76 Interconnection of Distributed Energy Resources in Secondary Distribution Network Systems
77 Pump Troubleshooting Volume 1
78 Update on Clean Coal Technologies and CO2 Capture & Storage
79 Electromagnetic Transients Program
80 Valve Application* Maintenance* and Repair Guide Volume 1
81 Evaluation of an advanced infrared thermography system for inspection of boiler tubes
82 Sodium Phosphate Hideout Mechanisms Data and Models for the Solubility and Redox Behavior of Iron(II) and Iron(III) Sodium-Phosphate Hideout Reaction Products
83 Air-Operated Valve Maintenance Guide
84 Electric Motor Predictive and Preventive Maintenance Guide
85 Home Area Network Performance Metrics and Monitoring – Phase 2
86 Tutorial The OpenDSS Application
87 Combined-Cycle Plant Optimization Studies Evaluations of Heat Recovery Steam Generator
Design* Duct Firing* and Combustion Turbine Inlet Air Cooling Options
88 EPRI ChemExpert: Cycle chemistry advisor for fossil power plants
89 Handbook for Evaluating Critical Digital Equipment and Systems
90 Ash Deposition Impacts in the Power Industry
91 Application of the EPRI Standard Radiation Monitoring Program for PWR Radiation Field Reduction
92 BWRVIP-1 8NP* Revision 2: BWR Vessel and Internals Project BWR Core Spray Internals Inspection and Flaw Evaluation Guidelines
93 Power Quality Predictive Maintenance (PQPM) Systems Application for Circuit Breakers and
Reclosers
94 Condition Monitoring and Diagnostics of Bushings* Current Transformers* and Voltage Transformers by Oil Analysis
95 Protective Relay Maintenance and Application Guide
96 Cycle Chemistry Guidelines for Fossil Plants: All-Volatile Treatment Revision 1
97 Condenser Performance Monitoring Practices
98 Circuit Breaker Timing and Travel Analysis
99 EPRI Smart Grid Demonstration Initiative THREE YEAR UPDATE
100 PULVERIZED COAL AND IGCC PLANT COST AND PERFORMANCE ESTIMATES
