Results 1 to 6 of 6
Thread: ISO Collection 88/300:ISO/TC 131 - Fluid power systems
    Standards and projects under the direct responsibility of ISO/TC 131 Secretariat
    ISO 1219-1:2012 Fluid power systems and components -- Graphical symbols and circuit diagrams -- Part 1: Graphical symbols for conventional use and data-processing applications
    ISO 1219-1:2012/Amd 1:2016 Fluid power systems and components -- Graphical symbols and circuit diagrams -- Part 1: Graphical symbols for conventional use and data-processing applications
    ISO 1219-2:2012 Fluid power systems and components -- Graphical symbols and circuit diagrams -- Part 2: Circuit diagrams
    ISO 2944:2000 Fluid power systems and components -- Nominal pressures
    ISO 5598:2008 Fluid power systems and components -- Vocabulary
    ISO 10946:1999 Hydraulic fluid power -- Gas-loaded accumulators with separator -- Selection of preferred hydraulic ports
    ISO 16030:2001 Pneumatic fluid power -- Connections -- Ports and stud ends
    ISO 16030:2001/Amd 1:2005 Pneumatic fluid power -- Connections -- Ports and stud ends
    ISO 19973-1:2015 Pneumatic fluid power -- Assessment of component reliability by testing -- Part 1: General procedures
    ISO 19973-2:2015 Pneumatic fluid power -- Assessment of component reliability by testing -- Part 2: Directional control valves
    ISO 19973-32015 Pneumatic fluid power -- Assessment of component reliability by testing -- Part 3: Cylinders with piston rod
    ISO 19973-4:2014 Pneumatic fluid power -- Assessment of component reliability by testing -- Part 4: Pressure regulators
    ISO 19973-5:2015 Pneumatic fluid power -- Assessment of component reliability by testing -- Part 5: Non-return valves, shuttle valves, dual pressure valves (AND function), one-way adjustable flow control valves, quick-exhaust valves
    Symbols, terminology and classifications
    ISO 1219-3:2016 Fluid power systems and components -- Graphical symbols and circuit diagrams -- Part 3: Symbol modules and connected symbols in circuit diagrams
    ISO 18582-1:2016 Fluid power -- Specification of reference dictionary -- Part 1: General overview on organization and structure
    Pumps, motors and integral transmissions
    ISO 3019-1:2001 Hydraulic fluid power -- Dimensions and identification code for mounting flanges and shaft ends of displacement pumps and motors -- Part 1: Inch series shown in metric units
    ISO 3019-2:2001 Hydraulic fluid power -- Dimensions and identification code for mounting flanges and shaft ends of displacement pumps and motors -- Part 2: Metric series
    ISO 3019-2:2001/Cor 1:2006 Hydraulic fluid power -- Dimensions and identification code for mounting flanges and shaft ends of displacement pumps and motors -- Part 2: Metric series
    ISO 3662:1976 Hydraulic fluid power -- Pumps and motors -- Geometric displacements
    ISO 4391:1983 Hydraulic fluid power -- Pumps, motors and integral transmissions -- Parameter definitions and letter symbols
    Cylinders
    ISO 3320:2013 Fluid power systems and components -- Cylinder bores and piston rod diameters and area ratios -- Metric series
    ISO 3321:1975 Fluid power systems and components -- Cylinder bores and piston rod diameters -- Inch series
    ISO 4393:2015 Fluid power systems and components -- Cylinders -- Basic series of piston strokes
    ISO 4394-1:1980 Fluid power systems and components -- Cylinder barrels -- Part 1: Requirements for steel tubes with specially finished bores
    ISO 4395:2009 Fluid power systems and components -- Cylinder piston rod end types and dimensions
    ISO 4395:2009/Cor 1:2010 Fluid power systems and components -- Cylinder piston rod end types and dimensions
    ISO 6020-1:2007 Hydraulic fluid power -- Mounting dimensions for single rod cylinders, 16 MPa (160 bar) series -- Part 1: Medium series
    ISO 6020-2:2015 Hydraulic fluid power -- Mounting dimensions for single rod cylinders, 16 MPa (160 bar) series -- Part 2: Compact series
    ISO 6020-3:2015 Hydraulic fluid power -- Mounting dimensions for single rod cylinders, 16 MPa (160 bar) series -- Part 3: Compact series with bores from 250 mm to 500 mm
    ISO 6022:2006 Hydraulic fluid power -- Mounting dimensions for single rod cylinders, 25 MPa (250 bar) series
    ISO 6099:2009 Fluid power systems and components -- Cylinders -- Identification code for mounting dimensions and mounting types
    ISO 6432:2015 Pneumatic fluid power -- Single rod cylinders, 1 000 kPa (10 bar) series, bores from 8 mm to 25 mm -- Basic and mounting dimensions
    ISO 6537:1982 Pneumatic fluid power systems -- Cylinder barrels -- Requirements for non-ferrous metallic tubes
    ISO 8132:2014 Hydraulic fluid power -- Mounting dimensions for accessories for single rod cylinders, 16 MPa (160 bar) medium and 25 MPa (250 bar) series
    ISO 8133:2014 Hydraulic fluid power -- Mounting dimensions for accessories for single rod cylinders, 16 MPa (160 bar) compact series
    ISO 8139:2009 Pneumatic fluid power -- Cylinders, 1 000 kPa (10 bar) series -- Mounting dimensions of rod-end spherical eyes
    ISO 8140:2009 Pneumatic fluid power -- Cylinders, 1 000 kPa (10 bar) series -- Mounting dimensions of rod-end clevises
    ISO 10099:2001 Pneumatic fluid power -- Cylinders -- Final examination and acceptance criteria
