1801 Effects of Welding Parameters and Electrode Atmospheric Exposure on the Diffusible Hydrogen Content of Gas Shielded Flux Cored Arc Welds
1802 Self-piercing riveting
1803 ANSI Z535 and ISO 3864 safety symbols
1804 ISO/IEC 17065:2012 Conformity assessment – Requirements for bodies certifying products*
processes and services - presentation
1805 Welding secrets revealed
1806 Surface preparation and protective coating
1807 IIW: Fatigue design of welded joints and components
1808 IIW: Fatigue design procedure for welded hollow section joints
1809 Evaluation of microstructure during long.term creep of a tempered martensite tempered steel
1810 Evolution of microstructure and mechanical properties of the heat affected zone in B-containing 9% chromium steels
1811 Modelling creep rupture strenght of ferritic steel welds
1812 Effect of laser irradiation conditions on the laser welding strength of cobalt-chromium and gold alloys
1813 INFLUENCE OF TUNGSTEN AND CARBON ADDITION ON ELECTROCHEMICAL BEHAVIOUR OF 9 % Cr CREEP-RESISTANT STEEL
1814 ESAB: SAFETY DATA SHEET
1815 ESAB: SAFETY DATA SHEET
1816 Oerlikon: Safety data sheet OP 119
1817 Oerlikon: Safety data sheet OP 33
1818 Health & safety information
1819 Tenaris: Seamless tubes and pipes for boilers
1820 Evolution of microstructure and mechanical properties of the heat affected zone in B-containing 9% chromium steels
1821 Bohler - DRY SYSTEM – GUARANTEED DRY ELECTRODES
1822 Supplement for partial renovation planning of hot-medium carrying elements in fossil fuel power units
1823 Austenitic Stainless Steel-Ferritic Steel Weld Joint Failures
1824 Weldability Characteristics of a New Corrosion and Wear-Resistant Cobalt Alloy
1825 AWS: Accredited Testing Facility (ATF) Program Information
1826 Workshop self inspection checklist (welding)
1827 WELDING AND CUTTING INSPECTION CHECKLIST
1828 WELDEDIT Schedule Editor Manual
1829 Mould and tool steels
1830 Welding Journal – august 2013
1831 VD TUV WD 550 - Warmfester Walz- und Schmiedestahl X10CrNiCuNb18-9-3 (1.4907)
1832 MC alloy
1833 The P91 book
1834 Design of machine elements – 3rd edition
1835 QualityManagement Systems and Statistical Quality Control
1836 EPRI: Cr VI content letter
1837 IIW: Guidance for the Implementation of ISO 3834 Oriented to Welded Product Standards
1838 Health and Safety in Welding
1839 FINITE ELEMENT SIMULATION OF THE SIEBELSCHWAIGERER TENSILE TEST
1840 Field testing of pipelines
1841 DESORPTION AND CRYOGENIC RECOVERY OF VOLATILE ORGANIC COMPOUNDS FOR RE-USE
1842 Improving the Inspectability of Stainless Steel and Dissimilar Metal Welded Joints Using Inverse Phase-Matching of Phased Array Time-Domain Signals
1843 AUTOMATED TIE-IN – NEW TIE-IN TECHNOLOGY FOR PIPELINE CONSTRUCTION
1844 CE470 Lecture 15: Welds Introduction Types
1845 Pressure vessels
1846 WELDED CONNECTIONS
1847 CONDITIONS LEADING TO QUENCH *****ING OTHER THAN SEVERITY OF QUENCH
1848 Long term performance of polymers
1849 Example Of Cost Calculation In Welding
1850 Experiment: Heat Treatment - Quenching & Tempering
