451 EWE 2003
452 Welding skills* processes and practices for entry-level welders – book 1
453 Welding skills* processes and practices for entry-level welders – book 2
454 Welding skills* processes and practices for entry-level welders – book 3
455 Theory and design of pressure vessels
456 Welding CrMo steels for power generation and petrochemical applications - past* present and future
457 ANALYSIS OF PROBLEMS OCCURED DURING WELDING OF NEW GENREATION BAINITIC STEEL 7CrMoVTiB10-10 (T24)
458 EVALUATION OF MICROSTRUCTURAL STABILITY OF CREEP-RESISTANT STEELS WELD JOINTS ON THE BASIS OF A COMPUTATIONAL MODELING
459 Material properties and structure of thick-walled elements made of steel 7CrMoVTiB10-10 after long-term annealing
460 Dissimilar Metal Welds
461 Advanced Material Castings for High Temperature Coal Fired Steam Turbine Applications
462 Welding of T24* lessons learned
463 Creep properties and damage behaviour of component-like tubes of Vm12-materials
464 PIPELINE RULESOFTHUMB H A N D B O O K A Manual of Quick* Accurate Solutions to Everyday Pipeline Engineering Problems
465 Welding of T24* P92 and VM12-SHC
466 Welding solutions for thermal power generation
467 EWF Guideline EUROPEAN WELDING PRACTITIONER FOR RESISTANCE WELDING–Short Version
468 Welding CrMo steels for power generation and petrochemical applications
469 Schweisstechnische Verarbeitung neuer Kraftwerkstahle
470 Schweißen von Edelstahl Rostfrei
471 Tess: Welding filler metals for power plant engineering
472 Kobelco: CR-12S & TG-S12CRS
473 CREEP RESISTANT FERRITIC STEELS FOR POWER PLANTS
474 Heat resisting steels of the new generation
475 EWE 2000
476 WeldOffice manual
477 Functions of the alloying elements in steel
478 NAVAL CONSTRUCTION FORCE WELDING MATERIALS HANDBOOK
479 Pipeline repair
480 WELDING DESIGN* PROCEDURES AND INSPECTION
481 Lincoln: Arc welding basics
482 IWE 2005
483 Materials handbook 15th edition
484 Real-time weld process monitoring
485 Boilers and burners: Design and theory
486 TWI: Welding inspection* macro sectional * practical
487 VDI:Warmeatlas
488 Requirements concerning materials and welding
489 Welded joint design 3rd edition
490 Weld Overlay Examination Using Ultrasonic Phased Array Technology
491 Alloy design for similar and dissimilar welding and their behaviours
492 Significance and control of lamellar tearing of steel plate in the shipbuilding industry
493 Hitachi: Boiler Design of innovative 600 °C- and 700 °C- Power Plants
494 Danish power utilities : General conditions for welding on pipe systems DKF 2002
495 Design of process equipment
496 Engineering mechanics: Statics – 12th edition
497 Engineers’ Guide to Pressure Equipment
498 Handbook of mechanical works inspection
499 MATERIAL ASPECTS OF A 700°C - POWER PLANT
500 Mechanical Design of Process Systems Volumel Piping and Pressure Vessels