    ISO 10100:2001 Hydraulic fluid power -- Cylinders -- Acceptance tests
    ISO 10100:2001/Amd 1:2012 Hydraulic fluid power -- Cylinders -- Acceptance tests
    ISO 10762:2015 Hydraulic fluid power -- Mounting dimensions for cylinders, 10 MPa (100 bar) series
    ISO/TS 13725:2016 Hydraulic fluid power -- Method for evaluating the buckling load of a hydraulic cylinder
    ISO 13726:2008 Hydraulic fluid power -- Single rod cylinders, 16 MPa (160 bar) compact series with bores from 250 mm to 500 mm -- Accessory mounting dimensions
    ISO 15524:2011 Pneumatic fluid power -- Cylinders -- Single-rod short-stroke cylinders, 1 000 kPa (10 bar) series, bores from 20 mm to 100 mm
    ISO 15552:2004 Pneumatic fluid power -- Cylinders with detachable mountings, 1 000 kPa (10 bar) series, bores from 32 mm to 320 mm -- Basic, mounting and accessories dimensions
    ISO 16656:2016 Hydraulic fluid power -- Single rod, short-stroke cylinders with bores from 32 mm to 100 mm for use at 10 MPa (100 bar) -- Mounting dimensions
    ISO/TR 16806:2003 Pneumatic fluid power -- Cylinders -- Load capacity of pneumatic slides and their presentation method
    ISO 21287:2004 Pneumatic fluid power -- Cylinders -- Compact cylinders, 1000 kPa (10 bar) series, bores from 20 mm to 100 mm
    Connectors and similar products and components
    ISO 1179-1:2013 Connections for general use and fluid power -- Ports and stud ends with ISO 228-1 threads with elastomeric or metal-to-metal sealing -- Part 1: Threaded ports
    ISO 1179-2:2013 Connections for general use and fluid power -- Ports and stud ends with ISO 228-1 threads with elastomeric or metal-to-metal sealing -- Part 2: Heavy-duty (S series) and light-duty (L series) stud ends with elastomeric sealing (type E)
    ISO 1179-3:2007 Connections for general use and fluid power -- Ports and stud ends with ISO 228-1 threads with elastomeric or metal-to-metal sealing -- Part 3: Light-duty (L series) stud ends with sealing by O-ring with retaining ring (types G and H)
    ISO 1179-4:2007 Connections for general use and fluid power -- Ports and stud ends with ISO 228-1 threads with elastomeric or metal-to-metal sealing -- Part 4: Stud ends for general use only with metal-to-metal sealing (type B)
    ISO 4397:2011 Fluid power connectors and associated components -- Nominal outside diameters of tubes and nominal hose sizes
    ISO 4399:1995 Fluid power systems and components -- Connectors and associated components -- Nominal pressures
    ISO 6149-1:2006 Connections for hydraulic fluid power and general use -- Ports and stud ends with ISO 261 metric threads and O-ring sealing -- Part 1: Ports with truncated housing for O-ring seal
    ISO 6149-2:2006 Connections for hydraulic fluid power and general use -- Ports and stud ends with ISO 261 metric threads and O-ring sealing -- Part 2: Dimensions, design, test methods and requirements for heavy-duty (S series) stud ends
    ISO 6149-3:2006 Connections for hydraulic fluid power and general use -- Ports and stud ends with ISO 261 metric threads and O-ring sealing -- Part 3: Dimensions, design, test methods and requirements for light-duty (L series) stud ends
    ISO 6149-4:2006 Connections for fluid power and general use -- Ports and stud ends with ISO 261 metric threads and O-ring sealing -- Part 4: Dimensions, design, test methods and requirements for external hex and internal hex port plugs
    ISO 6150:1988 Pneumatic fluid power -- Cylindrical quick-action couplings for maximum working pressures of 10 bar, 16 bar and 25 bar (1 MPa, 1,6 Mpa, and 2,5 MPa) -- Plug connecting dimensions, specifications, application guidelines and testing
    ISO 6162-1:2012 Hydraulic fluid power -- Flange connections with split or one-piece flange clamps and metric or inch screws -- Part 1: Flange connectors, ports and mounting surfaces for use at pressures of 3,5 MPa (35 bar) to 35 MPa (350 bar), DN 13 to DN 127
    ISO 6162-2:2012 Hydraulic fluid power -- Flange connections with split or one-piece flange clamps and metric or inch screws -- Part 2: Flange connectors, ports and mounting surfaces for use at a pressure of 42 MPa (420 bar), DN 13 to DN 76
    ISO 6164:1994 Hydraulic fluid power -- Four-screw, one-piece square-flange connections for use at pressures of 25 MPa and 40 MPa (250 bar and 400 bar)
    ISO 6605:2002 Hydraulic fluid power -- Hoses and hose assemblies -- Test methods
    ISO 7241:2014 Hydraulic fluid power -- Dimensions and requirements of quick-action couplings
    ISO 7241-2:2000 Hydraulic fluid power -- Quick-action couplings -- Part 2: Test methods
    ISO 8434-1:2007 Metallic tube connections for fluid power and general use -- Part 1: 24 degree cone connectors
    ISO 8434-2:2007 Metallic tube connections for fluid power and general use -- Part 2: 37 degree flared connectors
    ISO 8434-3:2005 Metallic tube connections for fluid power and general use -- Part 3: O-ring face seal connectors
    ISO 8434-6:2009 Metallic tube connections for fluid power and general use -- Part 6: 60 degree cone connectors with or without O-ring
    ISO 9974-1:1996 Connections for general use and fluid power -- Ports and stud ends with ISO 261 threads with elastomeric or metal-to-metal sealing -- Part 1: Threaded ports
    ISO 9974-2:1996 Connections for general use and fluid power -- Ports and stud ends with ISO 261 threads with elastomeric or metal-to-metal sealing -- Part 2: Stud ends with elastomeric sealing (type E)
    ISO 9974-3:1996 Connections for general use and fluid power -- Ports and stud ends with ISO 261 threads with elastomeric or metal-to-metal sealing -- Part 3: Stud ends with metal-to-metal sealing (type B)
    ISO 9974-4:2016 Connections for general use and fluid power -- Ports and stud ends with ISO 261 threads with elastomeric or metal-to-metal sealing -- Part 4: Dimensions, design, test methods and requirements for external hex and internal hex port plugs
    ISO 10763:1994 Hydraulic fluid power -- Plain-end, seamless and welded precision steel tubes -- Dimensions and nominal working pressures
    ISO/TS 11672:2016 Connectors for fluid power and general use -- Designation and nomenclature
    ISO 11926-1:1995 Connections for general use and fluid power -- Ports and stud ends with ISO 725 threads and O-ring sealing -- Part 1: Ports with O-ring seal in truncated housing
    ISO 11926-2:1995 Connections for general use and fluid power -- Ports and stud ends with ISO 725 threads and O-ring sealing -- Part 2: Heavy-duty (S series) stud ends
    ISO 11926-3:1995 Connections for general use and fluid power -- Ports and stud ends with ISO 725 threads and O-ring sealing -- Part 3: Light-duty (L series) stud ends
    ISO 12151-1:2010 Connections for hydraulic fluid power and general use -- Hose fittings -- Part 1: Hose fittings with ISO 8434-3 O-ring face seal ends
    ISO 12151-2:2003 Connections for hydraulic fluid power and general use -- Hose fittings -- Part 2: Hose fittings with ISO 8434-1 and ISO 8434-4 24 degree cone connector ends with O-rings
    ISO 12151-3:2010 Connections for hydraulic fluid power and general use -- Hose fittings -- Part 3: Hose fittings with ISO 6162-1 or ISO 6162-2 flange ends
    ISO 12151-4:2007 Connections for hydraulic fluid power and general use -- Hose fittings -- Part 4: Hose fittings with ISO 6149 metric stud ends
    ISO 12151-5:2007 Connections for hydraulic fluid power and general use -- Hose fittings -- Part 5: Hose fittings with ISO 8434-2 37 degree flared ends
    ISO 12151-6:2009 Connections for hydraulic fluid power and general use -- Hose fittings -- Part 6: Hose fittings with ISO 8434-6 60 degree cone ends
    ISO 14540:2013 Hydraulic fluid power -- Dimensions and requirements for screw-to-connect quick-action couplings for use at a pressure of 72 MPa (720 bar)
    ISO 14541:2013 Hydraulic fluid power -- Dimensions and requirements for screw-to-connect quick-action couplings for general purpose
    ISO 14743:2004 Pneumatic fluid power -- Push-in connectors for thermoplastic tubes
    ISO 15171-1:1999 Connections for fluid power and general use -- Hydraulic couplings for diagnostic purposes -- Part 1: Coupling not for connection under pressure
    ISO 15171-2:2016 Connections for fluid power and general use -- Hydraulic couplings for diagnostic purposes -- Part 2: Coupling with M16 x 2 end for connection under pressure
    ISO 16028:1999 Hydraulic fluid power -- Flush-face type, quick-action couplings for use at pressures of 20 MPa (200 bar) to 31,5 MPa (315 bar) -- Specifications
    ISO 16028:1999/Amd 1:2006 Hydraulic fluid power -- Flush-face type, quick-action couplings for use at pressures of 20 MPa (200 bar) to 31,5 MPa (315 bar) -- Specifications
    ISO 17165-1:2007 Hydraulic fluid power -- Hose assemblies -- Part 1: Dimensions and requirements
    ISO/TS 17165-2:2013 Hydraulic fluid power -- Hose assemblies -- Part 2: Practices for hydraulic hose assemblies
    ISO 19879:2010 Metallic tube connections for fluid power and general use -- Test methods for hydraulic fluid power connections
    Control products and components
    ISO 4400:1994 Fluid power systems and components -- Three-pin electrical plug connectors with earth contact -- Characteristics and requirements
    ISO 4401:2005 Hydraulic fluid power -- Four-port directional control valves -- Mounting surfaces
    ISO 4411:2008 Hydraulic fluid power -- Valves -- Determination of pressure differential/flow characteristics
    ISO 5599-1:2001 Pneumatic fluid power -- Five-port directional control valves -- Part 1: Mounting interface surfaces without electrical connector
    ISO 5599-1:2001/Cor 1:2007 Pneumatic fluid power -- Five-port directional control valves -- Part 1: Mounting interface surfaces without electrical connector
    ISO 5599-2:2001 Pneumatic fluid power -- Five-port directional control valves -- Part 2: Mounting interface surfaces with optional electrical connector
    ISO 5599-2:2001/Cor 1:2007 Pneumatic fluid power -- Five-port directional control valves -- Part 2: Mounting interface surfaces with optional electrical connector
    ISO 5599-2:2001/Amd 1:2004 Pneumatic fluid power -- Five-port directional control valves -- Part 2: Mounting interface surfaces with optional electrical connector
    ISO 5781:2016 Hydraulic fluid power -- Pressure-reducing valves, sequence valves, unloading valves, throttle valves and check valves -- Mounting surfaces
    ISO 5782-1:1997 Pneumatic fluid power -- Compressed-air filters -- Part 1: Main characteristics to be included in suppliers' literature and product marking requirements
    ISO 5782-2:1997 Pneumatic fluid power -- Compressed-air filters -- Part 2: Test methods to determine the main characteristics to be included in supplier's literature
    ISO 5783:1995 Hydraulic fluid power -- Code for identification of valve mounting surfaces and cartridge valve cavities
    ISO 6263:2013 Hydraulic fluid power -- Compensated flow-control valves -- Mounting surfaces
    ISO 6264:1998 Hydraulic fluid power -- Pressure-relief valves -- Mounting surfaces
    ISO 6301-1:2009 Pneumatic fluid power -- Compressed-air lubricators -- Part 1: Main characteristics to be included in supplier's literature and product-marking requirements
    ISO 6301-2:2006 Pneumatic fluid power -- Compressed-air lubricators -- Part 2: Test methods to determine the main characteristics to be included in supplier's literature
    ISO 6358-1:2013 Pneumatic fluid power -- Determination of flow-rate characteristics of components using compressible fluids -- Part 1: General rules and test methods for steady-state flow
    ISO 6358-2:2013 Pneumatic fluid power -- Determination of flow-rate characteristics of components using compressible fluids -- Part 2: Alternative test methods
    ISO 6358-3:2014 Pneumatic fluid power -- Determination of flow-rate characteristics of components using compressible fluids -- Part 3: Method for calculating steady-state flow-rate characteristics of systems
    ISO 6952:1994 Fluid power systems and components -- Two-pin electrical plug connectors with earth contact -- Characteristics and requirements
    ISO 6953-1:2015 Pneumatic fluid power -- Compressed air pressure regulators and filter-regulators -- Part 1: Main characteristics to be included in literature from suppliers and product-marking requirements
    ISO 6953-2:2015 Pneumatic fluid power -- Compressed air pressure regulators and filter-regulators -- Part 2: Test methods to determine the main characteristics to be included in literature from suppliers
    ISO 6953-3:2012 Pneumatic fluid power -- Compressed air pressure regulators and filter-regulators -- Part 3: Alternative test methods for measuring the flow-rate characteristics of pressure regulators
    ISO 7368:2016 Hydraulic fluid power -- Two-port slip-in cartridge valves -- Cavities
    ISO 7789:2007 Hydraulic fluid power -- Two-, three- and four-port screw-in cartridge valves -- Cavities
    ISO 7790:2013 Hydraulic fluid power -- Four-port modular stack valves and four-port directional control valves, sizes 02, 03, 05, 07, 08 and 10 -- Clamping dimensions
    ISO 8778:2003 Pneumatic fluid power -- Standard reference atmosphere
    ISO 9461:1992 Hydraulic fluid power -- Identification of valve ports, subplates, control devices and solenoids
    ISO 10041-1:2010 Pneumatic fluid power -- Electro-pneumatic continuous flow control valves -- Part 1: Main characteristics to include in the supplier's literature
    ISO 10041-2:2010 Pneumatic fluid power -- Electro-pneumatic continuous flow control valves -- Part 2: Test methods to determine main characteristics to include in the supplier's literature
    ISO 10094-1:2010 Pneumatic fluid power -- Electro-pneumatic pressure control valves -- Part 1: Main characteristics to include in the supplier's literature
    ISO 10094-2:2010 Pneumatic fluid power -- Electro-pneumatic pressure control valves -- Part 2: Test methods to determine main characteristics to include in the supplier's literature
    ISO 10372:1992 Hydraulic fluid power -- Four- and five-port servovalves -- Mounting surfaces
    ISO 11727:1999 Pneumatic fluid power -- Identification of ports and control mechanisms of control valves and other components
    ISO 12238:2001 Pneumatic fluid power -- Directional control valves -- Measurement of shifting time
    ISO 15217:2000 Fluid power systems and components -- 16 mm square electrical connector with earth contact -- Characteristics and requirements
    ISO 15218:2003 Pneumatic fluid power -- 3/2 solenoid valves -- Mounting interface surfaces
    ISO 15407-1:2000 Pneumatic fluid power -- Five-port directional control valves, sizes 18 mm and 26 mm -- Part 1: Mounting interface surfaces without electrical connector
    ISO 15407-2:2003 Pneumatic fluid power -- Five-port directional control valves, sizes 18 mm and 26 mm -- Part 2: Mounting interface surfaces with optional electrical connector
    ISO 16873:2011 Hydraulic fluid power -- Pressure switches -- Mounting surfaces
    ISO 16874:2004 Hydraulic fluid power -- Identification of manifold assemblies and their components
    ISO 17082:2004 Pneumatic fluid power -- Valves -- Data to be included in supplier literature
    ISO/TR 17209:2013 Hydraulic fluid power -- Two-, three- and four-port screw-in cartridge valves -- Cavities with ISO 725 (UN and UNF) threads
    ISO 20401:2005 Pneumatic fluid power systems -- Directional control valves -- Specification of pin assignment for electrical round connectors of diameters 8 mm and 12 mm
    ISO 20401:2005/Cor 1:2005 Pneumatic fluid power systems -- Directional control valves -- Specification of pin assignment for electrical round connectors of diameters 8 mm and 12 mm
    Contamination control
    ISO 2941:2009 Hydraulic fluid power -- Filter elements -- Verification of collapse/burst pressure rating
    ISO 2942:2004 Hydraulic fluid power -- Filter elements -- Verification of fabrication integrity and determination of the first bubble point
    ISO 2943:1998 Hydraulic fluid power -- Filter elements -- Verification of material compatibility with fluids
    ISO 3722:1976 Hydraulic fluid power -- Fluid sample containers -- Qualifying and controlling cleaning methods
    ISO 3723:2015 Hydraulic fluid power -- Filter elements -- Method for end load test
    ISO 3724:2007 Hydraulic fluid power -- Filter elements -- Determination of resistance to flow fatigue using particulate contaminant
    ISO 3938:1986 Hydraulic fluid power -- Contamination analysis -- Method for reporting analysis data
    ISO 3968:2001 Hydraulic fluid power -- Filters -- Evaluation of differential pressure versus flow characteristics
    ISO 3968:2001/Cor 1:2002 Hydraulic fluid power -- Filters -- Evaluation of differential pressure versus flow characteristics
    ISO 4021:1992 Hydraulic fluid power -- Particulate contamination analysis -- Extraction of fluid samples from lines of an operating system
    ISO 4405:1991 Hydraulic fluid power -- Fluid contamination -- Determination of particulate contamination by the gravimetric method
    ISO 4406:1999 Hydraulic fluid power -- Fluids -- Method for coding the level of contamination by solid particles
    ISO 4407:2002 Hydraulic fluid power -- Fluid contamination -- Determination of particulate contamination by the counting method using an optical microscope
    ISO/TR 10686:2013 Hydraulic fluid power -- Method to relate the cleanliness of a hydraulic system to the cleanliness of the components and hydraulic fluid that make up the system
    ISO/TR 10949:2002 Hydraulic fluid power -- Component cleanliness -- Guidelines for achieving and controlling cleanliness of components from manufacture to installation
    ISO 11170:2013 Hydraulic fluid power -- Sequence of tests for verifying performance characteristics of filter elements
    ISO 11171:2016 Hydraulic fluid power -- Calibration of automatic particle counters for liquids
    ISO 11500:2008 Hydraulic fluid power -- Determination of the particulate contamination level of a liquid sample by automatic particle counting using the light-extinction principle
    ISO 11943:1999 Hydraulic fluid power -- On-line automatic particle-counting systems for liquids -- Methods of calibration and validation
    ISO 12829:2016 Hydraulic spin-on filters with finite lives -- Method for verifying the rated fatigue life and the rated static burst pressure of the pressure-containing envelope
    ISO/TR 15640:2011 Hydraulic fluid power contamination control -- General principles and guidelines for selection and application of hydraulic filters
    ISO/TR 16144:2002 Hydraulic fluid power -- Calibration of liquid automatic particle counters -- Procedures used to certify the standard reference material SRM 2806
    ISO/TR 16386:2014 Impact of changes in ISO fluid power particle counting -- Contamination control and filter test standards
    ISO 16431:2012 Hydraulic fluid power -- System clean-up procedures and verification of cleanliness of assembled systems
    ISO 16860:2005 Hydraulic fluid power -- Filters -- Test method for differential pressure devices
    ISO 16889:2008 Hydraulic fluid power -- Filters -- Multi-pass method for evaluating filtration performance of a filter element
    ISO 16908:2014 Hydraulic filter element test methods -- Thermal conditioning and cold start-up simulation
    ISO 18413:2015 Hydraulic fluid power -- Cleanliness of components -- Inspection document and principles related to contaminant extraction and analysis, and data reporting
    ISO 21018-1:2008 Hydraulic fluid power -- Monitoring the level of particulate contamination of the fluid -- Part 1: General principles
    ISO 21018-3:2008 Hydraulic fluid power -- Monitoring the level of particulate contamination of the fluid -- Part 3: Use of the filter blockage technique
    ISO 21018-4:2016 Hydraulic fluid power -- Monitoring the level of particulate contamination in the fluid -- Part 4: Use of the light extinction technique
    ISO 23181:2007 Hydraulic fluid power -- Filter elements -- Determination of resistance to flow fatigue using high viscosity fluid
    ISO 23309:2007 Hydraulic fluid power systems -- Assembled systems -- Methods of cleaning lines by flushing
    ISO 27407:2010 Hydraulic fluid power -- Marking of performance characteristics on hydraulic filters
    Sealing devices
    ISO 3601-1:2012 Fluid power systems -- O-rings -- Part 1: Inside diameters, cross-sections, tolerances and designation codes
    ISO 3601-1:2012/Cor 1:2012 Fluid power systems -- O-rings -- Part 1: Inside diameters, cross-sections, tolerances and designation codes
    ISO 3601-2:2016 Fluid power systems -- O-rings -- Part 2: Housing dimensions for general applications
    ISO 3601-3:2005 Fluid power systems -- O-rings -- Part 3: Quality acceptance criteria
    ISO 3601-4:2008 Fluid power systems -- O-rings -- Part 4: Anti-extrusion rings (back-up rings)
    ISO 3601-5:2015 Fluid power systems -- O-rings -- Part 5: Specification of elastomeric materials for industrial applications
    ISO 3939:1977 Fluid power systems and components -- Multiple lip packing sets -- Methods for measuring stack heights
    ISO 5597:2010 Hydraulic fluid power -- Cylinders -- Dimensions and tolerances of housings for single-acting piston and rod seals in reciprocating applications
    ISO 6194-1:2007 Rotary shaft lip-type seals incorporating elastomeric sealing elements -- Part 1: Nominal dimensions and tolerances
    ISO 6194-2:2009 Rotary shaft lip-type seals incorporating elastomeric sealing elements -- Part 2: Vocabulary
    ISO 6194-3:2009 Rotary shaft lip-type seals incorporating elastomeric sealing elements -- Part 3: Storage, handling and installation
    ISO 6194-4:2009 Rotary shaft lip-type seals incorporating elastomeric sealing elements -- Part 4: Performance test procedures
    ISO 6194-5:2008 Rotary-shaft lip-type seals incorporating elastomeric sealing elements -- Part 5: Identification of visual imperfections
    ISO 6195:2013 Fluid power systems and components -- Cylinder-rod wiper-ring housings in reciprocating applications -- Dimensions and tolerances
    ISO 6547:1981 Hydraulic fluid power -- Cylinders -- Piston seal housings incorporating bearing rings -- Dimensions and tolerances
    ISO 7425-1:1988 Hydraulic fluid power -- Housings for elastomer-energized, plastic-faced seals -- Dimensions and tolerances -- Part 1: Piston seal housings
    ISO 7425-2:1989 Hydraulic fluid power -- Housings for elastomer-energized, plastic-faced seals -- Dimensions and tolerances -- Part 2: Rod seal housings
    ISO 7986:1997 Hydraulic fluid power -- Sealing devices -- Standard test methods to assess the performance of seals used in oil hydraulic reciprocating applications
    ISO 10766:2014 Hydraulic fluid power -- Cylinders -- Housing dimensions for rectangular-section-cut bearing rings for pistons and rods
    ISO 16589-1:2011 Rotary shaft lip-type seals incorporating thermoplastic sealing elements -- Part 1: Nominal dimensions and tolerances
    ISO 16589-2:2011 Rotary shaft lip-type seals incorporating thermoplastic sealing elements -- Part 2: Vocabulary
    ISO 16589-3:2011 Rotary shaft lip-type seals incorporating thermoplastic sealing elements -- Part 3: Storage, handling and installation
    ISO 16589-4:2011 Rotary shaft lip-type seals incorporating thermoplastic sealing elements -- Part 4: Performance test procedures
    ISO 16589-5:2011 Rotary shaft lip-type seals incorporating thermoplastic sealing elements -- Part 5: Identification of visual imperfections
    Product testing
    ISO 4392-1:2002 Hydraulic fluid power -- Determination of characteristics of motors -- Part 1: At constant low speed and constant pressure
    ISO 4392-2:2002 Hydraulic fluid power -- Determination of characteristics of motors -- Part 2: Startability
    ISO 4392-3:1993 Hydraulic fluid power -- Determination of characteristics of motors -- Part 3: At constant flow and at constant torque
    ISO 4409:2007 Hydraulic fluid power -- Positive-displacement pumps, motors and integral transmissions -- Methods of testing and presenting basic steady state performance
    ISO 4412-1:1991 Hydraulic fluid power -- Test code for determination of airborne noise levels -- Part 1: Pumps
    ISO 4412-2:1991 Hydraulic fluid power -- Test code for determination of airborne noise levels -- Part 2: Motors
    ISO 4412-3:1991 Hydraulic fluid power -- Test code for determination of airborne noise levels -- Part 3: Pumps -- Method using a parallelepiped microphone array
    ISO 6403:1988 Hydraulic fluid power -- Valves controlling flow and pressure -- Test methods
    ISO 8426:2008 Hydraulic fluid power -- Positive displacement pumps and motors -- Determination of derived capacity
    ISO 9110-1:1990 Hydraulic fluid power -- Measurement techniques -- Part 1: General measurement principles
    ISO 9110-2:1990 Hydraulic fluid power -- Measurement techniques -- Part 2: Measurement of average steady-state pressure in a closed conduit
    ISO 10767-1:2015 Hydraulic fluid power -- Determination of pressure ripple levels generated in systems and components -- Part 1: Method for determining source flow ripple and source impedance of pumps
    ISO 10767-2:1999 Hydraulic fluid power -- Determination of pressure ripple levels generated in systems and components -- Part 2: Simplified method for pumps
    ISO 10767-3:1999 Hydraulic fluid power -- Determination of pressure ripple levels generated in systems and components -- Part 3: Method for motors
    ISO 10770-1:2009 Hydraulic fluid power -- Electrically modulated hydraulic control valves -- Part 1: Test methods for four-port directional flow-control valves
    ISO 10770-2:2012 Hydraulic fluid power -- Electrically modulated hydraulic control valves -- Part 2: Test methods for three-port directional flow-control valves
    ISO 10770-3:2007 Hydraulic fluid power -- Electrically modulated hydraulic control valves -- Part 3: Test methods for pressure control valves
    ISO 10771-1:2015 Hydraulic fluid power -- Fatigue pressure testing of metal pressure-containing envelopes -- Part 1: Test method
    ISO/TR 10771-2:2008 Hydraulic fluid power -- Fatigue pressure testing of metal pressure-containing envelopes -- Part 2: Rating methods
    ISO 15086-1:2001 Hydraulic fluid power -- Determination of the fluid-borne noise characteristics of components and systems -- Part 1: Introduction
    ISO 15086-2:2000 Hydraulic fluid power -- Determination of the fluid-borne noise characteristics of components and systems -- Part 2: Measurement of the speed of sound in a fluid in a pipe
    ISO 15086-3:2008 Hydraulic fluid power -- Determination of the fluid-borne noise characteristics of components and systems -- Part 3: Measurement of hydraulic impedance
    ISO 16902-1:2003 Hydraulic fluid power -- Test code for the determination of sound power levels of pumps using sound intensity techniques: Engineering method -- Part 1: Pumps
    ISO 17559:2003 Hydraulic fluid power -- Electrically controlled hydraulic pumps -- Test methods to determine performance characteristics
    ISO/TR 19972-1:2009 Hydraulic fluid power -- Methods to assess the reliability of hydraulic components -- Part 1: General procedures and calculation method
    Installations and systems
    ISO 4413:2010 Hydraulic fluid power -- General rules and safety requirements for systems and their components
    ISO 4414:2010 Pneumatic fluid power -- General rules and safety requirements for systems and their components
    the missing are:
    links:
    or
    Re: ISO/TC 131 - Fluid power systems
    Re: ISO Collection 88/300:ISO/TC 131 - Fluid power systems
    update:
    added missing:
    new missing list:
    ISO 9974-4:2016 Connections for general use and fluid power -- Ports and stud ends with ISO 261 threads with elastomeric or metal-to-metal sealing -- Part 4: Dimensions* design* test methods and requirements for external hex and internal hex port plugs
    ISO 12151-1:2010/Amd 1:2017 Connections for hydraulic fluid power and general use -- Hose fittings -- Part 1: Hose fittings with ISO 8434-3 O-ring face seal ends
    ISO 9461:1992 Hydraulic fluid power -- Identification of valve ports* subplates* control devices and solenoids
    new link:
    update:
    better quality:
    ISO 16028:1999/Amd 1:2006 Hydraulic fluid power -- Flush-face type* quick-action couplings for use at pressures of 20 MPa (200 bar) to 31*5 MPa (315 bar) -- Specifications
    EN versions:
    ISO 21287:2004 Pneumatic fluid power -- Cylinders -- Compact cylinders* 1000 kPa (10 bar) series* bores from 20 mm to 100 mm
    added missing:
    new missing list:
    ISO/TR 16194:2017 Pneumatic fluid power -- Assessment of component reliability by accelerated life testing -- General guidelines and procedures
    full list 01.12.2017:
    ISO 19973-5:2015 Pneumatic fluid power -- Assessment of component reliability by testing -- Part 5: Non-return valves* shuttle valves* dual pressure valves (AND function)* one-way adjustable flow control valves* quick-exhaust valves
    ISO 4391:1983 Hydraulic fluid power -- Pumps* motors and integral transmissions -- Parameter definitions and letter symbols
    ISO 6020-1:2007 Hydraulic fluid power -- Mounting dimensions for single rod cylinders* 16 MPa (160 bar) series -- Part 1: Medium series
    ISO 6020-2:2015 Hydraulic fluid power -- Mounting dimensions for single rod cylinders* 16 MPa (160 bar) series -- Part 2: Compact series
    ISO 6020-3:2015 Hydraulic fluid power -- Mounting dimensions for single rod cylinders* 16 MPa (160 bar) series -- Part 3: Compact series with bores from 250 mm to 500 mm
    ISO 6022:2006 Hydraulic fluid power -- Mounting dimensions for single rod cylinders* 25 MPa (250 bar) series
    ISO 6432:2015 Pneumatic fluid power -- Single rod cylinders* 1 000 kPa (10 bar) series* bores from 8 mm to 25 mm -- Basic and mounting dimensions
    ISO 8132:2014 Hydraulic fluid power -- Mounting dimensions for accessories for single rod cylinders* 16 MPa (160 bar) medium and 25 MPa (250 bar) series
    ISO 8133:2014 Hydraulic fluid power -- Mounting dimensions for accessories for single rod cylinders* 16 MPa (160 bar) compact series
    ISO 8139:2009 Pneumatic fluid power -- Cylinders* 1 000 kPa (10 bar) series -- Mounting dimensions of rod-end spherical eyes
    ISO 8140:2009 Pneumatic fluid power -- Cylinders* 1 000 kPa (10 bar) series -- Mounting dimensions of rod-end clevises
    ISO 10762:2015 Hydraulic fluid power -- Mounting dimensions for cylinders* 10 MPa (100 bar) series
    ISO 13726:2008 Hydraulic fluid power -- Single rod cylinders* 16 MPa (160 bar) compact series with bores from 250 mm to 500 mm -- Accessory mounting dimensions
    ISO 15524:2011 Pneumatic fluid power -- Cylinders -- Single-rod short-stroke cylinders* 1 000 kPa (10 bar) series* bores from 20 mm to 100 mm
    ISO 15552:2004 Pneumatic fluid power -- Cylinders with detachable mountings* 1 000 kPa (10 bar) series* bores from 32 mm to 320 mm -- Basic* mounting and accessories dimensions
    ISO 16656:2016 Hydraulic fluid power -- Single rod* short-stroke cylinders with bores from 32 mm to 100 mm for use at 10 MPa (100 bar) -- Mounting dimensions
    ISO 6149-2:2006 Connections for hydraulic fluid power and general use -- Ports and stud ends with ISO 261 metric threads and O-ring sealing -- Part 2: Dimensions* design* test methods and requirements for heavy-duty (S series) stud ends
    ISO 6149-3:2006 Connections for hydraulic fluid power and general use -- Ports and stud ends with ISO 261 metric threads and O-ring sealing -- Part 3: Dimensions* design* test methods and requirements for light-duty (L series) stud ends
