1651 EPRI: Steam Generator Reference Book
1652 EPRI: Valve Application* Maintenance and Repair Guide (In Situ State-of-the-Art Valve Welding Repair)
1653 EPRI: State-of-the-Art Weld Repair Technology for Rotating Components Volume 1: Weld Repair of Steam Turbine Discs andRotors
1654 EPRI: Proceedings: Welding and repair technology for power plants – second international conferecne
1655 EPRI: On-Line Welding Repair for Leaking Pipe Components
1656 EPRI: Guideline for underwater welding to achieve acceptable ferrite number (FN) for stainless steel
1657 EPRI: Machine Welding Equipment for In Situ Piping Installation and Repairs
1658 EPRI: Influence of Irradiation and Stress/Strain on the In-Reactor Behavior of High Purity Stainless Steels & Ni-Based Alloys
1659 EPRI: Weld overlay of waterwall tubing* alternative materials and distortion
1660 EPRI: 1998 Repair & Replacement Applications Center – Product Report
1661 EPRI: Non-Destructive Evaluation of the Oyster Creek Top Guide Samples
1662 EPRI: Vibration fatigue testing of socket welds
1663 EPRI: Welding and repair technology for power plants
1664 ESAB: welding handbook – 5th edition
1665 Hardening* tempering and heat treatment
1666 ANSI/AWS A5.1-91 E6013 Rutile Electrodes: The Effect of Calcite
1667 Consumables and welding modified 9Cr-1Mo steel
1668 CREEP RESISTANT FERRITIC STEELS FOR POWER PLANTS
1669 THE MECHANICAL PROPERTIES AND MICROSTRUCTURES OF 9% CHROMIUM STEEL P92 WELDMENTS
1670 Performance of P91 Thick Section Welds Under Steady and Cyclic Loading Conditions: Power Plant and Research Experience
1671 Carbon and nitrogen redistribution in weld joints of heat resistant steels
1672 Alloy design for similiar and dissimilar welding and their behaviours
1673 Austenite to Martensite Phase Transformation in 9 Cr 1 Mo Steel Weld Metal
1674 NDE methods
1675 Bohler welding guide 09/2006
1676 Corrosion resistant alloys for oil and gas production
1677 Assessing the Benefits of Surface Tension Transfer® Welding to Industry
1678 THICK SECTION WELDED HCM2S (P23)
1679 Geometric dimensioning and tolerancing for mechanical design
1680 GMAW Welding Guide
1681 Welding for arts & crafts
1682 Lecture 4a: Alloys; Heat Treatment
1683 Lecture 4b: Alloys; Heat Treatment
1684 Magnesium – Alloys and technologies
1685 Rule Requirements for Materials and Welding 2000 Supplementary Requirements for Naval Vessels
1686 INTRODUCTION TO NONDESTRUCTIVE TESTING
1687 MODERN FERRITE TECHNOLOGY
1688 Microstructural Evolution in Two Variants of NF709 at 1023 and 1073 K
1689 RapidArc™— High Speed GMAW Welding
1690 DESIGN OF POLYMER BASED DIRECTIONAL COUPLER THERMOOPTIC OPTICAL SWITCH
1691 Simulation of Dissimilar Weld Joints of Steel P91
1692 MAGNETIC PERMEABILITY OF STAINLESS STEEL FOR USE IN ACCELERATOR BEAM TRANSPORT SYSTEMS
1693 FAC* field hardness testing of P91/T91* piping issues dominate program
1694 SME 2713 Manufacturing Processes
1695 Special metals – joining
1696 Structural Steel Welding
1697 A CREEP-PROPERTIES EVALUATION OF P91 STEEL WELDMENTS USING SHORT-TERM TESTING
1698 Properties of T/P92 CrMo weld metals for ultra super critical (USC) power plant
1699 Welding errors
1700 TWI: Welding inspection – codes and standards
