Thread: condenser water box top elevation
  1. condenser water box top elevation
    can any one tell me why is it desirable to have condenser elevation in a power plant higher than that of cooling tower inlet. As mentioned above cooling water head will be governed by condenser top.
    Re: condenser water box top elevation
    The condenser w&#225;ter box highest point should be lower than cooling tower riser to avoid vacuum when a circulating w&#225;ter pump trip.
    Otherwise additional equipment such as priming systems are required
    My recomendation is to have the condenser as low as posible , although steam turbine limits the condenser elevation
  5. Re: condenser water box top elevation
    do u have any condenser design guide
  1. Article: condenser water box top elevation
    By deepak_gharpure1 in forum Home Articles
    Last Post: 04-07-2013, 11:24 PM
  2. Digital Elevation overlay for Google Earth (.KMZ)
    By milonerva in forum Geology & Exploration
    Last Post: 06-16-2011, 09:33 AM
  3. how to deside heat exchanger elevation
    By aakul1127 in forum Oil And Gas Process
    Last Post: 08-02-2010, 06:02 PM
  4. Pump elevation
    Last Post: 07-26-2010, 06:54 PM
