Thread: Article: condenser water box top elevation
  1. Article: condenser water box top elevation
    You can view the page at
  3. Re: Article: condenser water box top elevation
    I think it would be better for exhaust air/gas out of cooling water pipes
    Condenser water box elevation at top should be below cooling tower riser outlet, as far as possible
    The Condenser will be always under pressure and less air is released inside.
    Through transients ( ie pump trips) less problems will occurs with vacuum and column separation
    If top of the condenser is above cooling tower, condenser priming is required for system starting to recover the syphon.
  1. Article: Water Loading in Oil Well
    By HashfiHazazi in forum Home Articles
    Last Post: 11-19-2013, 09:24 PM
  2. condenser water box top elevation
    By deepak_gharpure1 in forum Mechanical Engineering
    Last Post: 03-16-2013, 07:08 PM
  3. Replies: 0
    Last Post: 09-10-2010, 10:44 PM
  4. Article: hysys condenser...dynamic simulation
    By marchese85 in forum Home Articles
    Last Post: 06-18-2010, 01:15 AM
