2201 ANALYSIS OF FACTORS AFFECTING FRACTURES OF RAILS WELDED BY ALUMINO-THERMIC WELDING
2202 WELDING OF NICKEL BASE SUPERALLOY SINGLE CRYSTALS
2203 ELEVATED-TEMPERATURE FERRITIC AND MARTENSITIC STEELS AND THEIR APPLICATION TO FUTURE NUCLEAR REACTORS
2204 MOLYBDENUM
2205 Microstructure And Strength Characteristics Of Alloy 617 Welds
2206 DESIGN AND FABRICATION OF A POLYMER BASED DIRECTIONAL COUPLER THERMOOPTIC SWITCH
2207 Behavior of Quenched and Tempered Steels under High Strain Rate Compression Loading
2208 MICROSTRUCTURE – MECHANICAL PROPERTY RELATIONSHIPS IN TRANSIENT LIQUID PHASE BONDED NICKEL-BASED SUPERALLOYS AND IRON-BASED ODS ALLOYS
2209 S t u d T e n s i l e -T o r q u e S t r e n g t h s
2210 A r c S t u d W e l d i n g
2211 Aspects of the modeling of high-cycle fatigue
2212 Bohler: Welding guide 01/2008
2213 Corrosion control . 3rd edition
2214 Advanced USC Technology Development in Japan
2215 Corrosion-resistant Fastenings
2216 FURTHER INVESTIGATION OF STANDOFF SCREWS USED IN COMPOSITE JOISTS
2217 Financial Justification of Nondestructive Testing
2218 Gas Welding Safety
2219 POST WELD HEAT TREATMENT OF WELDED STRUCTURES
2220 HAYNES® 625 alloy
2221 Practical hardness testing
2222 Reactor dmaage overhaul in the course of integrity restoring and service life extension
2223 Production and Properties of Common Engineering Materials; Heat Treatment
2224 Materials
2225 Materials Chemistry
2226 ABOUT SOME VARIOUS INTERPRETATIONS OF THE FATIGUE CRITERION AT LOW NUMBER OF STRAIN CYCLES
2227 ERECTION OF A STAINLESS-STEEL TANK FOR STORING A PHOSPHORIC ACID
2228 Microstructural Evolution in Two Variants of NF709 at 1023 and 1073 K
2229 Properties and Typical Applications of Selected Nickel Alloys
2230 DESIGN OF POLYMER BASED DIRECTIONAL COUPLER THERMOOPTIC OPTICAL SWITCH
2231 MAGNETIC PERMEABILITY OF STAINLESS STEEL FOR USE IN ACCELERATOR BEAM TRANSPORT SYSTEMS*
2232 Physical mettalurgy and advanced materials – 7th edition
2233 Radiographer's weld interpretation reference
2234 Short description of the aluminothermic rail welding process
2235 Development of a PF Fired High Efficiency Power Plant (AD700)
2236 Aluminothermic Welding Manual
2237 Structural steel
2238 Guide to stainless steel finishes
2239 Stainless steels
2240 stainless steels and their properties
2241 Steel weld metallurgy
2242 SHIELDED METAL ARC WELDING
2243 Stud Welding Fasteners
2244 Surface engineering of metals
2245 THE LONG-TERM MANAGEMENT OF TANK WASTE AT HANFORD
2246 The QA* Material Testing and NDT Services Experts
2247 TECHNICAL BID SPECIFICATION AND NOTICE INVITING TENDER
2248 Defect detection in partially complete SAW and TIG welds using on-line radioscopy and image processing
2249 AWS: The practical reference guide for welding inspection management – Visual inspection of pressure vessels and pressure piping
2250 Intelligent Robotic GTAW System for 3D Welding
