2101 OPTIMIZATION OF CONCENTRATIONS OF ALLOYING ELEMENTS IN STEEL FOR MAXIMUM TEMPERATURE* STRENGTH* TIME-TO-RUPTURE AND MINIMUM COST AND WEIGHT
2102 Brazing cast iron-no longer a problem?
2103 Material and Weld Testing
2104 EXCEL IMPLEMENTATION OF SCHAEFFLER AND DELONG DIAGRAMS
2105 COMMON HF WELDING DEFECTS
2106 Use Undermatching Weld Metal Where Advantageous
2107 GUIDELINES FOR PIPELINE REPAIR BY DIRECT DEPOSITION OF WELD METAL
2108 FIELD WELDING AND CUTTING DUCTILE IRON PIPE
2109 High Strength Low Alloy Steel (HSLA) Ultra Low Carbon Steel Advance High Strength Steel
2110 Weld region representation during the simulation of TWB forming behavior
2111 Residual stresses during various pre and post-heating procedures for cold *****ing avoidance in high strenght structural steel welds
2112 Selecting Filler Metals: Matching Strength Criteria
2113 EFFICIENT LOW-ALLOY STEELS FOR HIGH PERFORMANCE STRUCTURAL APPLICATIONS
2114 Norsok: STRUCTURAL STEEL FABRICATION
2115 RECOMMENDED GOOD PRACTICE MATERIALS AND WELDING GUIDELINES FOR
BLACK LIQUOR RECOVERY BOILERS
2116 THE EFFECT OF SOLUTION ANNEALING ON PROPERTIES OF STEEL NITRONIC 60
2117 Experienced filler metals for increasing power plant efficiency
2118 The Stress-Relief *****ing Susceptibility of a New Ferritic Steel — Part 2: Multiple-Pass Heat-Affected Zone Simulations
2119 AN OVERVIEW OF THE PIPELINE DEFECT ASSESSMENT MANUAL (PDAM)
2120 Development of An Automated Inspection System for Welding Defect Detection
2121 Poster: ALL WELD METAL TENSION TEST
2122 Preheating in Welding Technology
2123 Avesta: Pickling handbook
2124 ESAB: Repair and Maintenance Welding Handbook
2125 CONDITION ASSESSMENT PROGRAMS FOR BOILER AND PIPING COMPONENTS AT THE BIG CAJUN II POWER STATION
2126 GTAW root pass welding of 6% molybdenum austenitic stainless steel pipe ! open root joint with hand-fed filler
2127 SCHAEFFLER DIAGRAM CALCULATION OF STRUCTURE FOR STAINLESS STEELS
2128 Application of the Schaeffler diagram
2129 Liquid Penetrant and Magnetic Particle Testing at Level 2
2130 Effects of nickel on irradiation embrittlement of light water reactor pressure vessel steels
2131 AN AES INVESTIGATION OF BRUSHED AISI 304 STAINLESS STEEL AFTER CORROSION TESTING
2132 APPLICATION OF ARTIFICIAL NEURAL NETWORKS TO EVALUATE WELD DEFECTS OF NUCLEAR COMPONENTS
2133 Weld *****ing
2134 Weld Design and Specification
2135 Welding of BISPLATE® Quenched and Tempered Steels
2136 WELDING AND COATING METALLURGY
2137 Welding of Hydrogen-Charged Steel for Modification or Repair
2138 High speed fusion weld bead defects
2139 Welding Defects* Causes and Prevention
2140 SPECIFICATION FOR WELDING REPAIRS
2141 High quality through high end technology on LSAWlarge diameter pipes
2142 ANALYSIS OF LACK OF FUSION IN WELDS AT WATER HEATERS
2143 Analysis of Ultrasonic Indications in Lack of Fusion Occurring in Welds
2144 Post Weld Heat Treatment Procedure
2145 Fatigue and Repair Cases in Steel Bridges
2146 Microstructural and Mechanical Characterization of High Temperature and Creep Resistant Steel Weldments
2147 TWI: Practical Plate Exercise
2148 TWI: Welding Inspection Defects/Repairs
2149 Effect of Defects on Fatigue Strength of GTAW Repaired Cast Aluminum Alloy
2150 INSTRUCTION OF WELDING AND REVIEW OF STEELS FOR POWER PLANT EQUIPMENT AND POSSIBILITY OF USING HAZ SIMULATION IN ORDER IMPROVE WELD JOINT QUALITY
