1351 Control of relaxation *****ing in austenitic high temperature components
1352 Effect of thermal aging on stress corrosion and fatigue ***** growth behaviour of A533B steel in high temperature pressurized water
1353 Engineers’ Guide to Pressure Equipment
1354 Ventilation for Welding and Cutting
1355 POST WELD HEAT TREATMENT OF WELDED STRUCTURES
1356 GUIDELINES FOR WELDING* NDE AND HEAT TREATMENT
1357 A REVIEW OF WELDING CAST STEELS AND ITS EFFECTS ON FATIGUE AND TOUGHNESS PROPERTIES
1358 HASTELLOY® and HAYNES® PIPE AND T U B U LAR PRODUCTS
1359 A State-of-the-Art Review of High Performance Steel for Bridge Design
1360 Hydrogen Piping Experience in Chevron Refining
1361 EPRI: U.S. Program for Advanced Ultrasupercritical (A-USC) Coal Fired Power Plants
1362 Advanced Control Methods for Optimization of Arc Welding
1363 ANALYSIS OF CREEP BEHAVIOR AND PARAMETRIC MODELS FOR 2124 AL AND 2124 AL + SiCW COMPOSITE
1364 Kobelco welding today – October 2005 – volume 8
1365 Mechanics for young' America
1366 Hydrogen plasma – smelting reduction – an option for steelmaking in the future
1367 Secondary recrystallization in non-oriented electrical steels
1368 Superplastic deformation of Al-Al4-C3 composites
1369 Influence of Post Weld Heat Treatment on Secondary Hardening of CrMoV Welded Joints
1370 Assessing Operating limits for C-0.5Mo steel in high temperature H2 service
1371 THE BASICS OF Gas Metal Arc Welding Examining metal transfer modes* electrodes* and
shielding gases
1372 Paralleling Arc Welding Power Sources
1373 Transformation of knowledge and technology from research and development to the commercial production of heavy steel castings and forgings for power engineering* made of advanced creep resistant steels
1374 Principles and practices of stud welding
1375 WITH THE NARROW GAP TIG HOT WIRE WELDING MULTIPLY YOUR PRODUCTIVITY BY A FACTOR OF 9* WITHOUT SACRIFYING THE QUALITY
1376 Z-phase strengthened Martensitic 9-12%Cr steels
1377 Creep Properties and Microstructure of HR6W and Ni-base Superalloys for Advanced USC Boilers
1378 Advances in Materials Technology for A-USC Power Plant Boilers
1379 Petroleum Hydrocarbons And Chlorinated Hydrocarbons Differ In Their Potential For Vapor Intrusion
1380 HANDBOOK FOR Resistance Spot Welding
1381 NEW COAL-FIRED STEAM GENERATOR DESIGN FOR HIGH PLANT EFFICIENCY AND LOW EMISSIONS
1382 High-Temperature Hydrogen Attack (HTHA) in non PWHT Carbon Steel Pipe Welds
1383 Boiler Grade DMV 310 N
1384 Experimental Evaluation of Fireside Corrosion Resistance of Advanced Materials for Ultra-Supercritical Coal-Fired Power Plants
1385 STUD WELDING TECHNICAL GUIDE For Weld Pins
1386 ULTIMET® alloy
1387 Hot Extrusion Technology Generation on the Basis of FEM and FMEA Analysis
1388 A pilot study on the strength of 5Ni-Cr-Mo-V steel columns* Experimental Mechanics* January 1968* Reprint No. 68-6
1389 BOILER MATERIALS FOR USC PLANT
1390 Essential Skills Manual Welder
1391 Welding gauge
1392 Welding manual for power sector
1393 Microstructural and Mechanical Characterization of High Temperature and Creep Resistant Steel Weldments
1394 Welding And The World Of Metals
1395 Bainitic and martensitic creep resistant steels
1396 Behavior of Welded Joints of Creep- Resistant Steels at Service Temperature
1397 Precipitate design for creep strengthening of 9% Cr tempered martensitic steel for ultra-supercritical power plants
1398 Tempering of bainite
1399 Introduction to Penetrant Testing
1400 Liquid penetrant testing 2
