full list:
EN 580:2003 Plastics piping systems - Unplasticized poly(vinyl chloride) (PVC-U) pipes - Test method for the resistance to dichloromethane at a specified temperature (DCMT)
EN ISO 580:2005 Plastics piping and ducting systems - Injection-moulded thermoplastics fittings - Methods for visually assessing the effects of heating (ISO 580:2005)
EN 637:1994 Plastics piping systems - Glass-reinforced plastics components - Determination of the amounts of constituents using the gravimetric method
EN 637:1994/AC:1995 Plastics piping systems - Glass-reinforced plastics components - Determination of the amounts of constituents using the gravimetric method
EN 705:1994 Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes and fittings - Methods for regression analysis and their use
EN 705:1994/AC:1995 Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes and fittings - Methods for regression analysis and their use
EN 714:1994 Thermoplastics piping systems - Non-end-load-bearing elastomeric sealing ring type joints beteween pressure pipes and moulded fittings - Test method for leaktighness under internal hydrostatic pressure without end thrust
EN 727:1994 Plastics piping and ducting systems - Thermoplastics pipes and fittings - Determination of Vicat softening temperature (VST)
EN 728:1997 Plastics piping and ducting systems - Polyolefin pipes and fittings - Determination of oxidation induction time
EN 744:1995 Plastics piping and ducting systems - Thermoplastics pipes - Test method for resistance to external blows by the round-the-clock method
EN 761:1994 Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes - Determination of the creep factor under dry conditions
EN 761:1994/AC:1995 Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes - Determination of the creep factor under dry conditions
EN 802:1994 Plastics piping and ducting systems - Injection-moulded thermoplastics fittings for pressure piping systems - Test method for maximum deformation by crushing
EN 803:1994 Plastics piping systems - Injection-moulded thermoplastics fittings for elastic sealing ring type joints for pressure piping - Test method for resistance to a short-term internal pressure without end thrust
EN 804:1994 Plastics piping systems - Injection-moulded socket fittings for solvent-cemented joints for pressure piping - Test method for resistance to a short-term internal hydrostatic pressure
CEN/TR 852:2010 Plastics piping systems for the transport of water intended for human consumption - Migration assessment - Guidance on the interpretation of laboratory derived migration values
EN 917:1997 Plastics piping systems - Thermoplastics valves - Test methods for resistance to internal pressure and leaktightness
CEN/TR 1046:2013 Thermoplastics piping and ducting systems - Systems outside building structures for the conveyance of water or sewage - Practices for underground installation
EN 1053:1995 Plastics piping systems - Thermoplastics piping systems for non-pressure applications - Test method for watertightness
EN 1054:1995 Plastics piping systems - Thermoplastics piping systems for soil and waste discharge - Test method for airtightness of joints
EN 1055:1996 Plastics piping systems - Thermoplastics piping systems for soil and waste discharge inside buildings - Test method for resistance to elevated temperature cycling
EN 1119:2009 Plastics piping systems - Joints for glass-reinforced thermosetting plastics (GRP) pipes and fittings - Test methods for leaktightness and resistance to damage of non-thrust resistant flexible joints with elastomeric sealing elements
EN 1120:1996 Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes and fittings - Determination of the resistance to chemical attack from the inside of a section in a deflected condition
EN ISO 1167-1:2006 Thermoplastics pipes, fittings and assemblies for the conveyance of fluids - Determination of the resistance to internal pressure - Part 1: General method (ISO 1167-1:2006)
EN ISO 1167-2:2006 Thermoplastics pipes, fittings and assemblies for the conveyance of fluids - Determination of the resistance to internal pressure - Part 2: Preparation of pipe test pieces (ISO 1167-2:2006)
EN ISO 1167-3:2007 Thermoplastics pipes, fittings and assemblies for the conveyance of fluids - Determination of the resistance to internal pressure - Part 3: Preparation of components (ISO 1167-3:2007)
EN ISO 1167-4:2007 Thermoplastics pipes, fittings and assemblies for the conveyance of fluids - Determination of the resistance to internal pressure - Part 4: Preparation of assemblies (ISO 1167-4:2007)
