1051 Welding Procedure Guide
1052 WELDING GUIDELINES ZERON® 100
1053 Few ASNT handbooks
1054 Fatigue and thermal fatigue damage analysis of thin metal films
1055 Guidelins for application of high temperature dual seals
1056 Design of Creep Resistant Steel Welds
1057 Welding Hardox® and Weldox®
1058 SIMILAR AND DISSIMILAR WELD JOINTS OF CREEP-RESISTING STEELS
1059 EVALUATION OF MICROSTRUCTURAL STABILITY OF CREEP-RESISTANT STEELS WELD JOINTS ON THE BASIS OF A COMPUTATIONAL MODELING
1060 Fracture assessment procedure of API 5L gas pipe steels
1061 THE ROLE OF NIOBIUM IN AUSTENITIC AND DUPLEX STAINLESS STEELS
1062 Stress Intensity Factors for Elliptical Surface *****s in Round Bars and Residual Life Estimation
1063 New Stirling Engine Concept (NSC-Engine) with Application of Direct Heat Introduction
1064 Stainless steel for PWTP – Guidelines
1065 INSTRUCTION OF WELDING AND REVIEW OF STEELS FOR POWER PLANT EQUIPMENT AND POSSIBILITY OF USING HAZ SIMULATION IN ORDER IMPROVE WELD JOINT QUALITY
1066 STAINLESS STEELS WITH IMPROVED STRENGTH FOR SERVICE AT 760°C AND ABOVE*
1067 EPRI: Guidelines for the Nondestructive Examination of Boilers
1068 Sandvik Sanicro 25* A new material for ultrasupercritical coal fired boilers
1069 EPRI: Damage to Power Plants Due to Cycling
1070 EPRI: Guidelines for Piping System Reconciliation (NCIG-05* Revision 1)
1071 Aws-Welding-Defects-and-Discountinuties
1072 EPRI: Primary System Corrosion Research Progarm: EPRI Materials Degradation Matrix* Revision 2
1073 EPRI: State-of-the-Art Boiler Design for High Reliability Under Cycling Operation
1074 ASSESSING HYDROGEN ASSISTED *****ING MODES IN HIGH STRENGTH STEEL WELDS
1075 COAL-FIRED POWER MATERIALS
1076 Numerical and experimental investigation of laser beam welding of AISI 304 stainless steel sheet
1077 Applications of advanced low-alloy steels for new high-temperature components
1078 Advanced Materials for AD700 Boilers
1079 Welding of Martensitic Creep-Resistant Steels
1080 Advanced Power Plant Using High Efficiency Boiler/Turbine
1081 The welding of stainless steels
1082 STAINLESS STEELS properties • how to weld them • where to use them
1083 EXCEL IMPLEMENTATION OF SCHAEFFLER AND DELONG DIAGRAMS
1084 30 Years of Niobium Steel Development in China
1085 Welding of Domex MC cold-forming steels
1086 Welding Fumes – Update on EPRI Research Optimizing Local Exhaust Ventilation Multi-metals Welding Fume Data Base
1087 Electric Shock Prevention Project
1088 The Role of Alloying Elements on the Fabricability of Austenitic Stainless Steel
1089 Properties * Specifications and Experience of Welded Stainless Steel Pipes
1090 Review of Current Practice for Welding of Grade 92
1091 Rules for Classification and Construction II Materials and Welding
1092 Structural Integrity Assessment of Pressure Vessels with Defect in Welded Joints
1093 Guidelines for the welded fabrication of nickel-containing stainless steels for corrosion resistant services
1094 Influence of Alloys
1095 A REVIEW ON EFFECT OF PREHEATING AND/OR POST WELD HEAT TREATMEMT (PWHT) ON
MECHANICAL BEHAVIOUR OF FERROUS METALS.
1096 Experimental Investigation for Welding Aspects of AISI 304 & 316 by Taguchi Technique for the Process of TIG & MIG Welding
1097 Integrated Design and Manufacturing of Welded Structures
1098 STAINLESS STEEL TUBING IN THE BIOTECHNOLOGY INDUSTRY
1099 Intergranular thermal fatigue damage evolution in SnAgCu lead-free solder
1100 fatigue management in boiling and pressurized water reactor coolant systems
link:
