Hi friend
I think 12 mm is good you have to the calculate the thk. not only for internal pressure but also for external load due to process coil and fire tubes.let me know the weight and size of the fire tube sizes,process coil and also heat duty.
can you please upload process design calculation for the Indirect water bath Heater, if possible example problem also.
thank you
