176 EPRI Family of Multi-Functional Low Cost Solid State Switchgear: Requirements Definition Phase
177 Pressurized Water Reactor Steam Generator Lay-up: Corrosion Evaluation
178 Common Information Model On Demand Meter Read Interoperability Test Procedure
179 Heat Recovery Steam Generator Repair Welding Technologies to Address FAC in Tube Bends
180 Comparison of Field and Manufactured Flaw Data in Austenitic Materials
181 Integration of Distributed Resources in Electric Utility Systems: Current Interconnection Practice and Unified Approach
182 Guide to the Industrial Application of Motors and Variable-Speed Drives
183 Development of Tube Repair Techniques for Heat Recovery Steam Generators
184 Guidelines for Nuclear Plant Response to an Earthquake
185 Power Plant Control System Tuning Short Course Notes
186 Heat Recovery Steam Generator (HRSG) Chemical Cleaning Guidelines Case Studies
187 Air-Cooled Condenser Design* Specification* and Operation Guidelines
188 “Fish Friendly” Hydropower Turbine Development and Deployment: Alden Turbine Preliminary Engineering and Model Testing
189 Closed Cooling Water Chemistry Guideline* Revision 1
190 Guideline on Nuclear Safety-Related Coatings Revision 21
191 Valve Positioner Principles and Maintenance Guide
192 Power System and Railroad Electromagnetic Compatibility Handbook Revised First Edition
193 Guideline on Proactive Maintenance 1004015 Final Report* November 2001
194 2012 Integrated gasification combined-cycle (IGCC) research and development roadmap
195 Guidelines for Performing Probabilistic Analyses of Boiler Pressure Parts
196 Corrosion of Low Pressure Steam Turbine Components
197 Optimal Hardness of P91 Weldments
198 Understanding the Zed-Meter® Instrument (Draft)
199 Grid Transformation Workshop Results
200 Tower Grounding and Soil Ionization Report
