201 Gas Tungsten Arc Welding (GTAW)
202 Classification of Steels* Welding of Mild Steels
203 Cold *****ing
204 Exploring temper bead welding
205 Guide to stainless steel finishes
206 Welding issues: Hydrogen *****ing - Cold *****s (Hydrogen embrittlemet)
207 Microstructure Development of Ultra-High Strength Steel Weld Metal for Avoiding Hot and Cold *****ing
208 WELDING HEAVY STRUCTURAL STEEL—SUCCESSFULLY
209 CONTROL OF STAINLESS STEEL WELDING
210 CONTROL OF FERRITE CONTENT IN STAINLESS STEEL WELD METAL
211 Control of stainless steel weld cladding of low-alloy steel components
212 Preheating in Welding Technology
213 Cold *****s: Causes and Cures
214 QUANTITATIVE EVALUATION OF HYDROGEN INDUCED COLD *****ING IN WELDED JOINTS
215 Reference photo guide for stainless steel welds
216 Chloride stress corrosion *****ing in austenitic stainless steel
217 Resistance Welding Manual
218 Stainless Steel ‘An Introduction & guide to Welding’
219 Cogne 304 HT 650 as Stainless Steel Reinforcement
220 Temper Bead Welding
221 Welding Austenitic Manganese Steel Rail
222 OCCURRENCE OF COLD *****S IN WELDING OF HIGH-STRENGTH S960 QL STEEL
223 Weld *****ing: An excerpt from the fabricators' and erectors' guide to welded steel construction
224 Weld *****s – An Engineer’s Worst Nightmare
225 Welding practice for the Sandvik duplex stainless steels SAF 2304* SAF 2205 and SAF 2507
226 ROLLED ALLOYS WELDING RA330®
227 WELDING GUIDE FOR HENSLEY PRODUCTS
228 WELDING OF STAINLESS STEELS AND OTHER JOINING METHODS
229 Welding of Austenitic & Duplex Stainless Steels - Overview
230 WELDING OPTIONS IN STEEL CONSTRUCTION
231 Determination of Necessary Preheating Temperature in Steel Welding
232 A Prediction Diagram For Preventing Hydrogen-Assisted *****ing in Weld Metal
233 A New Chromium-Free Welding Consumable for Joining Austenitic Stainless Steels
234 EPRI: Weld overlay of waterwall tubing* alternative filler
235 EPRI: The use of weld overlays to extend the usefull life of seam welded high energy piping in fossil power plants
236 EPRI: P-No. 4 and P-No. 5A Temperbead Repair Using the Flux-Cored Arc Welding (FCAW) Process
237 EPRI: Evaluation of solid wire advanced GMAW for heavy section and piping replacement
238 EPRI: Guide for repair of thinned piping
239 EPRI: Advanced GMAW process for pipe welding applications
240 EPRI: Repair of metal bellows
241 EPRI: Tack welding guidelines
242 EPRI: Development of Advanced Methods for Joining Low-Alloy Steels
243 EPRI: The Use of Weld Overlays to Extend the Life of Seam Welded High Energy Piping in Fossil Power Plants
244 EPRI: Optimal Hardness of P91 Weldments
245 EPRI: Effects of Cold Work and Heat Treatment on the Elevated Temperature Rupture
Properties of Grade 91 Material
246 EPRI: Effect of Normalization and Temper Heat Treatment on P91 Weldment Properties
247 EPRI: New Steels for Advanced Power Plants II Phase 2: Development of Advanced 9-12 Cr Steels for Thick Section Boiler Applications
248 EPRI: EPRI Conference on 9Cr Materials Fabrication and Joining Technologies
249 EPRI: Productivity Improvement Handbook for Fossil Steam Power Plants: Third Edition
250 EPRI: Conference Proceedings: EPRI-RRAC Fifth International Conference on Welding and Repair Technology for Power Plants
link:
