1151 THE EFFECTS OF SURFACE TOPOGRAPHY AND LACK OF FUSION ON THE FATIGUE STRENGTH OF LASER HYBRID WELDS
1152 RESISTANCE SPOT WELDING OF MARTENSITIC STAINLESS STEEL (SS420) - PART I
1153 The high alloy precipitation hardening martensitic steels and their suitability for welding
1154 CREEP ***** GROWTH PROPERTIES OF WELDED JOINTS FOR HIGH Cr FERRITIC STEEL
1155 How to weld fully austenitic stainless steels
1156 Z-Phase formation in welded joints of high chromium ferritic steels after long-term creep
1157 An Introduction to Corrosion
1158 Effect of steel Alloying Elements
1159 Alloying Elements in Stainless Steel and Other Chromium-Containing Alloys
1160 Metallography of Welds
1161 Bending stainless steel tube – Design benefits in engineering and archiceture
1162 Welding Defects
1163 COMMON HF WELDING DEFECTS
1164 Stainless steel in contact with other metallic materials
1165 Weldability of high Cr and 1 % tungsten alloyed creep resistant martensitic steel
1166 FATIGUE ***** GROWTH RATE IN LOW △K RANGE ACCORDING TO THE MICROSTRUCTURE AND TEMPERATURE IN P122 ALLOY STEEL
1167 Practical guidelines for the fabrication of duplex stainless steels
1168 Practical guidelines for the fabrication of high performance austenitic stainless steels
1169 V&M's innovative constribution to meet the challenges of present and future conventional power plants
1170 ANALYSIS OF LACK OF FUSION IN WELDS AT WATER HEATERS
1171 Tempering of Martensite in Dual-Phase Steels and Its Effects on Softening Behavior
1172 Analysis of Ultrasonic Indications in Lack of Fusion Occurring in Welds
1173 Solidification *****ing in austenitic stainless steel welds
1174 Poster - Causes and Cures of Common Welding Troubles
1175 Stainless steels: Tables of fabrication parameters: Welding processes and filler metals – heat treatments – typicals and uses
1176 Titanium alloy guide
1177 Tungesten – the story of an indispensable metal
1178 Weld defects and quality control
1179 What is stainless steel?
1180 Improving Supermartensitic Stainless Steel Weld Metal Toughness
1181 Fundamentals of Manual Metal Arc (MMA) Welding
1182 The alloy tree
1183 The Steel Book
1184 AUTOMATIC PIPE WELDING
1185 Hardox: Welding of cutting edge to bucket and adapters to cutting edge
1186 OUTLINE OF FATIGUE OF WELDED JOINTS OR SIX WAYS OF COUNTERACTING FATIGUE
1187 Magnetic arc blow
1188 Avoidance of discontinuities in the joint
1189 Application and Upgrading of On-line Monitoring System for Measurement and Processing of Electric Signals at Arc Stud Welding Process
1190 Prepainted sheet steel for buildings
1191 Assessing the Benefits of Surface Tension Transfer® Welding to Industry
1192 GAS METAL ARC WELDING LESSON PLAN
1193 Cut cost calculation
1194 THE INFLUENCE OF RETAINED AUSTENITE ON precipitation hardening OF MARAGING STEEL
1195 INNOVATIONS IN ARC WELDING
1196 Wave Form Controlled Technology
1197 HARDFACING GUIDE
1198 Hardfacing and High Alloy Product Selection Guide
1199 50 HARDFACING TIPS
1200 FUME MINIMISATION GUIDELINES GUIDELINE 8: HARDFACING
link:
