2401 Design of jigs* fixtures and press tools
2402 LIQUID PENETRANT TESTING (PT)
2403 Formation of Outburst STRUCTURE in hot dip galvannealed coatings on IF steels
2404 Recommendations for Fatigue Design of Welded Joints and Components
2405 Standards for Engineering Design and Manufacturing
2406 TUBE-TO-TUBESHEET JOINTS: THE MANY CHOICES
2407 TUNGSTEN GUIDEBOOK
2408 UNDERWATER CONCRETING AND REPAIR
2409 Recommended Welding Parameters: Carbon & Low Alloy Steel Electrodes - Flux Cored - Flat and Horizontal - CO2 - DCEP
2410 INTRODUCTION TOMIG Welding
2411 INSTRUCTION MANUAL FOR ARC WELDING MACHINE
2412 Manual Metal Arc Welding
2413 Arc welding basics
2414 AN INTRODUCTION TO MANUAL METAL ARC (MMA) “STICK” WELDING
2415 EML 2322L -- MAE Design and Manufacturing Laboratory Welding
2416 FREE GUIDE - HOW TO DO MIG WELDING
2417 Welding of stainless steels and other joining methods
2418 Basic Understanding of Weld Corrosion
2419 Corrosion of an austenite and ferrite stainless steel weld
2420 Solidification *****ing in austenitic stainless steel welds
2421 Dissimilar metal welds and weld joint design for duplex stainless steels
2422 Formation of Hot *****s in Austenitic Stainless Steel Welds—Solidification *****ing
2423 Ultrasonic Inspection of Austenitic and Dissimilar Welds
2424 WELDING DISSIMILAR METALS
2425 Clarification of Solidification Behaviors in Austenitic Stainless Steels Based on Welding Process
2426 Determining acceptable levels of weld discoloration on machinally polished and electropolished stainless steel surfaces
2427 Embrittlement of Austenitic Stainless Steel Welds
2428 Advances in ultrasonic testing of austenitic stainless steel welds. Towards a 3D description of the material including attenuation and optimisation by inversion
2429 Effect of Welding on The Corrosion Behaviour of a Highly Alloyed Austenitic Stainless Steel UNS N06027 in Polluted Phosphoric Acid Media
2430 Novel ways of using Nd:YAG laser for welding thick section austenitic stainless steel
2431 ACTIVE FLUX TUNGSTEN INERT GAS WELDING OF AUSTENITIC STAINLESS STEEL AISI 304
2432 Atmospheric Stress Corrosion *****ing Susceptibility of Welded and Unwelded 304* 304L* and 316L Austenitic Stainless Steels Commonly Used for Dry Cask Storage Containers Exposed to Marine Environments
2433 *****ing Phenomenon in Spot Welded Joints of Austenitic Stainless Steel
2434 Microstructure* Recrystallization* and Mechanical Property Evolutions in the Heat-Affected and Fusion Zones of the Dissimilar Stainless Steels
2435 The ultrasonic inspection of austenitic materials State of the art report
2346 An Overview of Welded Low Nickel Chrome-Manganese Austenitic and Ferritic Stainless Steel
2347 Handbook on the ultrasonic examination of austenitic clad steel components
2438 Guidelines for the welded fabrication of nickel-containing stainless steels for corrosion resistant services
2439 BOC: Shielding Gas The right gas working for you
2440 NORSOK: WELDING AND INSPECTION OF PIPING
2441 A review on critical aspects of 316ln austenitic stainless steel weldability
2442 Investigation of mechanical properties of welded SS347H austenitic stainless steel tube by using P-GMAW
2443 THE EFFECT ON ANGULAR DISTORTION OF WELDING CURRENT ON AUSTENITIC STAINLESS STEEL FLANGED PIPE WITH TIG METHOD WELDING
2444 Phased Array Ultrasonic Inspection of Dissimilar Metal Joints
2445 Combined welding of Austenitic and Ferritic Stainless steel
2446 Study of Austenitic Stainless Steel Welded With Low Alloy Steel Filler Metal
2447 LASER WELDING OF AUSTENITIC STAINLESS STEEL THIN SHEETS
2448 Designing of CK45 Carbon Steel and AISI 304 Stainless Steel Dissimilar Welds
2449 Solidification and phase transformations in welding
2450 Embrittlement Prediction of Aged Austenitic Stainless Steel Welded Components Using Hardness Measurements