EN 1228:1996 Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes - Determination of initial specific ring stiffness
EN 1229:1996 Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes and fittings - Test methods to prove the leaktightness of the wall under short-term internal pressure
EN 1277:2003 Plastics piping systems - Thermoplastics piping systems for buried non-pressure applications - Test methods for leaktightness of elastomeric sealing ring type joints
EN 1329-1:2014 Plastics piping systems for soil and waste discharge (low and high temperature) within the building structure - Unplasticized poly(vinyl chloride) (PVC-U) - Part 1: Specifications for pipes, fittings and the system
CEN/TS 1329-2:2012 Plastics piping systems for soil and waste discharge (low and high temperature) within the building structure - Unplasticized poly(vinyl chloride) (PVC-U) - Part 2: Guidance for the assessment of conformity
EN 1393:1996 Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes - Determination of initial longitudinal tensile properties
EN 1393:1996/AC:1997 Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes - Determination of initial longitudinal tensile properties
EN 1394:1996 Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes - Determination of the apparent initial circumferential tensile strength
EN 1394:1996/AC:1997 Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes - Determination of the apparent initial circumferential tensile strength
EN 1401-1:2009 Plastics piping systems for non-pressure underground drainage and sewerage - Unplasticized poly(vinyl chloride) (PVC-U) - Part 1: Specifications for pipes, fittings and the system
CEN/TS 1401-2:2012 Plastics piping systems for non-pressure underground drainage and sewerage - Unplasticized poly(vinyl chloride) (PVC-U) - Part 2: Guidance for assessment of conformity
EN 1411:1996 Plastics piping and ducting systems - Thermoplastics pipes - Determination of resistance to external blows by the staircase method
EN 1447:2009+A1:2010 Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes - Determination of long-term resistance to internal pressure
EN 1451-1:1998 Plastics piping systems for soil and waste discharge (low and high temperature) within the building structure - Polypropylene (PP) - Part 1: Specifications for pipes, fittings and the system
CEN/TS 1451-2:2012 Plastic piping systems for soil and waste discharge (low and high temperature) within the building structure - Polypropylene (PP) - Part 2: Guidance for the assessment of conformity
EN ISO 1452-1:2009 Plastics piping systems for water supply and for buried and above-ground drainage and sewerage under pressure - Unplasticized poly(vinyl chloride) (PVC-U) - Part 1: General (ISO 1452-1:2009)
EN ISO 1452-2:2009 Plastics piping systems for water supply and for buried and above-ground drainage and sewerage under pressure - Unplasticized poly(vinyl chloride) (PVC-U) - Part 2: Pipes (ISO 1452-2:2009)
EN ISO 1452-3:2010 Plastics piping systems for water supply and for buried and above-ground drainage and sewerage under pressure - Unplasticized poly(vinyl chloride) (PVC-U) - Part 3: Fittings (ISO 1452-3:2009, corrected version 2010-03-01)
EN ISO 1452-4:2009 Plastics piping systems for water supply and for buried and above-ground drainage and sewerage under pressure - Unplasticized poly(vinyl chloride) (PVC-U) - Part 4: Valves (ISO 1452-4:2009)
EN ISO 1452-5:2010 Plastics piping systems for water supply and for buried and above-ground drainage and sewerage under pressure - Unplasticized poly(vinyl chloride) (PVC-U) - Part 5: Fitness for purpose of the system (ISO 1452-5:2009, corrected version 2010-03-01)
CEN/TS 1452-7:2014 Plastics piping systems for water supply and for buried and above-ground drainage and sewerage under pressure - Unplasticized poly(vinyl chloride) (PVC-U) - Part 7: Guidance for the assessment of conformity
EN 1453-1:2000 Plastics piping systems with structured wall-pipes for soil and waste discharge (low and high temperature) inside buildings - Unplasticized poly(vinyl chloride) (PVC-U) - Part 1: Specifications for pipes and the system
ENV 1453-2:2000 Plastics piping systems with structured wall pipes for soil and waste discharge (low and high temperature) inside buildings - Unplasticized poly(vinyl chloride) (PVC-U) - Part 2: Guidance for the assessment of conformity
EN 1455-1:1999 Plastics piping systems for soil and waste discharge (low and high temperature) within the building structure - Acrylonitrile-butadiene-styrene (ABS) - Part 1: Requirements for pipes, fittings and the system
CEN/TS 1455-2:2012 Plastics piping systems for soil and waste discharge (low and high temperature) within the building structure - Acrylonitrile-butadiene-styrene (ABS) - Part 2: Guidance for the assessment of conformity
EN 1519-1:1999 Plastics piping systems for soil and waste discharge (low and high temperature) within the building structure - Polyethylene (PE) - Part 1: Specifications for pipes, fittings and the system
CEN/TS 1519-2:2012 Plastic piping systems for soil and waste discharge (low and high temperature) within the building structure - Polyethylen (PE) - Part 2: Guidance for the assessment of conformity
EN 1555-1:2010 Plastics piping systems for the supply of gaseous fuels - Polyethylene (PE) - Part 1: General
EN 1555-2:2010 Plastics piping systems for the supply of gaseous fuels - Polyethylene (PE) - Part 2: Pipes
EN 1555-3:2010+A1:2012 Plastics piping systems for the supply of gaseous fuels - Polyethylene (PE) - Part 3: Fittings
EN 1555-4:2011 Plastics piping systems for the supply of gaseous fuels - Polyethylene (PE) - Part 4: Valves
EN 1555-5:2010 Plastics piping systems for the supply of gaseous fuels - Polyethylene (PE) - Part 5: Fitness for purpose of the system
CEN/TS 1555-7:2013 Plastics piping systems for the supply of gaseous fuels - Polyethylene (PE) - Part 7: Guidance for the assessment of conformity
EN 1565-1:1998 Plastics piping systems for soil and waste discharge (low and high temperature) within the building structure - Styrene copolymer blends (SAN+PVC) - Part 1: Specifications for pipes, fittings and the system
CEN/TS 1565-2:2012 Plastics piping systems for soil and waste discharge (low and high temperature) within the building structure - Styrene-copolymer blends (SAN+PVC) - Part 2: Guidance for the assessment of conformity
EN 1566-1:1998 Plastics piping systems for soil and waste discharge (low and high temperature) within the building structure - Chlorinated poly(vinyl chloride) (PVC-C) - Part 1: Specifications for pipes, fittings and the system
CEN/TS 1566-2:2012 Plastics piping systems for soil and waste discharge (low and high temperature) within the building structure - Chlorinated poly(vinyl chloride) (PVC-C) - Part 2: Guidance for assessment of conformity
EN 1680:1997 Plastics piping systems - Valves for polyethylene (PE) piping systems - Test method for leaktightness under and after bending applied to the operating mechanisms
EN 1704:1997 Plastics piping systems - Thermoplastics valves - Test method for the integrity of a valve after temperature cycling under bending
EN 1705:1996 Plastics piping systems - Thermoplastics valves - Test method for the integrity of a valve after an external blow
EN 1716:1997 Plastics piping systems - Polyethylene (PE) tapping tees - Test method for impact resistance of an assembled tapping tee
EN 1796:2013 Plastics piping systems for water supply with or without pressure - Glass-reinforced thermosetting plastics (GRP) based on unsaturated polyester resin (UP)
EN 1852-1:2009 Plastics piping systems for non-pressure underground drainage and sewerage - Polypropylene (PP) - Part 1: Specifications for pipes, fittings and the system
CEN/TS 1852-2:2015 Plastics piping systems for non-pressure underground drainage and sewerage - Polypropylene (PP) - Part 2: Guidance for the assessment of conformity
EN 1905:1998 Plastics piping systems - Unplasticized poly(vinyl chloride) (PVC-U) pipes, fittings and material - Method for assessment of the PVC content based on total chlorine content
EN 1979:1999 Plastics piping and ducting systems - Thermoplastics spirally-formed structured-wall pipes - Determination of the tensile strength of a seam
EN ISO 2505:2005 Thermoplastics pipes - Longitudinal reversion - Test method and parameters (ISO 2505:2005)
EN ISO 3126:2005 Plastics piping systems - Plastics components - Determination of dimensions (ISO 3126:2005)
EN ISO 3458:2015 Plastics piping systems - Mechanical joints between fittings and pressure pipes - Test method for leaktightness under internal pressure (ISO 3458:2015)
EN ISO 3459:2015 Plastic piping systems - Mechanical joints between fittings and pressure pipes - Test method for leaktightness under negative pressure (ISO 3459:2015)
EN ISO 3501:2015 Plastics piping systems - Mechanical joints between fittings and pressure pipes - Test method for resistance to pull-out under constant longitudinal force (ISO 3501:2015)
EN ISO 3503:2015 Plastics piping systems - Mechanical joints between fittings and pressure pipes - Test method for leaktightness under internal pressure of assemblies subjected to bending (ISO 3503:2015)
EN ISO 6259-1:2015 Thermoplastics pipes - Determination of tensile properties - Part 1: General test method (ISO 6259-1:2015)
