2001 Heat Treatment
2002 Welding of Martensitic Creep-Resistant Steels
2003 OPTIMISATION OF ISR AND PWHT OF CRMOV STEELS
2004 Electron microscopy and microanalysis of steel weld joints after long time exposures at high temperatures
2005 Pressure seal flexible wedge gate valves Butt - weld ends
2006 Stress Relief *****ing in Advanced Steel Material- Overview
2007 Feature tests on welded components at higher temperatures - Material performance and Residual stress evaluation
2008 1.4845 material
2009 THE HEATING RATE IMPACT ON PARAMETERS CHARACTERISTIC OF STEEL BEHAVIOUR UNDER FIRE CONDITIONS
2010 Dynamics of Properties and Structure Changes of Pearlite Steel during Long-lived Operation
2011 Ageing and corrosion of steels in CO2 rich flue gas
2012 The high alloy precipitation hardening martensitic steels and their suitability for welding
2013 Friction Stir Spot Welding of Advanced High-Strength Steels – A Feasibility Study
2014 Welding of Steam Boilers
2015 Weldability of high Cr and 1 % tungsten alloyed creep resistant martensitic steel
2016 Joining and Processing Issues for Ferritic/Martensitic Steels
2017 Welding Martensitic Stainless Steels
2018 Thermal Aging Embrittlement of Austenitic Stainless Steel Welds and Castings
2019 Structural Stability of Dissimilar Weld between Two Cr-Mo-V Steels
2020 Waterproofing Materials for Ammonium Nitrate
2021 Borsig: Welding of Pressure Vessels and Pressure Vessel Components at Subcontractors
2022 Modeling Phase Transformations and Material Properties Critical to Processing Simulation of Steels
2023 CONTRIBUTION TO RESEARCH OF WELDABILITY OF MODERN LOW-ALLOY CREEP RESISTANT STEELS
2024 MEASUREMENT OF RESIDUAL STRESS DISTRIBUTION IN TUBULAR JOINTS CONSIDERING POST WELD HEAT TREATMENT
2025 1.4762 material
2026 Der Gefahrgutaufkleber enthält die verbindlichen Angaben über den Inhalt der Gasflasche!
2027 Experienced filler metals for increasing power plant efficiency
2028 NUMERICAL SIMULATION OF TIG-DRESSING OF WELDED JOINTS
2029 Life Assessment of Creep Exposed Components* New Challenges for Condition Monitoring of 9Cr Steels
2030 Creep Damage and Expected Creep Life for Welded 9-11%Cr Steels
2031 HIGH TEMPERATURE COMPONENTS IN POWER PLANTS: REMNANT LIFETIME ASSESSMENT* REPLICA INSPECTION
2032 API PIPE Seamless & ERW Welded Carbon Steel |Stainless Steel
2033 Non-Destructive Tests to Determine Lifetime of the Pipes
2034 THE INFLUENCE OF THE BOTH FUNCTIONING TIME AND THE SERVICE TEMPERATURE ON THE MECHANIC CHARACTERISTICS AND METALLOGRAPHIC STRUCTURE OF SOME STEELS
2035 Effect of in Service Weld Repair on the Performance of CrMo Steel Steam Pipelines
2036 High temperature corrosion in modern thermal power generation: gas turbines* high efficiency boilers* IGCC
2037 Materials for boiler tube surface protection
2038 Structure and hardness changes in welded joints of Hardox steels
2039 STEAM AND HOT-WATER BOILERS* STEAM AND HOT WATER PIPELINES WELDED JOINTS
General requirements
2040 Purchasing Eye Protection
2041 Studies of welded joints
2042 IT TOOL FOR HARMONISING EXAMINATIONS IN WELDING COURSES
2043 POST WELD HEAT TREATMENT OF WELDED STRUCTURES
2044 Recommended Welding Machine Daily Inspection and Pre-Start Check List
2045 Recommended Oxy-Fuel Gas Daily Inspection and Pre-Start Check List
2046 LASER SAFETY
2047 Norsok: Welding and inspection of piping
2048 The Evonik Steag Road to the High-efficiency Power Plant
2049 ANALYSIS OF WEAR CUTTING TOOLS BY COMPLEX POWEREXPONENTIAL FUNCTION FOR FINISHING TURNING OF THE HARDENED STEEL 20CrMo5 BY MIXED CERAMIC TOOLS
2050 Microstructures and properties of low-alloy fire resistant steel
