501 Mechanical Design of Process Systems Volume2 Shell-and-Tube Heat Exchangers Rotating Equipment Bins* Silos* Stacks
502 Mechanical Design: An integrated approach
503 Experienced filler metals for increasing power plant efficiency
504 Hitachi’s Activities for Suppression of Stress Corrosion *****ing
505 T23* T24 and VM 12 - Structure* Properties* Application
506 Danish power utilities general conditions for welding on pipe systems
507 VDI-Warmeatlas – 10th edition
508 THE ANALYSIS OF STRESS AND DEFORMATION
509 LARGE EDDY SIMULATION BASED TURBULENT FLOW-INDUCED VIBRATION OF FULLY DEVELOPED PIPE FLOW
510 CSWIP: Requirements for the Certification of Personnel engaged in the ACFM Inspection of Welds – Levels 1* 2 and 3
511 TWI: Radiographic interpretation
512 TWI: Welding Inspection Defects/Repairs
513 The welding of aluminium and its alloys
514 NDT data fusion
515 Nondestructive Test Methods for Evaluation of Concrete in Structures
516 Microstructural Evolution at the Bonding Interface during the Early-Stage Infrared Active Brazing of Alumina
517 Brazing of Hot Isostatically Pressed–Al2O3 to Stainless Steel (AISI 304L) by Mo-Mn Route Using 72Ag-28Cu Braze
518 Joining of AlN with metals and alloys
519 Bonding of zirconia to super alloy with the active brazing technique
520 Fabrication and thermal properties of a YSZ–NiCr joint with an interlayer of YSZ–NiCr functionally graded material
521 Joining of partially sintered alumina to alumina* titanium* Hastealloy and C–SiC composite using Ag–Cu brazes
522 Joining mechanism in Si3N4 bonded with a Ni–Cr–B interlayer
523 Effects of Adhesive Composition on Bond Strength of Joined Silicon Nitride Ceramics
524 The Brazing of S&N4 with Ni-Cr-Si Alloys
525 Interfacial microstructure of the Si3N4/Si3N4 joint brazed with Cu–Pd–Ti filler alloy
526 Reactive Brazing Study of a Silicon Nitride to Metal Joining
527 Joining of Si3N4 to Si3N4 using rapidly-solidified CuNiTiB brazing filler foils
528 Vacuum brazing of SiO2 glass ceramic and Ti–6Al–4V alloy using AgCuTi filler foil
529 Mechanical property of induction brazing TiAl-based intermetallics to steel 35CrMo using AgCuTi filler metal
530 Distribution and Chemistry of Phases Developed in the Brazing of Silicon Nitride to Molybdenum
531 NDT and Evaluation of Steel Structures
532 Wetting and reaction between beta-sialon* stainless steel and Cu-Ag brazing alloys containing Ti
533 Effects of Welding Parameters and Electrode Atmospheric Exposure on the Diffusible Hydrogen Content of Gas Shielded Flux Cored Arc Welds
534 Welding by mister Jalopy
535 MIG Welding Tips
536 NDT and eddy current testing 2003
537 Report about NDT of materials
538 DUPLEX STAINLESS STEEL (2205) UNS (31803) ASTM-A-790 NDT TESTING & DT TESTING (Before & After Welding)
539 ASNT: NDT training program: Ultrasonic method
540 Nondestructive test methods
541 Safety in gas welding* cutting and similiar processes
542 Study of SiC–nickel alloy bonding for high temperature applications
543 Soldering and brazing
544 Soldering* brazing & welding: A manual of techniques
545 Building a Two-Kilowatt Spot-Welding Set
546 Interface structure and mechanical properties of the brazed joint of TiC cermet and steel
547 Welders risk ear damage from hot slag
548 How To Weld and Cut Steel
549 NDT seminar
550 Casti handbook: Cladding technology
once again* I only doing 50 X 50 of uploading my older files considering mostly about welding (and allied processes)* so..if some files are doubled...don't mind me
