2351 Hyundai: Piping design handbook
2352 ANALYSIS OF PROBLEMS OCCURED DURING WELDING OF NEW GENREATION BAINITIC STEEL 7CrMoVTiB10-10 (T24)
2353 Corrosion of steels in H2O-CO2 atmospheres at temperatures between 500°C and 700°C
2354 Eskom: Welding of High Pressure* Temperature Tube and Pipework
2355 THE INVESTIGATION OF APPLICABILITY OF THE HOLLOMON-JAFFE EQUATION ON TEMPERING THE HSLA STEEL
2356 EFFECT OF WELDING ON THE PROPERTIES OF HR3C* SUPER 304H* TP347HFG AND P92 STEELS
2357 EPRI: EPRI Conference on 9Cr Materials Fabrication and Joining Technologies
2358 EPRI: Hexavalent Chromium Air Sampling Data from Welding and Steel Cutting
2359 Mathematical Model for Tempering Time Effect on Quenched Steel Based on Hollomon Parameter
2360 Welding of the austenitic alloys Super 304H* 310N and 347H FG
2361 Steel detailers' manual – 3rd edition
2362 Flexural Testing of Weld Site and HVOF Coating Characteristics
2363 Advanced welding systems: Fundamentals of fusion welding and technology
2364 COAL-FIRED POWER MATERIALS
2365 Fatigue of structures and materials
2366 Creep properties and damage behaviour of component-like tubes of Vm12-materials
2367 EPRI: Nondestructive Evaluation: Indication Characterization* Evaluation* and Disposition Guideline
2368 EPRI: Nondestructive Evaluation: NDE for Type 304/316 Stainless Steel Material Characterization
2369 Quality management at RWE using T24 boiler material as an example
2370 EPRI: Repair and Replacement Applications Center: Investigation of Thickness Limits for Post Weld Heat Treatment (PWHT) Exemption
2371 ACCELERATED CREEP TESTS OFALL-WELDED METALS
2372 Requirements concerning MATERIALS AND WELDING
2373 VM12-SHC Technical datasheet
2374 High performance materials and corrosion control for efficient and low emission biomass and waste combustion (HICOR) – final report
2375 Machinery's handbook
2376 Guide to Low-Emission Boiler and Combustion Equipment Selection
2377 Boilers questions
2378 Vallourec brochure
2379 HTRI design manual
2380 Couplings and joints: design* selection and application – 2nd edition
2381 Seals and sealing handbook – 5th edition
2382 Advances in materials technology for fossil power plants
2383 Supealloys
2384 FRICTION STIR WELDING AND PROCESSING VI
2385 AUTOMATIC PIPE BUTT WELDING PROCESSES IN STEAM BOILERS PRODUCTION
2386 BRAZING HANDBOOK
2387 Practical Plumbing Engineering
2388 Gamma Titanium Aluminide Alloys
2389 Basics of boiler and HRSG design
2390 Stresses in beams* plates and shells – 3rd editon
2391 COMPARISON OF ASME SPECIFICATIONS AND EUROPEAN STANDARDS FOR MECHANICAL TESTING OF STEELS FOR PRESSURE EQUIPMENT
2392 Corrosion atlas – 2nd edition
2393 Corrosion behaviour and protection of copper and aluminium alloys in seawater
2394 Defect sizing using non-destructive ultrasonic testing
2395 DESIGN OF WELDED STEEL STRUCTURES P R I N C I P L E S A N D P R A C T I C E
2396 Advances in corrosion control and materials in oil and gas production
2397 Electrochemistry and corrosion science
2398 Engineering cookbook: A Handbook for the Mechanical Designer
2399 IWE 2015
2400 Hot *****ing Phenomena in Welds III