EN ISO 6259-3:2015 Thermoplastics pipes - Determination of tensile properties - Part 3: Polyolefin pipes (ISO 6259-3:2015)
EN ISO 7686:2005 Plastics pipes and fittings - Determination of opacity (ISO 7686:2005)
EN ISO 8795:2001 Plastics piping systems for the transport of water intended for human consumption - Migration assessment - Determination of migration values of plastics pipes and fittings and their joints (ISO 8795:2001)
EN ISO 9080:2012 Plastics piping and ducting systems - Determination of the long-term hydrostatic strength of thermoplastics materials in pipe form by extrapolation (ISO 9080:2012)
EN ISO 9967:2016 Thermoplastics pipes - Determination of creep ratio (ISO 9967:2016)
EN ISO 9969:2016 Thermoplastics pipes - Determination of ring stiffness (ISO 9969:2016)
EN ISO 10147:2012 Pipes and fittings made of crosslinked polyethylene (PE-X) - Estimation of the degree of crosslinking by determination of the gel content (ISO 10147:2011)
EN ISO 10931:2005 Plastics piping systems for industrial applications - Poly(vinylidene fluoride) (PVDF) - Specifications for components and the system (ISO 10931:2005)
EN ISO 10931:2005/A1:2015 Plastics piping systems for industrial applications - Poly(vinylidene fluoride) (PVDF) - Specifications for components and the system (ISO 10931:2005/FDAM 1:2015)
EN ISO 11295:2010 Classification and information on design of plastics piping systems used for renovation (ISO 11295:2010)
EN ISO 11296-1:2011 Plastics piping systems for renovation of underground non-pressure drainage and sewerage networks - Part 1: General (ISO 11296-1:2009)
EN ISO 11296-3:2011 Plastics piping systems for renovation of underground non-pressure drainage and sewerage networks - Part 3: Lining with close-fit pipes (ISO 11296-3:2009+Cor 1:2011)
EN ISO 11296-4:2011 Plastics piping systems for renovation of underground non-pressure drainage and sewerage networks - Part 4: Lining with cured-in-place pipes (ISO 11296-4:2009, corrected version 2010-06-01)
EN ISO 11296-7:2013 Plastics piping systems for renovation of underground non-pressure drainage and sewerage networks - Part 7: Lining with spirally-wound pipes (ISO 11296-7:2011)
EN ISO 11297-1:2013 Plastics piping systems for renovation of underground drainage and sewerage networks under pressure - Part 1: General (ISO 11297-1:2013)
EN ISO 11297-3:2013 Plastics piping systems for renovation of underground drainage and sewerage networks under pressure - Part 3: Lining with close-fit pipes (ISO 11297-3:2013)
EN ISO 11298-1:2011 Plastics piping systems for renovation of underground water supply networks - Part 1: General (ISO 11298-1:2010)
EN ISO 11298-3:2011 Plastics piping systems for renovation of underground water supply networks - Part 3: Lining with close-fit pipes (ISO 11298-3:2010)
EN ISO 11299-1:2013 Plastics piping systems for renovation of underground gas supply networks - Part 1: General (ISO 11299-1:2011)
EN ISO 11299-3:2013 Plastics piping systems for renovation of underground gas supply networks - Part 3: Lining with close-fit pipes (ISO 11299-3:2011)
EN 12061:1999 Plastics piping systems - Thermoplastics fittings - Test method for impact resistance
EN 12095:1997 Plastics piping systems - Brackets for rainwater piping systems - Test method for bracket strength
EN 12099:1997 Plastics piping systems - Polyethylene piping materials and components - Determination of volatile content
EN 12100:1997 Plastics piping systems - Polyethylene (PE) valves - Test method for resistance to bending between supports
EN 12106:1997 Plastics piping systems - Polyethylene (PE) pipes - Test method for the resistance to internal pressure after application of squeeze-off
CEN/TR 12108:2012 Plastics piping systems - Guidance for the installation inside buildings of pressure piping systems for hot and cold water intended for human consumption
EN 12118:1997 Plastics piping systems - Determination of moisture content in thermoplastics by coulometry
EN 12119:1997 Plastics piping systems - Polyethylene (PE) valves - Test method for resistance to thermal cycling
EN ISO 12162:2009 Thermoplastics materials for pipes and fittings for pressure applications - Classification, designation and design coefficient (ISO 12162:2009)
EN 12200-1:2000 Plastics rainwater piping systems for above ground external use - Unplasticized poly(vinyl chloride) (PVC-U) - Part 1: Specifications for pipes, fittings and the system
CEN/TS 12200-2:2003 Plastics rainwater piping systems for above ground external use - Unplasticized poly(vinyl chloride) (PVC-U) - Part 2: Guidance for the assessment of conformity
EN 12201-1:2011 Plastics piping systems for water supply, and for drainage and sewerage under pressure - Polyethylene (PE) - Part 1: General
