1951 Joining and Processing Issues for Ferritic/Martensitic Steels
1952 The strength-related characteristics of chromium-molybdenum P5 steel dependence on postweld heat treatment parameters
1953 Current Technologies for Mechanized Pipeline Welding
1954 “Cold Metal Transfer” – Gas Metal Arc Welding CMT-GMAW Material Joining Characterization of Nickel Base Superalloy Inconel 718™
1955 Microstructural development during laser cladding of low-C martensitic stainless steel
1956 Industrial Materials for the Future R&D Strategies: A Case Study of Boiler Materials for the Pulp and Paper Industry
1957 Welding Processes and Technology
1958 The T92/P92 book
1959 Why new U.S. supercritical units should consider T/P92 piping
1960 Pressure Equipment Directive 97/23/EC
1961 1.4541 material
1962 1.4571 material
1963 Freshly generated stainless steel welding fume induced greater lung inflammation in rats as compared to aged fume
1964 Measurement System Analysis And Destructive Testing
1965 The Atlas specialty metals: Technical handbook of bar products
1966 Effect of High Heat input on CTOD Property of the Thick Steel Plate for Offshore Engineering
1967 Effect of weld heat input on toughness and structure of HAZ of a new super-high strength steel
1968 Influence of heat input on corrosion resistance of SAW welded duplex joints
1969 The effect of heat input on residual stress distribution of steel welds measured by neutron diffraction
1970 High Heat Input/Reduced Preheat
1971 Heat flow in welding
1972 Proper PWHT can stop stress-induced corrosion
1973 Quality assurance in field heat treatment
1974 Induction heating delivers production benefits
1975 Presentation of paper on weldability of LNG hull steels
1976 A TORQUE-BASED WELD POWER MODEL FOR FRICTION STIR WELDING
1977 IMPROVEMENT OF WELD HAZ TOUGHNESS AT LOW HEAT INPUT BY CONTROLLING THE DISTRIBUTION OF M-A CONSTITUENTS
1978 A look at heat input
1979 390 MPa Yield Strength Steel Plate for Large Heat-input Welding for Large Container Ships
1980 REFERENCE COMPILATION OF PARENT MATERIAL STRESS RUPTURE PROPERTIES FOR CONFORMITY ASSESSMENT OF WELDING CONSUMABLES
1981 Low Heat Input Welding by Continuous-Wave Nd:YAG Laser Processing
1982 What Is Heat Input* and How Does It Affect the Quality of Welds?
1983 Pressure- and activity-retaining components of systems outside the primary circuit Part 3: Manufacture
1984 Moly review July 2009
1985 Physicochemical properties of Cr-Ni-Mo steel and Co-Cr-W-Ni alloy applied in urology
1986 Effect of in Service Weld Repair on the Performance of CrMo Steel Steam Pipelines
1987 Martensite formation in 9 Cr-1 Mo steel weld metal and its effect on creep behavior
1988 Electrochemical Behavior of Cr-Mo Steel Alloy in High Temperature Aqueous Sodium Chloride Solution
1989 Microstructure and mechanical properties of Cr-Mo steels for nuclear industry applications
1990 ENVIRONMENTAL DEGRADATION OF THE Cr-Mo STEELS IN LIQUID HYDROCARBONS
1991 Avesta: Standard Cr-Ni-Mo Stainless Steels
1992 Transition Joints Aluminium CrNi-Steels
1993 Lloyd NonStop – edition 1/2009
1994 Essential Factors in Selecting Heat- Resistant Low Alloy Filler Metals for High- Temperature* High-Pressure Services in the Power Generation* Oil Refining* and Petrochemical Industries
1995 MECHANICAL PROPERTIES OF COMPONENTS MADE FROM Fe(Cr*Mo) PM STEELS
1996 Weld-Ring Gaskets
1997 Chromium Diffusion Coatings on Low-Alloyed Steels for Corrosion Protection Under Sulphidizing Conditions
1998 The Influence of Gas Heating on Material Properties of P92 Steel During Boiler Tube Alignment
1999 Application of thermovision method to welding thermal cycle analysis
2000 The high alloy precipitation hardening martensitic steels and their suitability for welding
