401 Arsenic and Selenium Treatment Technology Summary for Power Plant Wastewaters
402 Results of the Independent Evaluation of ISCST3 and ISCPRIME
403 Evaluation of nonmagnetic generator retaining rings
404 Customization of the EPRI Artificial Neural Network Short-Term Load Forecaster (ANNSTLF) and User Support for the California Independent System Operator (CA-ISO)
405 Manual of estimating soil properties for foundation design
406 Guidelines for Prioritizing Inspections of Aging Plant Infrastructure
407 1991 EPRI Power Plant Pump Short Course and Symposium Reprint
408 Guidelines for determining design basis ground motions – Volume 2: Appendices for ground motion estimation
409 Advances in Materials Technology for Fossil Power Plants
410 Bolt Preload Stress for ANSI Raised-Face Flanges Using Spiral-Wound Gaskets
411 Lithium Ion Batteries for Electric Transportation: Costs and Markets
412 Consolidated Plant Maintenance Optimization Guideline For Fossil Power Plants
413 Cycle chemistry guidelines for fossil plants: Phospate continuum and caustic treatmant
414 Valve Application* Maintenance and Repair Guide (In Situ State-of-the-Art Valve Welding Repair) (Gate* Globe* & Check Valves)* Volume 2
415 Summary Report of Advanced IR NDE of Service Water Piping Systems
416 DESIGN MODIFICATIONS ON A MULTI-STAGE STEAM TURBINE ROTOR TO IMPROVE RELIABILITY
417 Valve Application* Maintenance* and Repair Guide Volume 1
418 Diagnostic/Troubleshooting Monitoring to Identify Damaging Cycle Chemistry or Thermal Transients in Heat Recovery Steam Generator Pressure Parts
419 Program on Technology Innovation: Tradeoffs Between Once-Through Cooling and Closed-Cycle Cooling for Nuclear Power Plants
420 Materials Reliability Program: Finite-Element Model Validation for Dissimilar Metal Butt-Welds (MRP-316 Revision 1): Volumes 1 and 2
421 Maintaining Lube Oil System Cleanliness in Motor Bearing Applications
422 EPRI Case History Study: High Pressure Feedwater Heater Replacement
423 Pulverizer Monitoring Project
424 Assessment of Impacts of Retrofit NOx Controls on Gas/Oil Boilers
425 Materials Reliability Program A Review of Thermal Aging Embrittlement in Pressurized Water Reactors (MRP-80)