EN 12201-2:2011+A1:2013 Plastics piping systems for water supply, and for drainage and sewerage under pressure - Polyethylene (PE) - Part 2: Pipes
EN 12201-3:2011+A1:2012 Plastics piping systems for water supply, and for drainage and sewerage under pressure - Polyethylene (PE) - Part 3: Fittings
EN 12201-4:2012 Plastics piping systems for water supply, and for drainage and sewerage under pressure - Polyethylene (PE) - Part 4: Valves
EN 12201-5:2011 Plastics piping systems for water supply, and for drainage and sewerage under pressure - Polyethylene (PE) - Part 5: Fitness for purpose of the system
CEN/TS 12201-7:2014 Plastics piping systems for water supply, and for drainage and sewerage under pressure - Polyethylene (PE) - Part 7: Guidance for the assessment of conformity
EN 12256:1998 Plastics piping systems - Thermoplastics fittings - Test method for mechanical strength or flexibility of fabricated fittings
CEN/TS 12666-2:2012 Plastics piping systems for non-pressure underground drainage and sewerage - Polyethylene (PE) - Part 2: Guidance for the assessment of conformity
EN 12293:1999 Plastics piping systems - Thermoplastics pipes and fittings for hot and cold water - Test method for the resistance of mounted assemblies to temperature cycling
EN 12294:1999 Plastics piping systems - Systems for hot and cold water - Test method for leaktightness under vacuum
EN 12295:1999 Plastics piping systems - Thermoplastics pipes and associated fittings for hot and cold water - Test method for resistance of joints to pressure cycling
EN 12666-1:2005+A1:2011 Plastics piping systems for non-pressure underground drainage and sewerage - Polyethylene (PE) - Part 1: Specifications for pipes, fittings and the system
EN ISO 13229:2011 Thermoplastics piping systems for non-pressure applications - Unplasticized poly(vinyl chloride) (PVC-U) pipes and fittings - Determination of the viscosity number and K-value (ISO 13229:2010)
EN ISO 13260:2011 Thermoplastics piping systems for non-pressure underground drainage and sewerage - Test method for resistance to combined temperature cycling and external loading (ISO 13260:2010)
EN 13476-1:2007 Plastics piping systems for non-pressure underground drainage and sewerage - Structured-wall piping systems of unplasticized poly(vinyl chloride) (PVC-U), polypropylene (PP) and polyethylene (PE) - Part 1: General requirements and performance characterist
EN 13476-2:2007 Plastics piping systems for non-pressure underground drainage and sewerage - Structured-wall piping systems of unplasticized poly(vinyl chloride) (PVC-U), polypropylene (PP) and polyethylene (PE) - Part 2: Specifications for pipes and fittings with smooth
EN 13476-3:2007+A1:2009 Plastics piping systems for non-pressure underground drainage and sewerage - Structured-wall piping systems of unplasticized poly(vinyl chloride) (PVC-U), polypropylene (PP) and polyethylene (PE) - Part 3: Specifications for pipes and fittings with smooth
CEN/TS 13476-4:2013 Plastics piping systems for non-pressure underground drainage and sewerage - Structured-wall piping systems of unplasticized poly(vinyl chloride) (PVC-U), polypropylene (PP) and polyethylene (PE) - Part 4: Guidance for the assessment of conformity
EN ISO 13477:2008 Thermoplastics pipes for the conveyance of fluids - Determination of resistance to rapid ***** propagation (RCP) - Small-scale steady-state test (S4 test) (ISO 13477:2008)
EN ISO 13478:2007 Thermoplastics pipes for the conveyance of fluids - Determination of resistance to rapid ***** propagation (RCP) - Full-scale test (FST) (ISO 13478:2007)
EN ISO 13479:2009 Polyolefin pipes for the conveyance of fluids - Determination of resistance to ***** propagation - Test method for slow ***** growth on notched pipes (ISO 13479:2009)
EN 13566-2:2005 Plastics piping systems for renovation of underground non-pressure drainage and sewerage networks - Part 2: Lining with continuous pipes
EN 13598-1:2010 Plastics piping systems for non-pressure underground drainage and sewerage - Unplasticized poly(vinyl chloride) (PVC-U), polypropylene (PP) and polyethylene (PE) - Part 1: Specifications for ancillary fittings including shallow inspection chambers
EN 13598-2:2009 Plastics piping systems for non-pressure underground drainage and sewerage - Unplasticized poly(vinyl chloride) (PVC-U), polypropylene (PP) and polyethylene (PE) - Part 2: Specifications for manholes and inspection chambers in traffic areas and deep under
EN 13598-2:2009/AC:2009 Plastics piping systems for non-pressure underground drainage and sewerage - Unplasticized poly(vinyl chloride) (PVC-U), polypropylene (PP) and polyethylene (PE) - Part 2: Specifications for manholes and inspection chambers in traffic areas and deep under
CEN/TS 13598-3:2012 Plastics piping systems for non-pressure underground drainage and sewerage - Unplasticized poly(vinyl chloride)(PVC-U), polypropylene (PP) and polyethylene (PE) - Part 3: Guidance for assessment of conformity
EN ISO 13760:1998 Plastics pipes for the conveyance of fluids under pressure - Miner's rule - Calculation method for cumulative damage (ISO 13760:1998)
EN ISO 13783:1997 Plastics piping systems - Unplasticized poly(vinyl chloride) (PVC-U) end-load-bearing double socket joints - Test method for leaktightness and strength while subjected to bending and internal pressure (ISO 13783:1997)
CEN/TR 13801:2014 Plastics piping systems for soil and waste discharge (low and high temperature) within the building structure - Thermoplastics - Recommended practice for installation
EN ISO 13844:2015 Plastics piping systems - Elastomeric-sealing-ring-type socket joints for use with plastic pressure pipes - Test method for leaktightness under negative pressure, angular deflection and deformation (ISO 13844:2015)
EN ISO 13845:2015 Plastics piping systems - Elastomeric-sealing-ring-type socket joints for use with thermoplastic pressure pipes - Test method for leaktightness under internal pressure and with angular deflection (ISO 13845:2015)
EN ISO 13846:2000 Plastics piping systems - End-load-bearing and non-end-load-bearing assemblies and joints for thermoplastics pressure piping - Test method for long-term leaktightness under internal water pressure (ISO 13846:2000)
EN ISO 13967:2009 Thermoplastics fittings - Determination of ring stiffness (ISO 13967:2009)
EN ISO 13968:2008 Plastics piping and ducting systems - Thermoplastics pipes - Determination of ring flexibility (ISO 13968:2008)
EN 14364:2013 Plastics piping systems for drainage and sewerage with or without pressure - Glass-reinforced thermosetting plastics (GRP) based on unsaturated polyester resin (UP) - Specifications for pipes, fittings and joints
CEN/TS 14541:2013 Plastics pipes and fittings - Characteristics for utilisation of non-virgin PVC-U, PP and PE materials
CEN/TS 14578:2013 Plastics piping systems for water supply or drainage and sewerage - Glass-reinforced thermosetting plastics (GRP) based on unsaturated polyester resin (UP) - Recommended practice for installation
CEN/TS 14632:2012 Plastics piping systems for drainage, sewerage and water supply, pressure and non-pressure - Glass-reinforced thermosetting plastics (GRP) based on unsaturated polyester resin (UP) - Guidance for the assessment of conformity
EN 14636-1:2009 Plastics piping systems for non-pressure drainage and sewerage - Polyester resin concrete (PRC) - Part 1: Pipes and fittings with flexible joints
EN 14636-2:2009 Plastics piping systems for non-pressure drainage and sewerage - Polyester resin concrete (PRC) - Part 2: Manholes and inspection chambers
EN 14741:2006 Thermoplastics piping and ducting systems - Joints for buried non-pressure applications - Test method for the long-term sealing performance of joints with elastomeric seals by estimating the sealing pressure
EN 14758-1:2012 Plastics piping systems for non-pressure underground drainage and sewerage - Polypropylene with mineral modifiers (PP-MD) - Part 1: Specifications for pipes, fittings and the system
CEN/TS 14758-2:2007 Plastics piping systems for non-pressure underground drainage and sewerage - Polypropylene with mineral modifier(s) (PP-MD) - Part 2: Guidance for the assessment of conformity
EN 14802:2005 Plastics piping systems - Thermoplastics shafts or risers for inspection chambers and manholes - Determination of resistance against surface and traffic loading
CEN/TS 14807:2013 Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) based on unsaturated polyester resin (UP) - Guidance for the structural analysis of buried GRP-UP pipelines
EN 14830:2006 Thermoplastics inspection chamber and manhole bases - Test methods for buckling resistance
EN 14982:2006+A1:2010 Plastics piping and ducting systems - Thermoplastics shafts or risers for inspection chambers and manholes - Determination of ring stiffness
EN 15012:2007 Plastics piping systems - Soil and waste discharge systems within the building structure - Performance characteristics for pipes, fittings and their joints
EN 15014:2007 Plastics piping systems - Buried and above ground systems for water and other fluids under pressure - Performance characteristics for pipes, fittings and their joints
EN 15015:2007 Plastics piping systems - Systems for hot and cold water not intended for human consumption - Performance characteristics for pipes, fittings and their joints
CEN/TS 15223:2008 Plastics piping systems - Validated design parameters of buried thermoplastics piping systems
EN 15383:2012+A1:2013 Plastics piping systems for drainage and sewerage - Glass-reinforced thermosetting plastics (GRP) based on polyester resin (UP) - Manholes and inspection chambers
CEN/TR 15438:2007 Plastics piping systems - Guidance for coding of products and their intended uses
EN ISO 15493:2003 Plastics piping systems for industrial applications - Acrylonitrile-butadiene-styrene (ABS), unplasticized poly(vinyl chloride) (PVC-U) and chlorinated poly(vinyl chloride) (PVC-C) - Specifications for components and the system - Metric series (ISO 15493:
EN ISO 15494:2015 Plastics piping systems for industrial applications - Polybutene (PB), polyethylene (PE), polyethylene of raised temperature resistance (PE-RT), crosslinked polyethylene (PE-X), polypropylene (PP) - Metric series for specifications for components and the system (ISO 15494:2015)
CEN/TR 15729:2010 Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) based on unsaturated polyester resin (UP) - Report on the determination of mean abrasion after a defined number of test cycles
EN ISO 15874-1:2013 Plastics piping systems for hot and cold water installations - Polypropylene (PP) - Part 1: General (ISO 15874-1:2013)
EN ISO 15874-2:2013 Plastics piping systems for hot and cold water installations - Polypropylene (PP) - Part 2: Pipes (ISO 15874-2:2013)
EN ISO 15874-3:2013 Plastics piping systems for hot and cold water installations - Polypropylene (PP) - Part 3: Fittings (ISO 15874-3:2013)
EN ISO 15874-5:2013 Plastics piping systems for hot and cold water installations - Polypropylene (PP) - Part 5: Fitness for purpose of the system (ISO 15874-5:2013)
CEN ISO/TS 15874-7:2003 Plastics piping systems for hot and cold water installations - Polypropylene (PP) - Part 7: Guidance for the assessment of conformity (ISO/TS 15874-7:2003)
EN ISO 15875-1:2003 Plastics piping systems for hot and cold water installations - Crosslinked polyethylene (PE-X) - Part 1: General (ISO 15875-1:2003)
EN ISO 15875-1:2003/A1:2007 Plastics piping systems for hot and cold water installations - Crosslinked polyethylene (PE-X) - Part 1: General (ISO 15875-1:2003)
EN ISO 15875-2:2003 Plastics piping systems for hot and cold water installations - Crosslinked polyethylene (PE-X) - Part 2: Pipes (ISO 15875-2:2003)
EN ISO 15875-2:2003/A1:2007 Plastics piping systems for hot and cold water installations - Crosslinked polyethylene (PE-X) - Part 2: Pipes (ISO 15875-2:2003)
EN ISO 15875-3:2003 Plastics piping systems for hot and cold water installations - Crosslinked polyethylene (PE-X) - Part 3: Fittings (ISO 15875-3:2003)
EN ISO 15875-5:2003 Plastics piping systems for hot and cold water installations - Crosslinked polyethylene (PE-X) - Part 5: Fitness for purpose of the system (ISO 15875-5:2003)
CEN ISO/TS 15875-7:2003 Plastics piping systems for hot and cold water installations - Crosslinked polyethylene (PE-X) - Part 7: Guidance for the assessment of conformity (ISO/TS 15875-7:2003)
EN ISO 15876-1:2003 Plastics piping systems for hot and cold water installations - Polybutylene (PB) - Part 1: General (ISO 15876-1:2003)
EN ISO 15876-1:2003/A1:2007 Plastics piping systems for hot and cold water installations - Polybutylene (PB) - Part 1: General (ISO 15876-1:2003)
EN ISO 15876-2:2003 Plastics piping systems for hot and cold water installations - Polybutylene (PB) - Part 2: Pipes (ISO 15876-2:2003)
EN ISO 15876-2:2003/A1:2007 Plastics piping systems for hot and cold water installations - Polybutylene (PB) - Part 2: Pipes (ISO 15876-2:2003)
EN ISO 15876-3:2003 Plastics piping systems for hot and cold water installations - Polybutylene (PB) - Part 3: Fittings (ISO 15876-3:2003)
EN ISO 15876-5:2003 Plastics piping systems for hot and cold water installations - Polybutylene (PB) - Part 5: Fitness for purpose of the system (ISO 15876-5:2003)
CEN ISO/TS 15876-7:2003 Plastics piping systems for hot and cold water installations - Polybutylene (PB) - Part 7: Guidance for the assessment of conformity (ISO/TS 15876-7:2003)
EN ISO 15877-1:2009 Plastics piping systems for hot and cold water installations - Chlorinated poly(vinyl chloride) (PVC-C) - Part 1: General (ISO 15877-1:2009)
EN ISO 15877-1:2009/A1:2010 Plastics piping systems for hot and cold water installations - Chlorinated poly(vinyl chloride) (PVC-C) - Part 1: General (ISO 15877-1:2009)
EN ISO 15877-2:2009 Plastics piping systems for hot and cold water installations - Chlorinated poly(vinyl chloride) (PVC-C) - Part 2: Pipes (ISO 15877-2:2009)
EN ISO 15877-2:2009/A1:2010 Plastics piping systems for hot and cold water installations - Chlorinated poly(vinyl chloride) (PVC-C) - Part 2: Pipes (ISO 15877-2:2009)
EN ISO 15877-3:2009 Plastics piping systems for hot and cold water installations - Chlorinated poly(vinyl chloride) (PVC-C) - Part 3: Fittings (ISO 15877-3:2009)
EN ISO 15877-3:2009/A1:2010 Plastics piping systems for hot and cold water installations - Chlorinated poly(vinyl chloride) (PVC-C) - Part 3: Fittings (ISO 15877-3:2009)
EN ISO 15877-5:2009 Plastics piping systems for hot and cold water installations - Chlorinated poly(vinyl chloride) (PVC-C) - Part 5: Fitness for purpose of the system (ISO 15877-5:2009)
EN ISO 15877-5:2009/A1:2010 Plastics piping systems for hot and cold water installations - Chlorinated poly(vinyl chloride) (PVC-C) - Part 5: Fitness for purpose of the system (ISO 15877-5:2009)
CEN ISO/TS 15877-7:2009 Plastics piping systems for hot and cold water installations - Chlorinated poly(vinyl chloride) (PVC-C) - Part 7: Guidance for the assessment of conformity (ISO/TS 15877-7:2009)
EN 16000:2010 Plastics piping systems - Systems within the building structure - Mounting and fixing of components in the test apparatus to thermal attack by a single burning item
EN ISO 16871:2003 Plastics piping and ducting systems - Plastics pipes and fittings - Method for exposure to direct (natural) weathering (ISO 16871:2003)
EN ISO 17778:2015 Plastics piping systems - Fittings, valves and ancillaries - Determination of gaseous flow rate/pressure drop relationships (ISO 17778:2015)
EN ISO 21003-1:2008 Multilayer piping systems for hot and cold water installations inside buildings - Part 1: General (ISO 21003-1:2008)
EN ISO 21003-2:2008 Multilayer piping systems for hot and cold water installations inside buildings - Part 2: Pipes (ISO 21003-2:2008)
EN ISO 21003-2:2008/A1:2011 Multilayer piping systems for hot and cold water installations inside buildings - Part 2: Pipes (ISO 21003-2:2008)
EN ISO 21003-3:2008 Multilayer piping systems for hot and cold water installations inside buildings - Part 3: Fittings (ISO 21003-3:2008)
EN ISO 21003-5:2008 Multilayer piping systems for hot and cold water installations inside buildings - Part 5: Fitness for purpose of the system (ISO 21003-5:2008)
CEN ISO/TS 21003-7:2008 Multilayer piping systems for hot and cold water installations inside buildings - Part 7: Guidance for the assessment of conformity (ISO/TS 21003-7:2008)
CEN ISO/TS 21003-7:2008/A1:2010 Multilayer piping systems for hot and cold water installations inside buildings - Part 7: Guidance for the assessment of conformity (ISO/TS 21003-7:2008)
EN ISO 22391-1:2009 Plastics piping systems for hot and cold water installations - Polyethylene of raised temperature resistance (PE-RT) - Part 1: General (ISO 22391-1:2009)
EN ISO 22391-2:2009 Plastics piping systems for hot and cold water installations - Polyethylene of raised temperature resistance (PE-RT) - Part 2: Pipes (ISO 22391-2:2009)
EN ISO 22391-3:2009 Plastics piping systems for hot and cold water installations - Polyethylene of raised temperature resistance (PE-RT) - Part 3: Fittings (ISO 22391-3:2009)
EN ISO 22391-5:2009 Plastics piping systems for hot and cold water installations - Polyethylene of raised temperature resistance (PE-RT) - Part 5: Fitness for purpose of the system (ISO 22391-5:2009)
CEN ISO/TS 22391-7:2011 Plastics piping systems for hot and cold water installations - Polyethylene of raised temperature resistance (PE-RT) - Part 7: Guidance for the assessment of conformity (ISO/TS 22391-7:2011)
CEN ISO/TR 27165:2012 Thermoplastics piping systems - Guidance for definitions of wall constructions for pipes (ISO/TR 27165:2012)
missing AMD's or AC's:
EN 705:1994/AC:1995 Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes and fittings - Methods for regression analysis and their use - missing AC 1995
EN 761:1994/AC:1995 Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes - Determination of the creep factor under dry conditions - missing AC 1995
EN 1393:1996/AC:1997 Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes - Determination of initial longitudinal tensile properties - missing AC 1997
EN 1394:1996/AC:1997 Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes - Determination of the apparent initial circumferential tensile strength - missing AC 1997
EN ISO 10931:2005/A1:2015 Plastics piping systems for industrial applications - Poly(vinylidene fluoride) (PVDF) - Specifications for components and the system (ISO 10931:2005/FDAM 1:2015) - missing A1:2015
missing standards:
missing valid editions:
or
