951 Health and Safety in Welding and Allied Processes
952 MICROSTRUCTURAL EVOLUTION DURING FRICTION STIR WELDING OF AlSi1MgMn ALLOY
953 Tensile testing – 2nd edition
954 On-line monitoring system – AN application for monitoring key welding parameters of different welding processes
955 Welded design theory and practice
956 KOBELCO WELDING CONSUMABLES FOR HEAT-RESISTANT LOW-ALLOY STEEL 3rd Special Edition
957 Oerlikon welding consumables
958 Prediction of fracture toughness temperature depending applying neural network
959 Non destructive testing handbook vol. 2: Liquid penetrant testing
960 Pipe sizing. What is ID and OD?
961 POSSIBILITIES OF IMPLEMENTING BIMETALLIC HAMMER CASTINGS IN CRUSHING INDUSTRIES
962 Relationship betvveen Fracture Toughness and mechanical Properties of some Structural Steels at Low Temperatures
963 Welding abstarcts december 2011
964 Development of a New Class of Fe-3Cr-W(V) Ferritic Steels for Industrial Process Applications
965 Physical mettalurgy and advanced materials
966 Advanced high-strenght steel repairability – phase 1
967 Corrosion resistance
968 Fundamentals and applications of ultrasonic waves
969 STEEL FORMING AND HEAT TREATING HANDBOOK
970 IMPROVING THE PERFORMANCE CREEP STRENGTH-ENHANCED FERRITIC STEELS
971 Advanced Pressure Boundary Materials: Evaluation of Specification Ranges for Creep-Strength-Enhanced Ferritic Steels
972 Stainless steels: Tables of technical properties
973 Non destructiove handbook vol 4: Radiographic testing
974 Improving the performance of creep strenght enhanced ferritic (CSEF) steels
975 Develpoment and use of weld repair methodologies in the USA
976 Effect of Postweld Heat Treatment on Microstructures and Hardness of TIG Weldment between P22 and P91 Steels with Inconel 625 Filler Metal
977 EPRI: Welding & Repair Technology Center Program Overview
978 Preliminary Materials Selection Issues for the Next Generation Nuclear Plant Reactor Pressure Vessel
979 Review of Dissimilar Metal Welding for the NGNP Helical-Coil Steam Generator
980 Welding techniques
981 Welding-properties-of-fusion-welding
982 Joint-weld terminology and standard welding symbols interpretation
983 TWI: Weld defects
984 EPRI: Evaluation of Filler Materials for Transition Weld Joints Between Grade 91 to Grade 22 Components
985 Advanced weld repair technology extends plant life
986 Preliminary Materials Selection Issues for the Next Generation Nuclear Plant Reactor Pressure Vessel
987 EPRI: Nondestructive Evaluation: Guideline for Conducting Ultrasonic Examinations of Dissimilar Metal Welds
988 An Evaluation of Former Soviet Union Welding Processes on Commercially Pure Titanium
989 HEAT RESISTANT ALLOYS
990 Microstructures of Brazings and Welds Using Grade 2 Commercially Pure Titanium
991 STRENGTH AND DUCTILITY OF WELDED JOINTS SUBJECTED TO OUT‐OF‐PLANE BENDING
992 SELECTION OF MATERIALS FOR PROTOTYPE FAST BREEDER REACTOR
993 Acoustic emission monitoring for inspection of seam-welded hot reheat piping in fossil power plants
994 Welding - Design Procedures And Inspections
995 Microstructural Changes in Grade 22 Ferritic Steel Clad Successively with Ni-Based and 9Cr Filler Metals
996 New Socket Weld Repair Method: Strong and Effective
997 Effects of weld preheat temperature and heat input on type IV failure
998 Type IV *****ing in Modified 9Cr-1Mo Steel Weld Joint
999 INVESTIGATION OF INFLUENCE REINFORCEMENTS IN CIRCUMSTANCES WHEN THE ASYMMETRIC LOAD ACTING ON GIRDER
1000 SIMILAR AND DISSIMILAR WELD JOINTS OF CREEP-RESISTING STEELS
