1301 Alias-hida* a knowledge based system for probabilistic & sensitivity analysis of creep and fatigue ***** growth in high temperature components
1302 Unifuse overlay cladding for surface protection against corrosiona and errosion/corrosion in power boilers and waste heat recovery systems
1303 Improvement of type IV creep *****ing resistance of 9Cr heat resisting steels by boron addition
1304 Comparision of the procedures for the assessment of creep ***** initiation
1305 A16 defect assessment procedure application to 316SS CT speciments and plates in bending at 650°C with a repair weld and improvements to take into account initial creep damage
1306 A simple engineering probabilistic assessment method of fatigue ***** growth in the stable paris region
1307 The effect of warm pre-stressing in enhancigh the toughness of LP and IP turbine rotor steels
1308 MICROSCOPIC DAMAGE ANALYSIS OF WELDED JOINTS UNDER TYPE III AND TYPE IV CREEP FAILURE
1309 CREEP RESISTANCE OF WELD JOINT OF TUBE MADE OF P92 STEEL
1310 Two Shifting of Power Plant: Damage to Power Plant Due to Cycling - A brief overview
1311 THE EFFECT OF LONG TERM EXPOSURE TO ELEVATED TEMPERATURE ON STEAM LINE STEEL PROPERTIES
1312 Effect of Cadmium Chloride Flux in Active Flux TIG Welding of Magnesium Alloys
1313 Condenser And Heat Exchanger Tube Restoration
1314 Heat treatment is not optional
1315 LONG TERM MICROSTRUCTURAL EVOLUTION OF 9-12%CR STEEL GRADES FOR STEAM POWER GENERATION PLANTS
1316 Tensile test analysis using reversing DC electrical potential method
1317 Materials for AdvancedUltra-Supercritical Steam Boilers
1318 Arc voltage behavior in GMAW-P under different drop transfer modes
1319 Changes in the structure of VM12 steel after being exposed to creep conditions
1320 U.S. Program on Materials Technology for Ultrasupercritical Coal-Fired Boilers
1321 Pulsed Gas Metal Arc Welding (GMAW-P) for Newer Challenges in Welding of Aluminum Alloys
1322 Creep testing of steel
1323 Effect of in Service Weld Repair on the Performance of CrMo Steel Steam Pipelines
1324 BOILER MATERIALS FOR ULTRASUPERCRITICAL COAL POWER PLANTS
1325 Susceptibility to Hot *****ing and Weldment Heat Treatment of Haynes 230 Superalloy
1326 Procurement and Initial Characterization of Alloy 230 and CMS Alloy 617
1327 Introduction to welding
1328 Creep-Rupture Reliability Analysis
1329 Cadmium General information
1330 Weldability and Mechanical Property Characterization of Weld Clad Alloy 800H Tubesheet Forging
1331 A procedure for high temperature plant components life evaluation: Small punch creep test methodology
1332 Development of the microalloyed constructional steels
1333 FRACTURE OF ADVANCED HIGH STRENGTH STEELS (AHSS)
1334 MICROSTRUCTURE EVOLUTION OF CrMoV WELD METAL AFTER LONG-TERM HEAT EXPOSURE
IN THE SUB-CREEP RANGE
1335 Welding of Electron Beam Single Melt Ti-6Al-4V Plate
1336 Basic electricity
1337 Stud Welding – Practical Knowledge Quick Start Guide – BMK-12W Stud Welder
1338 BOILER MATERIALS FOR ULTRASUPERCRITICAL COAL POWER PLANTS
1339 Elimination of Fissures in Thick Section INCONEL Alloy 740 Welds
1340 Material Considerations when working with Hydrogen
1341 TIME DEPENDENT BEHAVIOUR: CREEP
1342 Cobalt in metallurgical uses
1343 CORROSION CONTROL BY MODERN WELD OVERLAY TECHNOLOGY
1344 Corrosion Performance and Fabricability of the New Generation of Highly Corrosion-Resistant
Nickel-Chromium-Molybdenum Alloys
1345 Creep and Stress Rupture
1346 AWS: D10 COMMITTEE ON PIPE AND TUBE WELDING - INFORMATION ON-HAND* PROBLEMS SOLVED* QUESTIONS ANSWERED
1347 TigHotWire
1348 INVERTER ARC WELDER MODEL 300TSW AC/DC CC
1349 Cr-Alloyed Steel Powders for High-Strength Sintered Parts without Heat Treatment after Sintering*
1350 Digital singal processing as a diagnostic tool for GTAW
link:
