1251 Cross Weld Creep Testing in the Assessment of Repair Welds
1252 Factors influencing the performance and reliability of tubular boiler components
1253 NUMERICAL MODELLING OF FERRITIC WELDS AND REPAIR WELDS
1254 Economic Analysis of Boiler Tube Failures in NSW
1255 EXPERIENCE IN IN-SITU REPAIR WELDING OF STEAM TURBINE SHROUDS AND BLADES
1256 A review of the finite element analysis of repaired welds under creep conditions
1257 THE MECHANICAL PROPERTIES AND MICROSTRUCTURES OF 9% CHROMIUM STEEL P92 WELDMENTS
1258 Life Assessment of Creep Exposed Components* New Challenges for Condition Monitoring of 9Cr Steels
1259 Active Balancing Developments For Power Generation
1260 Condenser And Heat Exchanger Tube Restoration
1261 RENOVATION AND MODERNISATION OF THERMAL POWER PLANTS
1262 EXPERIENCE FROM EXTENSIVE TWO-SHIFT OPERATION OF 680MW COAL / GAS-FIRED UNITS AT CASTLE PEAK Power Station - HONG KONG
1263 Combustion Turbine Hot Section Life Management
1264 Performance of P91 Thick Section Welds Under Steady and Cyclic Loading Conditions: Power Plant and Research Experience
1265 Factors* Defined from Analysis* Contributing to the Creep Performance of Weld Repairs
1266 Weld Repair of a Petrochemical Component
1267 Steam Turbine Management in a Changing Market
1268 Risk Acceptance Criteria and Regulatory Aspects
1269 CREEP LIFE ASSESSMENT OF PIPE GIRTH WELD REPAIRS WITH RECOMMENDATIONS
1270 Managing the pay-off between risk* reliability and remaining life – weighting the consequences
1271 APPLYING ENGINEERING CONTRACTOR SKILLS TO MANAGE AND MITIGATE RISKS ON POWER PLANT
1272 Background to the design of HRSG systems and implications for CCGT plant cycling
1273 Some characteristics of weld repair for creep applications
1274 Review of cold weld repair applications
1275 Develpoment and use of weld repair methodologies in the USA
1276 Residual life evaluation and repair procedures for high temperature boiler piping
1277 The collation of in-house-data on weld repair of high temperature components
1278 The application of FCAW in UK power plant
1279 Creep-fatigue properties of 2.25Cr-1Mo repair welds
1280 Gas market liberalization in Germany and possible consenquences for gas turbine operation
1281 Operating experience with feed pumps in 800/900 MW units
1282 The situation in steam turbine construction and current development trends
1283 Tensile test analysis using reversing DC electrical potential method
1284 GUIDANCE NOTES ON THE NEW EUROPEAN STANDARD (pr)EN 14532-2 ON CONFORMITY ASSESSMENT OF HIGH TEMPERATURE WELDING CONSUMABLES
1285 REFERENCE COMPILATION OF PARENT MATERIAL STRESS RUPTURE PROPERTIES FOR CONFORMITY ASSESSMENT OF WELDING CONSUMABLES
1286 Creep life prection of tube bends including ovality effects
1287 Study on the judgement criterion and mechanisms of anti-vibration in large tubular heat exchangers
1288 Life extension methods in aero-engines
1289 Creep-fatigue characteristics of partial repair welds and full repair welds on aged 2.25Cr-1Mo steel
1290 Microstructural and microchemical analysis of aluminized superalloy
1291 Environmental degradation issues in gas turbines and their relevance to plant life extension
1292 Lifetime deterioraion of turbine components during start-ups
1293 Equivalent stress variation at interface of two materials in a butt-welded plate – an analitical/numerical study
1294 Mid-life review of a repowered 600MW boiler – practical aspects from design to inspection
1295 On-line monitoring and control of furnace wall corrosion in PF-fired boilers
1296 The investigation of defects and failures on power plant
1297 Creep* creep-fatigue ***** initiation and growth in 9-12% chromium steels
1298 Fatigue ***** growth in large *****ed plates of martensitic P91 steel at 500° C
1299 On the time depended-material fracture toughness at high temperature
1300 Gas turbine hot section life assessment & extension: Status and issues
link:
