851 MEASUREMENT OF RESIDUAL STRESS DISTRIBUTION IN TUBULAR JOINTS CONSIDERING POST WELD HEAT TREATMENT
852 MSC February 2011
853 Pressure vessels and stacks: Field repair manual
854 Z-phase strengthened Martensitic 9-12%Cr steels
855 Laser welding
856 Radiography book
857 RT calculations
858 Radiography in Modern Industry
859 Textbook of engineering drawing
860 Welding symbols on drawings
861 CSWIP 3 WIS 10: Senio welding inspection 2010
862 Guide to Low-Emission Boiler and Combustion Equipment Selection
863 BOILER TROUBLE SHOOTING GUIDE
864 ECCC DATA SHEETS 2005
865 Pressure vessel design: The direct route
866 TWI: Assured High Integrity and Productivity for Thick Section Fabrications
867 Practical guide to pressure vessel manufacturing
868 PROCEDURE FOR CALIBRATION OF MACHINES WELDING
869 Steel designers' hanbook
870 Stress corrosion *****ing of metals- A state of the art
871 TWI: Guide to weld symbols for senior welding inspectors CSWIP 3.2
872 TWI: Senior welding inspector 1991
873 API 510: Training course 2006
874 API 510 Study questions
875 Toughness and ductility of high strenght steels welded joints
876 ON LINE MONITORING FOR DEFECTS IN ELECTRIC ARC STUD WELDING
877 EDDY CURRENT INSPECTION IN PROCESSING FURNACE REMAINING LIFE PREDICTION
878 Welding: Processes* quality and applications
879 ASNT: Level 3 – Study guide basics
880 ASNT Level II Study Guide Liquid Penetrant Testing Method
881 ASNT Level II Study Guide Magnetical particle testing Method
882 ASNT Level II Study Guide ultrasonic testing Method
883 ASNT Level III Study Guide Magnetical particle testing Method
884 ASNT Level III Study Guide Liquid Penetrant Testing Method
885 ASNT Level III Study Guide Radiographic method
886 ASNT Level III Study Guide ultrasonic testing Method
887 Corrosion control checklist
888 Heat treaters guide practices
889 Non Destructive Testing handbook vol.8: Visual and optical testing
890 Service Experience for Grade 91 Steel in Boilers and Piping
891 Lincoln: The procedure handbook of arc welding
892 Visual inspection worksheet spring 91
893 CWB: Canadian welding bureau certificate programe modules
894 INSTRUCTION OF WELDING AND REVIEW OF STEELS FOR POWER PLANT EQUIPMENT AND POSSIBILITY OF USING HAZ SIMULATION IN ORDER IMPROVE WELD JOINT QUALITY
895 Metallographer’s Guide Practices and Procedures for Irons and Steels
896 Compressor handbook: Principles and practice
897 Buried pipe design – 3rd edition
898 Strengthening The ability of a metal to deform depends on the ability of dislocations to move
899 Companion guide to the ASME vol 1: Boiler and pressure vessel code
900 D I M E N S I O N S & P R O P E R T I E S H A N D B O O K ed. 2007
