Thread: Fluid Power Engineering by Rabe
    Author(s): M Rabie
    Publisher: McGraw-Hill Professional
    Date : 2009
    ISBN-10 : 0071622462
    Develop high-performance hydraulic and pneumatic power systems
    Design, operate, and maintain fluid and pneumatic power equipment using the expert information contained in this authoritative volume. Fluid Power Engineering presents a comprehensive approach to hydraulic systems engineering with a solid grounding in hydrodynamic theory. The book explains how to create accurate mathematical models, select and assemble components, and integrate powerful servo valves and actuators. You will also learn how to build low-loss transmission lines, analyze system performance, and optimize efficiency.
    •Work with hydraulic fluids, pumps, gauges, and cylinders
    •Design transmission lines using the lumped parameter model
    •Minimize power losses due to friction, leakage, and line resistance
    •Construct and operate accumulators, pressure switches, and filters
    •Develop mathematical models of electrohydraulic servosystems
    •Convert hydraulic power into mechanical energy using actuators
    •Precisely control load displacement using HSAs and control valves
    •Apply fluid systems techniques to pneumatic power systems
    Links :
    thank you
  1. Fluid Power: Theory and Applications 3rd Ed.
    By mkhurram79 in forum Mechanical Engineering
    Last Post: 12-14-2012, 01:06 AM
  2. [request] iso standard for pneumatic fluid power
    By arifinbc in forum Pipeline And Fluid Flow
    Last Post: 12-02-2012, 04:46 PM
  3. Power Gained by Fluid
    Last Post: 01-26-2012, 12:39 PM
  4. Replies: 0
    Last Post: 07-27-2011, 12:46 AM
  5. The power gained by fluid from operating pumps or fans
    Last Post: 07-26-2011, 10:31 AM
