1901 INCONEL® alloy 686 The Corrosion-Resistant Alloy for the 21st Century
1902 Norsok: Material data sheets for structural steel
1903 Microprocesses of metal dusting on iron-nickel alloys and their dependence on the alloy composition
1904 Nicrofer® 3718/3718 So❋ – alloy DS
1905 Lincoln: Making Butt Welds with Power Wave AC/DC 1000™ Technology
1906 Delta ferrite prediction in stainless steel welds using neural network analysis and comparison with other prediction methods
1907 Stainless Steel Comparator
1908 Avesta: Stainless steels
1909 The metal dusting corrosion of steels with varying concentrations of chromium
1910 ACCEPTANCE CRITERIA FOR COMPLETED WELDS
1911 NDT of materials
1912 Finite elements analysis with error estimators
1913 Gas turbine handbook
1914 Machinery's handbook – 26th edition
1915 Guide to the Use of Tables and Formulas in Machinery’s Handbook 28th Edition
1916 Machinery's handbook – 28th edition
1917 Conveyors: Application* selection and integration
1918 Belt Conveyors for Bulk Materials
1919 Compressors: Selection and Sizing
1920 Phoenix Conveyor Belts Design FundamentalsNew
1921 Eliptical head calculation
1922 Energy management handook – 6th edition
1923 Engineering design – 3rd edition
1924 Machinery component maintenance and repair – volume 3
1925 Dictionary of engineering – 2nd edition
1926 Piping training course
1927 Plant design and economics for chemical engineers
1928 Rules of thumb for chemical engineers
1929 Structure-property relations in nonferrous metals
1930 Standard handbook of engineering calculations
1931 Welding journal – march 2009
1932 Gas Welding Safety
1933 GAS METAL ARC WELDING OF STAINLESS STEEL
1934 Oxy-Acetylene Welding
1935 WELDING FUME AND GAS EXPOSURE
1936 Metrode 2009 cd
1937 Investigations on oxidation and corrosion carachteristics of the advanced boiler materials at steam temperatures up to 720° C
1938 Defining the Materials Issues and Research for Ultra-Supercritical Steam Turbines
1939 Austenitic steels –mechanical properties* exfoliation* availability
1940 EsbjergUnit 3-Investigation of AdvancedMaterialsat Steam Temperaturesup to 720 °C
1941 460 MWe SUPERCRITICAL CFB BOILER DESIGN FOR ŁAGISZA POWER PLANT
1942 FIRESIDE CORROSION RESISTANCE OF PROPOSED USC SUPERHEATER AND
REHEATER MATERIALS: LABORATORY AND FIELD TEST RESULTS
1943 Fatigue Properties of As-Welded and Postweld Heat Treated Type 410SS Repair Welds for Steam Turbine Components
1944 Develpoment of matching composition supermartensitic stainless steel welding consumables
1945 The new revolution in digital GMA welding
1946 Significance of *****s in the heat-affected-zone of steels for elevated temperature application
1947 Embrittlement Prediction of Aged Austenitic Stainless Steel Welded Components Using Hardness Measurements
1948 Stainless steels
1949 AUTOMATIC PIPE BUTT WELDING PROCESSES IN STEAM BOILERS PRODUCTION
1950 High-strenght and highly weldable rolled section plates for the modern steel construction
