1601 EPRI: Effect of Cold Work and Heat Treatment on the Elevated-Temperature Rupture Properties of Grade 91 Material
1602 EPRI: Investigation of Thickness Limits for Post Weld Heat Treatment (PWHT) Exemption
1603 EPRI: NDE Training Activities
1604 EPRI: Materials Handbook for Nuclear Repair Applications
1605 EPRI: Status Review of Initiation of Environmentally Assisted *****ing and Short ***** Growth
1606 EPRI: Materials Reliability Program: Selection of Materials and Fabrication of Weldments
for Investigation of PWSCC Susceptibility in the Alloy 600 and 690 Weld Heat Affected Zones (MRP-161)
1607 EPRI: Flue Gas Desulfurization Systems Component Material Performance and Welding
1608 EPRI: Dissimilar Metal Weld Configuration Management Database
1609 EPRI: CoalFleet Guideline for Advanced Pulverized Coal Power Plants
1610 EPRI: The Grade 22 Low Alloy Steel Handbook
1611 EPRI: Materials Reliability Program: Technical Basis for Preemptive Weld Overlays for Alloy 82/182 Butt Welds in PWRs (MRP-169)
1612 EPRI:Topical Report Supporting an Expedited NRC Review of the Content of the Code Case needed for Dissimilar Metal Weld Overlay Repairs
1613 EPRI: The Grades 11 and 12 Low Alloy Steel Handbook
1614 EPRI: Stress Corrosion *****ing of Grade 91 Materials
1615 EPRI: Repair and Replacement Applications Center: Investigation of Thickness Limits for Post Weld Heat Treatment (PWHT) Exemption
1616 EPRI: Repair and Replacement Applications Center: Stress Corrosion *****ing in Closed Cooling Water Systems
1617 EPRI: Repair and Replacement Applications Center: Topical Report Supporting Expedited NRC Review of Code Cases for Dissimilar Metal Weld Overlay Repairs
1618 EPRI: Nondestructive Evaluation: Dissimilar Metal Weld (DMW) Configuration Database
1619 EPRI: Materials Reliability Program: Advanced FEA Evaluation of Growth of Postulated Circumferential PWSCC Flaws in Pressurizer Nozzle Dissimilar Metal Welds (MRP-216)
1620 EPRI: Materials Reliability Program: Advanced FEA Evaluation of Growth of Postulated Circumferential PWSCC Flaws in Pressurizer Nozzle Dissimilar Metal Welds (MRP-216* Rev. 1)
1621 EPRI: Materials Reliability Program: Inspection and Evaluation Guidelines for Reactor Vessel Bottom-Mounted Nozzles in U.S. PWR Plants (MRP-206)
1622 EPRI: Hexavalent Chromium Air Sampling Data from Welding and Steel Cutting
1623 EPRI: Nondestructive Evaluation: Guideline for Conducting Ultrasonic Examinations of Dissimilar Metal Welds
1624 EPRI: Development of a New Nickel Filler for Dissimilar Metal Welds and Repair
1625 EPRI: Welding and Repair Technology Center: Evaluation of Post Weld Heat Treatment (PWHT) Exemption Thickness Limitations
1626 EPRI: Repair Methods for Dissimilar Metal Welds— Development* Weldability* and Properties of EPRI P87 Solid Wire Filler Metal
1627 EPRI: Materials Reliability Program: Technical Basis for Preemptive Weld Overlay for Alloy 82/182 Butt Welds in Pressurized Water Reactors (PWRs) (MRP-169) Revision 1-A
1628 EPRI: Materials Reliability Program: Welding Residual Stress Dissimilar Metal Butt-Weld
Finite Element Modeling Handbook (MRP-317)
1629 EPRI: Guidelines and Specifications for High-Reliability Fossil Power Plants Best Practice Guideline for Manufacturing and Construction of Grade 91 Steel Components
1630 EPRI: Program on Technology Innovation: Environmental and Health Issues Related to Radiofrequency Emissions from Smart Grid Technologies
1631 EPRI: Relationship Between Alloy Chemistry* Hardenability* and Creep Behavior of Code Case 2199 (T23)
1632 EPRI: Materials Reliability Program: PWR Reactor Coolant System Cold-Loop Dissimilar Metal Butt Weld Reexamination Interval Extension (MRP-349)
1633 EPRI: Critical Issues Report and Roadmap for the Advanced Radiation-Resistant Materials Program
1634 EPRI: Dissimilar weld failure analysis and development program vol. 8: Design and procedure guide for improved welds
1635 EPRI: Ambient temperature preheat for machine GTAW temperbead applications
1636 EPRI: Proceedings: 1983 workshop on secondary side stress corrosion *****ing and intergranular corrosion of PWR steam generator tubing
1637 EPRI: Proceedings: 1986 workshop on advanced high-strenght materials
1638 EPRI: Norem wear-resistant iron.based hard-facing alloys
1639 EPRI: Cobalt reduction guidelines
1640 EPRI: Inconel weld-overlay repair for low-alloy steel nozzle to safe-end joint
1641 EPRI: Underwater Maintenance Guide: Revision 2
1642 EPRI: Welding best practices survey
1643 EPRI: SMAW temperbead weld repair without grinding
1644 EPRI: New materials for advanced steam turbines – Volume 5: Survey of superalloy bolt failures in high-temperature services
1645 EPRI: Magnetic replicas and the very incomplete meissner effect
1646 EPRI: Temperbead welding repair of low alloy pressure vessel steels: Guidelines
1647 EPRI: Review of steam generator girth weld *****ing
1648 EPRI: State-of-the-art weld repair technology for high temperature and pressure parts – Volume 2: Repair guideline
1649 EPRI: State-of-the-art weld repair technology for high temperature and pressure parts – Volume 5: Weld repair of 1-1/4Cr-1/2 Mo piping girth welds
1650 EPRI: State-of-the-art weld repair technology for high temperature and pressure parts – Volume 7: Weld repair of aged piping – A literature review
