1851 PIPING DESIGN QUESTIONAIRE
1852 Fillet Weld Legs Determine Size and Throat of Fillet Welds
1853 Guide on selection of welding electrodes
1854 Inspection of Dissimilar Metal Welds in Reactor Pressure Vessels in Spain
1855 Castolin eutectic technical data book 2007
1856 Mechanical properties and corrosion resistance of dissimilar stainless steel welds
1857 Development of Weldable Super 13Cr Martensitic Stainless Steel for Flowline
1858 Effect of Alloy Grain Size on the High-TemperatureOxidation Behavior of the Austenitic Steel TP 347
1859 Effect Of Off-Normal Austenization On Creep Strength Of Ferritic-Martensitic Steels
1860 EPRI: Materials Reliability Program: Resistance of Alloys 690* 152* and 52 to Primary Water Stress Corrosion *****ing (MRP-237* Rev. 2)
1861 The potential of modified type 310 stainless steel for advanced fossil energy applications
1862 Corrosion of Hafnium and Hafnium Alloys
1863 Corrosion of Duplex Stainless Steels in Seawater
1864 AWS Level III - Expert Welder - - Guide for the Training and Qualification of Welding Personnel
1865 Dilution and microsegregation in dissimilar metal welds between super austenitic stainless steel and nickel base alloys
1866 PROPERTIES OF SUMITOMO 347AP STEEL TUBE FOR HYDRO-TREATER IN COMPLEX REFINERY
1867 Numerical Simulation of Hydrogen Assisted *****ing in Supermartensitic Stainless Steel Welds
1868 Development of DP28W™ duplex stainless
1869 Carbon migration across dissimilar metal welds* related to power plant
1870 Tess: Welding consumables for the petrochemical industry
1871 Effect on carbon migration on creep properties of Cr5Mo dissimilar welded joints with Ni-based and austenitic weld metal
1872 Austenitic Stainless Steels and Alloys With Improved High-Temperature Performance for Advanced Microturbine Recuperators
1873 Kobelco welding handbook 2012
1874 ELGA: Storage and handling of welding consumables
1875 The ferritic solution
1876 EPRI: Borated stainless steel joining technology
1877 EPRI: Properties of modified 9Cr-1Mo cast steel
1878 EFFECT oF CARBoN M IGRATIoN 0N CREEP PRoPERTIES oF Cr5M o DISSIM ILAR W ELDED JoINTS W ITH Ni-BASED AND AUSTENITIC W ELD M ETAL
1879 Welding Terminology
1880 General characteristics of stainless steels Basic requirements and behaviour of Stainless electrode coatings Cromarod – Stainless product programme
1881 Welding & repair technology for fossil power plants
1882 Ontario Hydro Experience with Dissimilar Metal Welds in Boiler Tubing
1883 Welding Behavior and Microstructure of a Ni3AI Alloy
1884 BWG seminar – Zdjelarevic 2013
1885 T-Put conference
1886 VDI conference 2012
1887 Hitachi: Air Quality Control Systems and Components
1888 DWT – Boiler seminar 2009
1889 Boiler Needs Survey Responses Forest Products Industry
1890 Gas Boilers
1891 Optimisation of welding parameters for weld penetration in FCAW
1892 Metal dusting of nickel-base alloys
1893 Manual of Steel Construction Load and Resistance Factor Design 3rd Edition
1894 Supply and use of vanadium
1895 Materials develpoment for boilers and steam turbines operating at 700°C
1896 Alloy design for similar and dissimilar welding and their behaviours
1897 Influence of high temperature exposure on the mechanical behavior and microstructure of 17-4 PH stainless steel
1898 EFFECT OF STRAIN-INDUCED ?’-MARTENSITE TRANSFORMATION ON MECHANICAL PROPERTIES OF METASTABLE AUSTENITIC STAINLESS STEELS
1899 EPRI: X20 CrMoV12-1 Steel Handbook
1900 Advanced Materials for AD700 Boilers
