1551 Frequently Asked Questions Welding Fume Control
1552 Pressure vessel handbook – 10th edition
1553 CSWIP 3.2
1554 Welding journal – January 2013
1555 Weld Joints
1556 IIW Guideline PERSONNEL WITH RESPONSIBILITY FOR WELDING COORDINATION
Minimum Requirements for the Education* Examination and Qualification
1557 Non-Destructive Testing Inspector's Handbook
1558 Welder level A: Program outline
1559 FABRICATION OF SUPER304H STEEL TUBES
1560 FABRICATION OF HR3C STEEL TUBES
1561 SUMITOMO Boiler TubesforUltra super critical BoilersSUMITOMO Boilers
1562 Manual of Steel Construction Load and Resistance Factor Design
1563 Stainless Steel Chromium-Nickel-Manganese ATI 201LNTM-MIL (UNS Designation S20153)
1564 Haynes welding manual
1565 Chromium and Nickel in Welding Fume
1566 IMPROVEMENT OF WELD HAZ TOUGHNESS AT LOW HEAT INPUT BY CONTROLLING THE DISTRIBUTION OF M-A CONSTITUENTS
1567 PROBLEMS IN REPAIR-WELDING OF DUPLEX-TREATED TOOL STEELS
1568 Nickel-Chromium-Molybdenum Superalloys: The Solution to Corrosion Problems in Wet Limestone FGD Air Pollution Control Systems
1569 Ship Construction
1570 stainless steels and their properties
1571 Chromium* Nickel and Welding
1572 Weldability and high temperature behavior of 12% Cr-steel for tubes and pipes in power plants with steam temperatures up to 650 °C.
1573 T-PUT catalogues
1574 EPRI: Weld overlčay of waterwall tubing* alternative filler
1575 EPRI: The Use of Weld Overlays to Extend the Useful Life of Seam Welded High Energy Piping in Fossil Power Plants
1576 EPRI: P-No. 4 and P-No. 5A Temperbead Repair Using the Flux-Cored Arc Welding (FCAW) Process
1577 EPRI: Evaluation of solid wire advanced GMAW for solide section and piping replacement
1578 EPRI: Guide for repair of thinned piping
1579 EPRI: Advanced GMAW proces for pipe welding applications
1580 EPRI: Repair of Metal Bellows
1581 EPRI: Tack Welding Guidelines
1582 EPRI: Inherently Reliable Boiler Component Design
1583 EPRI: Development of Advanced Methods for Joining Low-Alloy Steels
1584 EPRI: Optimal Hardness of P91 Weldments
1585 EPRI: Effects of Cold Work and Heat Treatment on the Elevated Temperature Rupture Properties of Grade 91 Material
1586 EPRI: Effect of Normalization and Temper Heat Treatment on P91 Weldment Properties
1587 EPRI: New Steels for Advanced Power Plants II Phase 2: Development of Advanced 9-12 Cr Steels for Thick Section Boiler Applications
1588 EPRI: EPRI Conference on 9Cr Materials Fabrication and Joining Technologies
1589 EPRI: Productivity Improvement Handbook for Fossil Steam Power Plants: Third Edition
1590 EPRI: Development of an On-Line Corrosion Advisor (OLCA)
1591 EPRI: Conference Proceedings: EPRI-RRAC Fifth International Conference on Welding and Repair Technology for Power Plants
1592 EPRI: Fan Repair Guideline
1593 EPRI: Welding Best Practices Manual for High-Risk/High-Value Repairs
1594 EPRI: PWHT Exemptions for Low Hardenability Materials
1595 EPRI: Ultrasonic Testing (UT) of Dissimilar Metal Welds (DSM) Training
1596 EPRI: GTAW Flux-Cored Wires for Open Root SS Welding
1597 EPRI: Reinstatement of Post-Weld Heat Treatment (PWHT) Exemptions for P Nos. 4 and 5A Socket Welds
1598 EPRI: Temperbead Repair Welding of Grade 91 Material
1599 EPRI: Evaluation of Filler Materials for Transition Weld Joints Between Grade 91 to Grade 22 Components
1600 EPRI: Heat Exchanger Single Tube Test Device
