1451 Researches concerning damage assessment of heat resistant steels used for power plant components
1452 Estimation of long-term strenght by microstructural parameters of low-alloyed steel exposed to creep
1453 STATE OF THE ART WELDING TECHNOLOGIES
1454 The effect of shielding gas compositions for MIG welding process on mechanical behaviour of low carbon steel
1455 Corrosion tests and standards
1456 Pipe welding procedures – 2nd edition
1457 THE WELDING OF ALUMINIUM MIG & TIG FUSION
1458 Growing experience with P91/T91 forcing essential code changes
1459 Slope control in welding and fusing
1460 ACCELERATED CREEP TESTS OFALL-WELDED METALS
1461 Welding and Postweld Heat Treatment of P91 Steels
1462 Questions and answers – level I* II and III – Ultrasonic testing method
1463 Questions and answers – level I* II and III – Liquid penetrant method
1464 Pitting corrosion
1465 GTAW: Training regulations
1466 Mechanics of materials
1467 Handbook of structural welding
1468 The Welding Workplace - Technology Change and Work Management for a Global Welding Industry
1469 Weldability of ferritic steels
1470 FRACTURE MECHANICS PARAMETERS OF 42CrMo4 STEEL
1471 Assessing Operating limits for C-0.5Mo steel in high temperature H2 service Hennie de Bruyn Statoil
1472 Visual Inspection Of Welds (VT)
1473 Guide for the visual inspection of welds
1474 Visual inspection of welds
1475 Pressure vessel desing manual – 3rd edition
1476 FINITE ELEMENT CREEP FAILURE ANALYSES OF P91 LARGE TENSILE CROSS-WELD SPECIMENS TESTED AT 625OC
1477 Theoretical Discussion for Creep and Fracture Mechanism of P92 Steel
1478 ROLLING-SLIDING-CONTACT FATIGUE DAMAGE OF THE GEAR TOOTH FLANKS
1479 Flux Cored Arc Welding Equipment* Setup* and Operation
1480 Construction databook – 2nd edition
1481 Effects of Welding Parameters and Electrode Atmospheric Exposure on the Diffusible Hydrogen Content of Gas Shielded Flux Cored Arc Welds
1482 Inconel alloy 617
1483 DEVELOPMENT OF BAKE HARDENING EFFECT BY PLASTIC DEFORMATION AND ANNEALING CONDITIONS
1484 Welding Consumables for P92 and T23 Creep Resisting Steels
1485 Creep Properties Of Heat Resistant Steels And Superalloys
1486 Weldability of Precipitation Hardening Superalloys – Influence of Microstructure
1487 Corrosion Resistance of Alloy 740 as Superheater Tubing in Coal-Fired Ultra-Supercritical Boilers
1488 Engineering properties of alloy 713C
1489 HAYNES® 282® ALLOY
1490 IMPROVING THE PERFORMANCE CREEP STRENGTH-ENHANCED FERRITIC STEELS
1491 UPDATE ON THE FIRESIDE CORROSION RESISTANCE OF PROPOSED ADVANCED ULTRASUPERCRITICAL SUPERHEATER AND REHEATER MATERIALS: LABORATORY AND FIELD TEST RESULTS
1492 Filler metals for welding 3Cr12
1493 RADIATION DAMAGE MICROSTRUCTURE IN Cr-Mo-V STEELS
1494 Mechanical properties and structure of the Cr-Mo-V low-alloyed steel after long-term service in creep condition
1495 Welder Certification
1496 Towards an optimized process planning of multistage deep drawing: an overview
1497 Welding stability assessment in the GMAW-S process based on fuzzy logic by acoustic sensing from arc emissions
1498 Diamond composite with Ti2SnC and Zr2SnC phases
1499 The effect of α-alumina particles on the properties of EN AC-44200 Al alloy based composite materials
1500 Preparation and properties of carbon/carbon and polymer/carbon porous monolithic composites
