Results 1 to 8 of 8
Thread: Sizing of relief valves in process piping
  1. Sizing of relief valves in process piping
    Dear Friends;
    Please anyone can kindly share how to size corretlly a relief valve in process piping?
    Thank you
  3. Re: Sizing of relief valves in process piping
    What is the duty? Gas/liquid?
    Relief valves are sized in accordance with the procedure in API 520 Part 1, but you don't normally see relief valves on process piping, they are normally on vessels. You do, however, see thermal relief valves on piping to guard against thermal expansion. In this case, it is usual to just install the smallest relief valve which is 1D2 if I recall correctly.
  5. Re: Sizing of relief valves in process piping
    Sizing criteria as per API 520
    1. Pressure drop for rated flow in suction piping shall not exceed 3% of set pressure of PSV
    2. Pressure drop in discharge piping for rated flow shall not exceed 10% of set pressure of PSV considering back press
  9. Re: Sizing of relief valves in process piping
    For thermal expansion case in the Liquid piping, size of (NPS 3/4 x NPS 1) is commonly used as per API STD 521 para 5.14.2.
    If there is reason to believe that this size is not adequate, calculated procedure must be applied.
    Quote Originally Posted by gtaa View Post
    Smile Re: Sizing of relief valves in process piping
    Thermal relief valve generally considers
    1. expansion of trapped liquid due to solar radiation/ambient temp change
    2. No vapourisation during heating
    It is liquid drop expulsion to relieve the pressure arising due to the expansion of trapped liquid in a pipeline section with closed condition . size 3/4 " x 1" is generally acceptable . even if u do calculation u will find size covering the flow rate calculated. This size has been standardised across industry.
  11. Re: Sizing of relief valves in process piping
    Just get the Pentair PRV sizing program, the manual that comes with it has how to size as well
  1. Replies: 2
    Last Post: 05-20-2018, 09:33 PM
  2. Replies: 16
    Last Post: 01-04-2016, 07:33 AM
  3. Could Safety-relief valves be used in gas services?
    By aidini in forum Safety And Environment
    Last Post: 09-09-2014, 02:37 AM
  4. Arrangement of discharge piping from Pressure Relief Valves
    By malarfra in forum Pipeline And Fluid Flow
    Last Post: 05-22-2014, 12:46 AM
  5. Sizing of Thermal Relief Valves
    By patelnikunjr in forum Safety And Environment
    Last Post: 07-31-2013, 07:15 AM
