1751 Application of the Schaeffler diagram
1752 The Ferrite Content of Austenitic Stainless Steel Weld Metal
1753 Prediction of Austenitic Weld Metal Microstructure and Properties
1754 Sensitivity Analysis of Half-Bead and Alternative GTAW Techniques
1755 Predictive and Measurement Methods for Delta Ferrite Determination in Stainless Steels
1756 Effect of Postweld Heat Treatment on the Toughness of Heat-Affected Zone for Grade 91 Steel
1757 Welding Metallurgy of Stainless Steels
1758 Introduction to health and safety at work
1759 Introduction to health and safety in construction
1760 IEEE Recommended Practice for Electric Power Distribution for Industrial Plants
1761 Martensite formation in 9 Cr-1 Mo steel weld metal and its effect on creep behavior
1762 IIW: 141 - TIG WELDING OF STAINLESS STEEL
1763 Penetrant and Magnetic Particle Testing with Blue Light
1764 THE DEVELOPMENT OF CONFIDENCE LIMITS FOR FATIGUE STRENGTH DATA
1765 Weld cost calculation
1766 American National Standard for Metric Practice
1767 MICROSTRUCTURAL INVESTIGATION OF THE HEAT-AFFECTED ZONE OF SIMULATED WELDED JOINT OF P91 STEEL
1768 SMAW and CO2 weld cost
1769 Weld Testing Using Phased Arrays
1770 WRC bulletin 452
1771 Microbiological Degradation of Materials - and Methods of Protection
1772 Guidelines on Materials Requirements for Carbon and Low Alloy Steels For H2S-Containing
Environments in Oil and Gas Production
1773 Corrosion Resistant Alloys for Oil and Gas Production: Guidance on General Requirements and Test Methods for H2S Service
1774 CO2 Corrosion Control in Oil and Gas Production
1775 Marine Corrosion of Stainless Steels
1776 Corrosion in rafineries
1777 Amine unit corrosion in refineries
1778 Corrosion-under-insulation (CUI) guidelines
1779 Guidance Notes for Welding Companies Using Thoriated Tungsten Electrodes
1780 Health Hazards Of Welding
1781 ESAB: Welding guide for the joining of dissimilar metals
1782 DVS poster: qualification test certificate ACCORDING TO EN ISO 9606-1:2013
1783 Radiation Hazards with the Use of Tungsten Welding Rods Containing Thorium
1784 WELDING: FUMES AND GASES
1785 Health and Safety in Welding
1786 Determination of major and minor ash-forming elements in solid biofules
1787 Modeling of aerosol formation during biomass combustion for various furnace and boiler types
1788 Comparative characterization og high temperature aerosols in waste wood fired fixed-bed and fluidised-bed combustion systems
1789 Corrosion in fire tube boilers of biomass combustion plants
1790 NOx REDUCTION IN BIOMASS GRATE FURNACES BY PRIMARY MEASURES - EVALUATION BY MEANS OF LAB-SCALE EXPERIMENTS AND CHEMICAL KINETIC SIMULATION COMPARED WITH EXPERIMENTAL RESULTS AND CFD CALCULATIONS OF PILOT-SCALE PLANTS
1791 RADIOGRAPHIC QUALITY ASSESSMENT OF WELDED JOINTS IN BUILDING STRUCTURES PRODUCED ACCORDING TO REQUIREMENTS OF STANDARD EN-1090-2* QUALITY LEVEL “B +”
1792 Control of welding distortion in thin-plate fabrication
1793 Perspectives on Technical Brief
1794 Metalworking: Tips and Tricks for Machinists* Welders* and Fabricators
1795 IIW: Introductory fatigue tests on welded joints in high strength steel and aluminium improved by various methods including ultrasonic impact treatment (UIT)
1796 TWI: Welding inspection questions
1797 TECHNICAL DESCRIPTION welding
1798 Modeling and simulation of microstructure evolution in solidifying alloys
1799 Computed Radiography
1800 Computed Radiography
