2051 Martensitic Stainless Steels Types 410* 420* 425 Mod* and 440A
2052 SIGNIFICANCE OF *****S IN THE HEAT-AFFECTED-ZONE OF STEELS FOR ELEVATED TEMPERATURE APPLICATION
2053 Creep-fatigue interaction assessment of 16Mo5 steel
2054 Surface roughness analyses on hard martensitic stainless steel by turning
2055 Prevention of Type IV Failure in High Cr Ferritic Heat Resistant Steel Welded Joint
2056 FRACTURE OF ADVANCED HIGH STRENGTH STEELS (AHSS)
2057 HARDOX 600 In Workshop
2058 Hardox in the cement industry
2059 Fundamental aspects of electroslag welding of titanium alloy
2060 Welding of Zirconium Alloys
2061 Hardox & Weldox welding
2062 INTERNATIONAL EDUCATION* QUALIFICATION AND CERTIFICATION SYSTEMS IN WELDING
2063 Reserach and development of 9Cr steels for steam generator of DFBR in Japan
2064 The manufacture* properties and weldability of vanadium-containing steels
2065 590MPa Class Fire-Resistant Steel for Building Structural Use
2066 Structure and hardness changes in welded joints of Hardox steels
2067 A challenge for biaxial and triaxial creep testing
2068 Solidification *****ing in austenitic stainless steel welds
2069 Improvement of Creep Property in High Cr Heat Resistant Steel Welded Joint
2070 Review of the performance of high strength steels used offshore
2071 Ferrite to austenite reverse transformation process in B containing 9%Cr heat resistant steel HAZ
2072 Afrox: Nickel
2073 Shielding Gases. Are You Welding with a Shielding Gas that conforms to AWS Specification A5.32?
2074 WELDING OF TITANIUM ALLOYS
2075 Nickel alloy welding requirements for nuclear service
2076 WELDING OF TOOL STEEL
2077 The Effect of Chromium on the Weldability and Microstructure of Fe-Cr-Al Weld Cladding
2078 VdTUV Werkstoffblatter 06/2011
2079 THE CORROSION RESISTANCE OF CAST AND WROUGHT HASTELLOY C IS 70% ENHANCED WHEN REMOVING THE UNWANTED COMPLEX CARBIDES FROM THEIR MICROSTRUCTURE
2080 Analysis of Microstructure in Soft Zone and Precipitation Zone of Dissimilar Cr-Mo Steels Weldment
2081 Structural steels of 690 MPa yield strenght – A state of art
2082 Welding defects* causes and correction
2083 Acceptability of Residual Stresses Measurement Methods of Butt Weldments and Repairs
2084 Modeling of Hydrogen Assisted Cold *****ing in High Strength Steel Welds
2085 Effect of weld heat input on toughness and structure of HAZ of a new super-high strength steel
2086 Numerical investigation on welding residual stress in 2.25Cr-1Mo steel pipes
2087 PREDICTING WELD STRUCTURE USING MODIFIED SCHAEFFLER CONSTITUTION DIAGRAM
2088 Welding defects
2089 Optimizing tensile strength of low-alloy steel joints in upset welding
2090 Evaluation of Fillet Weld Requirements
2091 Electron microscopy investigation of the Cr–Mo–V cast steel
2092 Application of thermovision method to welding thermal cycle analysis
2093 Proposal of welding methods in terms of the amount of oxygen
2094 Modification of Cr-Mo low alloyed steels by addition of Mn via mechanical milling
2095 Innovative PM duplex stainless steels obtained basing on the Schaeffler diagram
2096 Other welding processes
2097 Static strenght of welded joint
2098 Essential Factors in Selecting Heat- Resistant Low Alloy Filler Metals for High- Temperature* High-Pressure Services in the Power Generation* Oil Refining* and Petrochemical Industries
2099 Heat Treatment
2100 Advanced weld repair technology extends plant life
