1501 Investigation of the effects of various surface treatments on properties of plastic mould steels X40CrMoV5-1
1502 Influence of select parameters of drawing process on the expansive deposition of inner PE lining in pipelines
1503 A study on simulation model and kinematic model of welding robot
1504 Co-ordination in the autonomous software agents’ systems
1505 Effect of cutting on surface hardness and residual stresses for 12Mn austenitic steel
1506 Carbon effect in the sintered high-speed steels matrix composites - HSSMC
1507 Microstructure characterization of chromium carbides coatings deposited by thermal spraying processes
1508 General overview of sheet incremental forming
1509 The polish proposal for environmental protection
1510 SimulationDB – technological knowledgebase – new trend of data management
1511 Atom probe tomography of 15KhMFT Cr-Mo-V steel surveillance specimens
1512 Oerlikon competence # 2
1513 Cr-Mo Welding Electrodes for the Power Generating Industry
1514 The science and engineering o materials – 6th edition
1515 High-Performance Alloys For aircraft* land-based & marine gas turbines
1516 Heat treatment: Principles and techniques – 2nd edition
1517 How to Weld Type 2205 Code Plus Two® Duplex Stainless Steel
1518 Selecting Filler Metals: Low Hydrogen
1519 A Smart Model for Welding Engineers to Achieve Target Fusion Zone Geometry and Microstructure using Parallel Genetic Algorithm
1520 WELDABILITY TEST OF PRECIPITATION HARDENABLE ALUMINIUM ALLOY EN AW 6082 T6
1521 Nicrofer 5520 Co – Alloy 617
1522 TERMS AND TERMINOLOGY FOR WELDING PROCESSES AND WELD CONFIGURATIONS
1523 WHAT EVERY ENGINEER SHOULD KNOW ABOUT WELDING
1524 Structural Stability of Dissimilar Weld between Two Cr-Mo-V Steels
1525 Sustainability issues of research and development of forging
1526 A review of recovery of metals from industrial waste
1527 Microstructural study on retained austenite in advanced high-strength multiphase 3Mn-1.5Al and 5Mn-1.5Al steels
1528 Silicon influence on the microstructure formation at cooling rates lower than the critical rate
1529 Dilatometric examination of continuously heated austenite formation in hypoeutectoid steels
1530 Development of unconventional forming methods
1531 Fracture toughness of advanced alumina ceramics and alumina matrix composites used for cutting tool edges
1532 Mechanical and physical properties investigation of polyurethane material obtained from renewable natural source
1533 Chosen manufacture methods of Polymeric Graded Materials with electrical and magnetic properties gradation
1534 New trends in nanoscale compounds for energy storage
1535 Application of contemporary engineering techniques and technologies in the field of dental prosthetics
1536 Computer modelling and analysis of microstructures with fibres and *****s
1537 The skeleton castings as a new type of cast lattice structures
1538 Synergy effect of heat and surface treatment on properties of the Mg-Al-Zn cast alloys
1539 Measurement & instrumentation principles – 3rd editon
1540 Oerlikon compentence # 5
1541 Oerlikon compentence # 1
1542 Oerlikon compentence # 3
1543 SPECIALTY ALLOY WELDING
1544 Design* fabrication and repair of zirconium equipment in monoment service
1545 ALUMINUM GMAW Gas Metal Arc Welding for Aluminum
1546 Copper-Nickel fabrication
1547 Welding of Zirconium Alloys
1548 Residual Stress Analysis and Fatigue Assessment of Welded Steel Structures
1549 Guide to Beryllium Copper
1550 A guide to brazing & soldering
