91 Steels with Inconel 625 Filler Metal
    38 CREEP FAILURE CHARACTERISTICS IN P23/P91 DISSIMILAR WELDS
    39 REDISTRIBUTION OF CARBON AND NITROGEN IN HETEROGENEOUS WELD JOINTS OF CREEP-RESISTANT STEELS (P91/P22)
    40 MICROSTRUCTURAL FEATURES OF AISI 430 FERRITIC STAINLESS STEEL (FSS) WELD PRODUCED UNDER VARYING PROCESS PARAMETERS
    41 Welding imperfections of submerged arc welded duplex steel joints in aspects of the welding heat input
    42 Mechanical properties and corrosion resistance of dissimilar stainless steel welds
    43 Ferritic-austenitic steel and its weldability in large size constructions
    44 Embrittlement of Austenitic Stainless Steel Welds
    45 Structural Dynamic Analysis and Model Updating for a Welded Structure made from Thin Steel Sheets
    46 Basic Understanding of Weld Corrosion
    47 SRP‟s Experience with P91 Piping
    48 Automatic Detection* Sizing and Characterisation of Weld Defects Using Ultrasonic Time-of-Flight Diffraction
    49 Hydrogen-Induced *****ing along the Fusion Boundary of Dissimilar Metal Welds
    50 Welding of High-Alloy Steels* Corrosion
    links:
    or
    Re: 50 X 50 Welding Literature ... # 01
    Many thanks
    Thank a lot indeed.
  6. Re: 50 X 50 Welding Literature ... # 01
    Thank you* sir.
  1. low alloy steel welding literature
    By ify09 in forum Mechanical Engineering
    Last Post: 03-25-2018, 06:43 PM
  2. WeldShop - Free Welding Software for Piping Welding (Carbon & Low Alloy Steel)
    By ashfaqanwer in forum Materials Science &Corrosion
    Last Post: 01-27-2014, 08:50 AM
  3. Replies: 0
    Last Post: 01-24-2011, 03:16 PM
  4. Replies: 0
    Last Post: 04-30-2010, 02:36 PM