    ISO 6149-4:2017 Connections for fluid power and general use -- Ports and stud ends with ISO 261 metric threads and O-ring sealing -- Part 4: Dimensions* design* test methods and requirements for external hex and internal hex port plugs
    ISO 6150:1988 Pneumatic fluid power -- Cylindrical quick-action couplings for maximum working pressures of 10 bar* 16 bar and 25 bar (1 MPa* 1*6 Mpa* and 2*5 MPa) -- Plug connecting dimensions* specifications* application guidelines and testing
    ISO 6162-1:2012 Hydraulic fluid power -- Flange connections with split or one-piece flange clamps and metric or inch screws -- Part 1: Flange connectors* ports and mounting surfaces for use at pressures of 3*5 MPa (35 bar) to 35 MPa (350 bar)* DN 13 to DN 127
    ISO 6162-2:2012 Hydraulic fluid power -- Flange connections with split or one-piece flange clamps and metric or inch screws -- Part 2: Flange connectors* ports and mounting surfaces for use at a pressure of 42 MPa (420 bar)* DN 13 to DN 76
    ISO 6164:1994 Hydraulic fluid power -- Four-screw* one-piece square-flange connections for use at pressures of 25 MPa and 40 MPa (250 bar and 400 bar)
    ISO 6605:2017 Hydraulic fluid power -- Test methods for hoses and hose assemblies
    ISO 10763:1994 Hydraulic fluid power -- Plain-end* seamless and welded precision steel tubes -- Dimensions and nominal working pressures
    ISO/TS 11686:2017 Connectors for fluid power and general use -- Assembly instructions for connectors with adjustable stud ends and O-ring sealing
    ISO 16028:1999 Hydraulic fluid power -- Flush-face type* quick-action couplings for use at pressures of 20 MPa (200 bar) to 31*5 MPa (315 bar) -- Specifications
    ISO 18869:2017 Hydraulic fluid power -- Test methods for couplings actuated with or without tools
    ISO 5781:2016 Hydraulic fluid power -- Pressure-reducing valves* sequence valves* unloading valves* throttle valves and check valves -- Mounting surfaces
    ISO 5782-1:2017 Pneumatic fluid power -- Compressed air filters -- Part 1: Main characteristics to be included in supplier's literature and product-marking requirements
    ISO 6301-1:2017 Pneumatic fluid power -- Compressed-air lubricators -- Part 1: Main characteristics to be included in supplier's literature and product-marking requirements
    ISO 7789:2007 Hydraulic fluid power -- Two-* three- and four-port screw-in cartridge valves -- Cavities
    ISO 7790:2013 Hydraulic fluid power -- Four-port modular stack valves and four-port directional control valves* sizes 02* 03* 05* 07* 08 and 10 -- Clamping dimensions
    ISO 15407-1:2000 Pneumatic fluid power -- Five-port directional control valves* sizes 18 mm and 26 mm -- Part 1: Mounting interface surfaces without electrical connector
    ISO 15407-2:2003 Pneumatic fluid power -- Five-port directional control valves* sizes 18 mm and 26 mm -- Part 2: Mounting interface surfaces with optional electrical connector
    ISO/TR 17209:2013 Hydraulic fluid power -- Two-* three- and four-port screw-in cartridge valves -- Cavities with ISO 725 (UN and UNF) threads
    ISO 20401:2017 Pneumatic fluid power systems -- Directional control valves -- Specification of pin assignment for 8 mm and 12 mm diameter electrical round connectors
    ISO 3968:2017 Hydraulic fluid power -- Filters -- Evaluation of differential pressure versus flow
    ISO 4406:2017 Hydraulic fluid power -- Fluids -- Method for coding the level of contamination by solid particles
    ISO 12669:2017 Hydraulic fluid power -- Method for determining the required cleanliness level (RCL) of a system
    ISO 18237:2017 Hydraulic fluid power -- Method for evaluating water separation performance of dehydrators
    ISO 18413:2015 Hydraulic fluid power -- Cleanliness of components -- Inspection document and principles related to contaminant extraction and analysis* and data reporting
    ISO 3601-1:2012 Fluid power systems -- O-rings -- Part 1: Inside diameters* cross-sections* tolerances and designation codes
    ISO 3601-1:2012/Cor 1:2012 Fluid power systems -- O-rings -- Part 1: Inside diameters* cross-sections* tolerances and designation codes
    ISO 6194-3:2009 Rotary shaft lip-type seals incorporating elastomeric sealing elements -- Part 3: Storage* handling and installation
    ISO 7425-1:1988 Hydraulic fluid power -- Housings for elastomer-energized* plastic-faced seals -- Dimensions and tolerances -- Part 1: Piston seal housings
    ISO 7425-2:1989 Hydraulic fluid power -- Housings for elastomer-energized* plastic-faced seals -- Dimensions and tolerances -- Part 2: Rod seal housings
    ISO 16589-3:2011 Rotary shaft lip-type seals incorporating thermoplastic sealing elements -- Part 3: Storage* handling and installation
    ISO 4409:2007 Hydraulic fluid power -- Positive-displacement pumps* motors and integral transmissions -- Methods of testing and presenting basic steady state performance
    the missing:
  1. Replies: 14
    Last Post: 12-24-2017, 05:29 AM
  2. Replies: 10
    Last Post: 09-14-2016, 01:19 PM
  3. Power System Engineering: Planning, Design, and Operation of Power Systems and Equipm
    By Han Ah kwang in forum Electrical & Power Engineering
    Last Post: 01-26-2015, 02:33 PM
  4. Power Gained by Fluid
    Last Post: 01-26-2012, 12:39 PM
  5. Fluid Power Engineering by Rabe
    By Azad in forum General Engineering
    Last Post: 05-02-2010, 08:18 PM
