251 WET STACKS DESIGN GUIDE
252 Development of an LP rotor rim-attachment *****ing life assessment code (LPRimLife)
253 Examples Manual for Boiler Overhaul Interval Optimization
254 A Strategy for Nuclear Energy Research and Development
255 Electrostatic Precipitator Maintenance Guide Volume 1 of a Two-Volume Set (E213676)
256 Methodology for estimating tidal current energy resources and power production by tidal in-stream energy conversion (TISEC) devices – rev 2-draft
257 Lighting and Human Performance II Beyond Visibility Models Toward a Unified Human Factors Approach to Performance
258 Nondestructive Evaluation: Seismic Design Criteria for Polyethylene Pipe Replacement Code Case
259 Fossil Plant Cycle Chemistry Instrumentation and Control— State-of-Knowledge Assessment
260 Grid Reliability and Power Quality Impacts of Distributed Resources
261 Integrating Distributed Resources into Electric Utility Distribution Systems
262 Phasor Measurement Unit (PMU) Implementation and Applications
263 Assessment of the Need to Chemical Clean
264 Materials Reliability Program: Safety Evaluation for Boric Acid Wastage of PWR Reactor Vessel Bottom Heads Due to Bottom-Mounted Nozzle Leakage (MRP-167)
265 Enchanced oil recovery scopping study
266 Improved Thermal Modeling Tools for Substation Equipment
267 Major Steam Turbine Plant Components
268 Primer: Fracture mechanics in the nuclear power industry
269 Ultrasonic Phased Array Procedures for Rapid Inspection of Piping Welds
270 Dry Cask Storage Characterization Project
271 Pulverizer Maintenance Guide Volume 3: Ball/Tube Mills
272 FMAC: Coal Handling System Maintenance Guide
273 Power Quality Distributed Generation Workbook
274 Stress Intensification Factors and Flexibility Factors for Unreinforced Branch Connections
275 Heat Rate Improvement Reference Manual
