1701 Welding operations 1
1702 A Welding Data Dictionary
1703 Welding journal – March 2006
1704 Stahlbau profile – 24th edition
1705 Handbook of Comparative World Steel Standards – 3rd edition
1706 Welding of stainless steel
1707 TUV kennblatt
1708 Piping design handbook
1709 Welding CrMo steels for power generation and petrochemical applications - past* present and future
1710 ANALYSIS OF PROBLEMS OCCURED DURING WELDING OF NEW GENREATION BAINITIC STEEL 7CrMoVTiB10-10 (T24)
1711 Corrosion of steels in H2O-CO2 atmospheres at temperatures between 500°C and 700°C
1712 Welding of High Pressure* Temperature Tube and Pipework
1713 THE INVESTIGATION OF APPLICABILITY OF THE HOLLOMON-JAFFE EQUATION ON TEMPERING THE HSLA STEEL
1714 EFFECT OF WELDING ON THE PROPERTIES OF HR3C* SUPER 304H* TP347HFG AND P92 STEELS
1715 Changes in the structure of VM12 steel after being exposed to creep conditions
1716 EPRI: EPRI Conference on 9Cr Materials Fabrication and Joining Technologies
1717 EPRI: Hexavalent Chromium Air Sampling Data from Welding and Steel Cutting
1718 Mathematical Model for Tempering Time Effect on Quenched Steel Based on Hollomon Parameter
1719 Welding of the austenitic alloys Super 304H* 310N and 347H FG
1720 Steel detailers' manual – 3rd edition
1721 Flexural Testing of Weld Site and HVOF Coating Characteristics
1722 Advanced welding systems: Fundamentals of fusion welding technology
1723 EWE 2000
1724 KKS Handbook – 7th edition
1725 Fatigue of structures and materials – 2nd edition
1726 Creep properties and damage behaviour of component-like tubes of Vm12-materials
1727 EPRI: Nondestructive Evaluation: Indication Characterization* Evaluation* and Disposition Guideline
1728 EPRI: Nondestructive Evaluation: NDE for Type 304/316 Stainless Steel Material Characterization
1729 Quality management at RWE using T24 boiler material as an example
1730 ACCELERATED CREEP TESTS OFALL-WELDED METALS
1731 Requirements concerning MATERIALS AND WELDING
1732 ANALYSIS OF PROBLEMS OCCURED DURING WELDING OF NEW GENREATION BAINITIC STEEL 7CrMoVTiB10-10 (T24)
1733 VM12-SHC Technical datasheet
1734 High performance materials and corrosion control for efficient and low emission biomass and waste combustion (HICOR) – final report
1735 Post-fabrication clean up
1736 ASME PCC-1:2000 - GUIDELINES FOR PRESSURE BOUNDARY BOLTED FLANGE JOINT ASSEMBLY
1737 AWS: The practical welding engineer
1738 Bechtel Rigging Handbook – 2nd edition
1739 EWF documents
1740 The 101 essential elements in a pressure equipment
1741 Corrosion and Corrosion Protection
1742 Thermal Spray Manual
1743 Corrosion protection of rolled steel sections using hot-dip galvanization
1744 AWS: Filler metal comparision charts
1745 IIW Guideline INTERNATIONAL WELDER Minimim Requirements for the Education* Examination and Qualification
1746 Journal of pipeline engineering – June 2012
1747 Mechanical Engineer's Handbook
1748 Metallurgy of welding – 6th edition
1749 TOPTIG A new robot welding process for industry
1750 SCHAEFFLER DIAGRAM CALCULATION OF STRUCTURE FOR STAINLESS STEELS
