801 Guideline for submerged arc welding
802 HEAT TREATMENT PROCEDURE QUALIFICATION
803 Heat-resistant materials
804 Bohler: THE DANGERS POSED BY HYDROGEN IN WELDING UN- AND LOW ALLOYED STEELS
805 Modern physical metallurgy & materials engineering
806 Nickel and the skin
807 Bohler: WELDING CONSUMABLES FOR THE OFFSHORE INDUSTRY
808 Welding materials handbook
809 Creep and fatigue ***** growth in P91 weldments
810 Performance of P91 Weldments Under Steady And Cyclic Load Conditions And Directions For Future Research
811 Bohler: WELDING CONSUMABLES FOR THE CHEMICAL AND PETROCHEMICAL PROCESS INDUSTRY
812 Bohler: WELDING CONSUMABLES FOR PIPELINE CONSTRUCTION
813 SELF SHIELDED FLUX CORED WIRES BÖHLER PIPESHIELD 71 T8-FD AND BÖHLER PIPESHIELD 81 T8-FD
814 Poweder metallurgy technology
815 Resistance welding: Fundamentals & Applications
816 RECENT EXPERIENCE IN DISSIMILAR METAL WELD FAILURES
817 Life Management and Maintenance for Power Plants Vol. 1
818 UK Plant Experience with Grade 91
819 Selection and Use of Engineering Materials* 3rd Ed
820 Steel framed structures: Stability and strenght
821 Bohler: WELDING CONSUMABLES FOR STEEL CONSTRUCTION
822 Steel heat treatment handbook
823 Magnetic NDT Technology for Characterizing Materials – A State of the Art Survey
824 Weld assessments and weld propertiies
825 Welding theory and application
826 Understanding “Position” in Welding
827 Bohler welding giude 09/2010
828 Bohler welding guide 07/2005
829 Creep Properties of Base Material and Weldments of P23 Steel
830 MICROSTRUCTURAL EVOLUTION IN A SINGLE PASS AUTOGENOUSLY WELDED 2.25Cr-1Mo STEEL
831 CREEP FAILURE CHARACTERISTICS IN P23/P91 DISSIMILAR WELDS
832 Introduction of the state-of-the-art technology of IHI for Ultra-SuperCritical power plant
833 ASNT Level 2 Study Guide: Magnetic particle testing method – 2nd edition
834 Building design and construction handbook – 6th edition
835 Joining of materials and structures from fragmatic process to enabling technology
836 ESAB: Repair and Maintenance Welding Handbook – 2nd edition
837 MECHANISM OF PHOSPHORUS SEGREGATION IN HAY OF Cr/Mo STEEL AND ITS EFFECT ON REHEAT *****ING
838 BOILERS for POWER and PROCESS
839 Welding Fabrication Standards
840 Guidelines on pipe wall thinning
841 Installation* Operation and Maintenance for the PT-24 Precision Plasmarc System
842 PROCEDURE FOR LIQUID PENETRANT EXAMINATION
843 ACCELERATED CREEP TESTS OF ALL-WELDED METALS
844 EXPERT TECHNOLOGY TOOL ISO 3834:2005 Quality requirements for fusion welding of
metallic materials Benefits and Implementation
845 Reliability of Welding Parameters Monitoring System
846 Welding Guidelines for Sanicro 69
847 Vallourec & Mannesman Brochures
848 Welding for dummies
849 Boiler operator's handbook
850 CONTRIBUTION TO RESEARCH OF WELDABILITY OF MODERN LOW-ALLOY CREEP RESISTANT STEELS
