Thread: Could Safety-relief valves be used in gas services?
    Safety valves are used in gas services while Relief valves in liquid services.
    Is it possible to use Safety-relief valves in gas services?
    If yes, how is their reaction to pressure excess, do they pop-up like safety valves or gradually open?
  3. Re: Could Safety-relief valves be used in gas services?
    In gas service, pressure relief valve is used only for pump discharge also known as 'by pass valve' to prevent overpressure in discharge pipe. The pressure setting is lower than safety valve
  5. Re: Could Safety-relief valves be used in gas services?
    For the most part, safety valves and relief valves are the same thing. I've seen them referred to as PRVs (pressure relief valves) and PSVs (pressure safety valves).
    I think by relief valves in liquid service you may be thinking of thermal relief valves. These are very small (typically 1 x 1.5") and open momentarily to relieve pressure resulting from the heating of a trapped liquid stream. Note however that liquid systems may also have 'proper' relief valves - particularly on the discharge side of positive displacement pumps.
    To answer your question though, yes. PRVs/PSVs are indeed used in gas service for overpressure protection. However, it is more common to find them on vessels and equipment rather than piping itself. They are sized for a variety of duties, including external fire, control valve failure, blocked discharge to name a few.
    For more information, get yourself a copy of API 520 Part 1 and have a read.
  6. Re: Could Safety-relief valves be used in gas services?
  1. Replies: 16
    Last Post: 01-04-2016, 07:33 AM
  2. Are Safety-relief valves used in gas services?
    By aidini in forum Instrumentation & Control
    Last Post: 09-06-2014, 04:22 AM
  3. NEED MSS SP-134-2010 : Valves for cryogenic services.
    By amshah in forum Mechanical Engineering
    Last Post: 11-16-2013, 03:23 AM
  4. Sizing of Thermal Relief Valves
    By patelnikunjr in forum Safety And Environment
    Last Post: 07-31-2013, 07:15 AM
  5. Isolation valves upstream of safety valves
    By bkay in forum Safety And Environment
    Last Post: 06-08-2009, 02:32 AM
