751 MSDS NO: TUNGSTEN ELECTRODE
752 Lincoln: WELD METAL SELECTOR GUIDE
753 Welder's handbook For Gas Shielded Arc Welding* Oxy Fuel Cutting & Plasma Cutting
754 WELDING THEORY 8th edition
755 Welding training
756 Microstructural and Mechanical Characterization of High Temperature and Creep Resistant Steel Weldments
757 Mechanical properties of engineered materials
758 Metrode: FILLER MATERIALS FOR 6%Mo SUPERAUSTENITIC STAINLESS STEELS
759 Metrode: 308H & 16-8-2 STAINLESS STEEL WELD METALS FOR OIL REFINERY CATALYTIC
*****ING UNITS
760 Metrode: WELDING 1-2CrMo AND CrMoV FOR POWER AND PETROCHEMICAL INDUSTRIES
761 Metrode: WELDING GUIDELINES FOR DUPLEX & SUPERDUPLEX STAINLESS STEELS
762 Metrode: DUPLEX & SUPERDUPLEX PROPERTIES & TEST REQUIREMENTS
763 Metrode: Effective Welding of Duplex & Superduplex Stainless Steels
764 Metrode: WELDIING WIITH METRODE FLUX CORED WIRES "GETTIING THE BEST
OUT OF THE PROCESS"
765 Metrode: STAINLESS STEEL CONSUMABLES FOR LNG APPLICATIONS
766 Metrode: General Guidance on Welding Nickel Alloys
767 Metrode: Welding consumables for P91 steels for the power generation industry
768 Metrode: PROPERTIES OF T/P92 STEELWELD METALS FOR ULTRA SUPER CRTITICAL (USC) POWER PLANT
769 Metrode: Welding Consumables for P92 and T23 Creep Resisting Steels
770 Metrode: P92 welding consumables for the power generation industry
771 Stainless Steel Arc Welding Consumables for Cryogenic Applications
772 Metrode: P36 welding consumables for the power generation industry
773 T-PUT at a glance
774 Requirements on pipe and tube steels and fabrication of the components for new generation of high effecient power stations
775 Limits and state-of-the-art of the new creep resistant steels for new power plants
776 Filler metals for welding of T/P23 and T/P24
777 Filler metals for welding of the 9% and 12% Cr-steels P92 and VM12-SHC
778 Hot *****ing phenomena in submerged arc welds of the martensitic steel P92
779 Welding of dissimilar joints for new power statons
780 Experience and applications of new steel grades
781 Filler metals for welding of super 304 H
782 Accelerated test determination of creep properties for different P24 steel weldments
783 Weld path optimisation for rapid prototyping and wear replacement by robotic GMAW
784 THE FUNDAMENTAL FACTORS INFLUENCING THE BEHAVIOR OF WELDED STRUCTURES UNDER CONDITIONS OF MULTL4XIAL STRESS* AND VARIATIONS OF TEMPERATURE* STRESS
CONCENTRATION* AND RATES OF STRAIN
785 IIW: Fatigue Life Improvement of Tubular Welded Joints by Ultrasonic Peening
786 Performance of P91 Thick Section Welds Under Steady and Cyclic Loading Conditions: Power Plant and Research Experience
787 IIW: Rehabilitation and Repair of Welded Elements and Structures by Ultrasonic Peening
788 Corrosion Resistant Alloys for Oil and Gas Production: Guidance on General Requirements and
Test Methods for H2S Service
789 Welding of Martensitic Creep-Resistant Steels
790 BORSIG Standard BOR-ACW-S-1 Welding of Pressure Vessels and Pressure Vessel Components
at Subcontractors
791 AWS: Characterization of arc welding fume
792 Computional welding mechanics: Thermomechanical and microstructural simulations
793 ESAB: BASIC WELDING FILLER METAL TECHNOLOGY
794 Failures of P91 steel at the west burton plant in england raise concerns about the long term behaviour of the advanced steel
795 Fabrication and welding engineering
796 Bohler: FLUX CORED WELDING WIRES FOR STAINLESS STEELS
797 Fundamentals of metallic corrosion
798 GTAW handbook
799 Guidelines To Gas Tungsten Arc Welding (GTAW)
800 EFFECTS OF THERMAL CYCLE ON MECHANICAL PROPERTIES AND FRACTOGRAPHY IN HAZ OF HQ130 STEEL
