1001 THERMODYNAMIC VIEWPOINT IN DESIGNING HETEROGENEOUS WELD JOINTS
1002 WELDING OF 9% Cr CREEP RESISTING STEELS FOR POWER ENGINEERING EQUIPMENT
1003 Improving the Inspectability of Stainless Steel and Dissimilar Metal Welded Joints Using Inverse Phase-Matching of Phased Array Time-Domain Signals
1004 TWI: Advances in welded creep resistant 9-12%Cr steels
1005 Numerical Evaluation of the Weldability of the Low Alloy Ferritic Steels T/P23 and T/P24
1006 Austenitic chromium-manganese stainless steels – A European approach
1007 ESAB: Cr-Mo Welding Electrodes for the Power Generating Industry
1008 THE EFFECT OF COLD WORK ON THE SENSITISATION OF AUSTENITIC STAINLESS STEELS
1009 DETERMINATION OF SUSCEPTIBILITY TO INTERGRANULAR CORROSION OF UNS 31803 TYPE DUPLEX STAINLESS STEEL BY ELECTROCHEMICAL REACTIVATION TECHNIQUE
1010 DETERMINATION OF SUSCEPTIBILITY TO INTERGRANULAR CORROSION IN AISI 304L AND 316L TYPE STAINLESS STEELS BY ELECTROCHEMICAL REACTIVATION METHOD
1011 Fracture toughness of friction stir welded joints of AlCu SiMg aluminium alloy
1012 Microstructural Evolution on the T91 Dissimilar Metal Joints during Creep Rupture Tests
1013 SHIELDING GASES SELECTION MANUAL
1014 NDT – Level III literature
1015 FATIGUE STRENGTH OF WELDS IN THE VIEW OF RESIDUAL STRESSES
1016 Welding book
1017 BENDING AND FORMING OPERATIONS
1018 AN EVALUATION OF FOUR CURRENT MODELS TO PREDICT THE CREEP-FATIGUE INTERACTION IN RENf 95
1019 OUTOKUMPU: High Performance Austenitic Stainless Steel
1020 DEGRADATION OF MECHANICAL PROPERTIES OF CrMo CREEP RESISTANT STEEL OPERATING UNDER CONDITIONS OF CREEP
1021 NDT CODE BOOK
1022 TENSION TESTS ON WELDED THREADED STUDS WITH A TENSILE STRENGTH OF 800N/mm²
1023 THE EFFECT OF STRAIN RATE ON TENSILE PROPERTIES AND FRACTURE STRAIN
1024 Numerical simulation of the temperaturbe filed in fixed-TIG welding pool
1025 Two-parametar fracture criterion by volumetric method approach
1026 Use Undermatching Weld Metal Where Advantageous
1027 Mechanical properties of structural steels
1028 Fatigue strength of shafts reclaimed by welding
1029 Selecting Filler Metals: Matching Strength Criteria
1030 Straing ageing of structural steels
1031 DEGRADATION OF MECHANICAL PROPERTIES OF CrMo CREEP RESISTANT STEEL OPERATING UNDER CONDITIONS OF CREEP
1032 MAIN ALLOY ELEMENTS IN COVERED ELECTRODES IN TERMS OF THE AMOUNT OF OXYGEN IN WELD METAL DEPOSITS (WMD)
1033 Metrode Welding consumables
1034 VOID NUCLEATION AND *****ING AT GRAIN BOUNDARIES
1035 Tensile properties and mechanical heterogeneity of friction stir welded joints of 2014 aluminum alloy
1036 Weld Design and Specification
1037 A Methodology for Screening Candidate Dissimilar Metal Welds for Repair or Replacement
1038 Application and Upgrading of On-line Monitoring System for Measurement and Processing of Electric Signals at Arc Stud Welding Process
1039 INTERFACIAL *****ING FROM THE FREEEDGE OF A LONG BI-MATERIAL STRIP
1040 Initiation and arrest of an interfacial ***** in a four-point bend test
1041 Quantitative characterisation of the microstructure high chromium steel with boron for advanced steam power plants
1042 CHARACTERISATION OF INTERFACIAL *****ING IN MICROELECTRONIC PACKAGING
1043 Practical aspects for production welding and control of duplex stainless steel pressure and process plants
1044 Prediction of Weld Bead Geometry using Artificial Neural Networks on 2205 Duplex Stainless Steel
1045 ESAB: Welder guide book - All-positional rutile flux cored wires for non and low alloyed steels
1046 Electron microscopy and microanalysis of steel weld joints after long time exposures at high temperatures
1047 NEW FEATURES ON MAGNESIUM ALLOYS
1048 Porosity in Castings
1049 CREVICE CORROSION OF STAINLESS-STEEL FASTENING COMPONENTS IN AN INDOOR MARINE-WATER BASIN
1050 FRACTURE TOUGHNESS AND MECHANICAL PROPERTIES OF PURE NIOBIUM AND WELDED JOINTS FOR SUPERCONDUCTING CAVITIES AT 4 K
link:
